Less low end grunt after exhaust install? - JeepForum.com
post #1 of 5 Old 02-11-2011, 05:20 PM Thread Starter
nassin2
2005 WK
I just had 3 inch magnaflow exhaust installed on my 5.7 gc. It sounds really nice and all but my seat of the pants impression is that it doesn't seem to have quite as much low end power as before. They removed the resonator by the back bumper when the exhaust was installed. I'm wondering if maybe I lost some needed back pressure. Has anyone else noticed this after having exhaust installed?
04 WJ Limited 4.7, Quadradrive, 2 inch BB, Skyjacker 8000 nitros, rough country stabilizer, hella lights <--Totalled
05 WK Limited Hemi, QD2, K&N intake, Magnaflow exhaust
Black WK Club Member #11
nassin2 is offline
post #2 of 5 Old 02-25-2011, 05:40 AM
DAHEMI
2005 WK
was hoping for some replies as I'm following that other thread before splurging on an exhaust. my WAG is doubtful the muffler swap and resonator delete effected low end much. that big ole Hemi is already necked down to a single exhaust and the resonator isn't much of a restriction itself just a sonic tuning aid. you should hear my neighbor warming up his Hemi Ram every morning. good thing I like harmonics and drone. even at oh-dark-thirty in the morning love that V8 rumble!
has there been any other changes in driving / mpg? going for the Superchips later?
2005 WK GC LTD 5.7L Hemi QD II 4WD Midnight Blue Pearl 33k
Blue WK Club Member #1
my poor signature is thrashed so deleted it
The Second Amendment - America's Original Homeland Security
DAHEMI is offline
post #3 of 5 Old 02-25-2011, 06:12 AM
jmohlerfaria
little light on the low end
re-increase your back pressure.
should help restore the low end.
did you change anything else?
RE long arm $5500.00
35x12.50 $1200.00
skid plates $400.00
parking on your a**hole neighbor's honda : ) Priceless
jmohlerfaria is offline
post #4 of 5 Old 02-25-2011, 01:09 PM
90grandoneer
90grandoneer's Avatar
2006 WK
You may loose a very little low end with the 3 in. system, but overall (city/highway) you will see improvement. The biggest problem with the Hemi breathing adequately is the stock exhaust manifolds. Although they port match the heads (1 3/8 in.), internally the ports dump into each other from front to back and exit into a 1 7/8 in. ID collector. With the firing order as it is, not all of the cylinders scavenge through the manifolds adequately, especially the driver's side. Once into the single system they should scavenge better than a dual system. I would guess that you have a pretty big drone issue on yours without any other silencing other than the Magnaflow. Which one do you have. On mine I have two 12 in. glasspacks (one in front of the Magnaflow and one in the resonator position) and a 14589 Magnaflow, and it is just barely passes the wife test, especially when the MDS is active. In V-8 mode it's not too bad.
06 GCO, Dk Khaki, QDII, Flshing Hi 3rd Bk Lt, MDS "ON" Lt, Airtab Vortex Gens, Debadged, Fumoto Drain Valve, BT Catch Can, Chopped EGR Tube, SRT8 CAI, TruFlow Filter, Sonnax Trans Line Press Booster, SC Tuner W/Adv Trans Tune App, Transgo Shift Kit, DS Tuner, Cust tubular hdrs w/3 in Magnaflow/Xlerator AP Exh Sys, Bilsteins, SRT Springs/Sways, Cust Eng Cvr, SRT8 frt/rear bumpers, FRI Sidewinder Cam w/6* advance/6.1 valvetrain, SLP 25% UD Pulley, BBK true 90mm T-Body, SOS Ign Coils w/.060 spark plug gaps, TEA ported/milled heads, SRT Reps with 265/45&295/40X20's.
90grandoneer is offline
post #5 of 5 Old 02-25-2011, 11:39 PM Thread Starter
nassin2
2005 WK
After having the exhaust for awhile it sounds really nice with no noticeable drone. I have the big body magnaflow and that really melllows out the exhaust tone. The exhaust combined with my K and N intake makes for some really nice noises The low end really isn't much different after getting used to the exhaust.
nassin2 is offline
exhaust , magnaflow
ZJ exhaust install jkruk ZJ Grand Cherokee Forum 6 02-02-2010 09:50 PM
2 second grind / grunt when put in reverse adgjqetuo ZJ Grand Cherokee Forum 9 08-20-2009 07:54 AM
Groan or grunt shortly after starting off? John in MA ZJ Grand Cherokee Forum 12 11-05-2006 09:45 AM
Exhaust Install Teds98Grand ZJ Grand Cherokee Forum 15 07-21-2006 08:09 PM
Grunt from steering... dpierson ZJ Grand Cherokee Forum 7 03-08-2005 04:44 PM
