left rear tails do not work--left signal, backup and left stop do - JeepForum.com
post #1 of 11 Old 12-06-2008, 12:21 PM Thread Starter
kenific
Hi,
I have a Grand Cherokee 2005 Laredo. When I turn on my headlights the back left tail lights dont come on. The back left directional works, the stop and backup do work. I even put in bulbs from the right side to see if something wacky was going on with the connectors to the bulbs themselves. Same issue.--The top left tail light and middle tail will not turn on. Probably not a fuse issue since all of the right side lights work fine?
Thanks
JPK
kenific is offline
post #2 of 11 Old 12-06-2008, 12:40 PM Thread Starter
kenific
to add- I took the entire light bulb and the casing from the right to test into the left tail lights. still no dice.
kenific is offline
post #3 of 11 Old 12-06-2008, 06:36 PM
fatfreddy
2008 WK
Have you checked you fuses.On 2008 they have seperate left and right tail light fuses.Maybe 2005's have seperate fuses also.
fatfreddy is offline
post #4 of 11 Old 12-07-2008, 06:31 AM Thread Starter
kenific
I have not. I looked in the manual under fuse section but it was not clear if there were separate fuses for left and right tail lights.
If anyone knows if they exist, please let me know where I can find them.
It appears there is a fuse section by the steering wheel and two separate fuse "boxes" under the front hood. Hopefully the fuse is the cause because I believe the next thing to look at would be wiring leading up to both tail lights. If thats the case, it would be suspect that just a tail light wire going to each tailight on the left broke or came loose. But then again, what do I know...hence Im here! Thanks....
kenific is offline
post #5 of 11 Old 12-07-2008, 07:34 AM
robpp
The fuses are seperate.
http://www.wkjeeps.com/wk_fuses.htm
Rob 007 Laredo 4.7 FFV 27X; DeBadg'd; Zaino'd; SRT8 Grill, Pedals, Strut; ClearBra; WeatherTech; LED Reverse; HIR Hi/Lo; SS Fog; Stealth Turns; 15% Tint; Stubbie; Rear Spoiler; Magnaflow; V1; 22Elite Console/Visors; Body Kit; Color Match Everything; TintedTails; K&N 63; Front Skid; QuickOilDrainValve; BatteryTender; SuperChips 91; Bilstein; Billet Window Switches; Greasable Addco Sways; RamMedic Hood; Fastman TB; BWoody Links; Kicker Upgrade w/Single Sub; AVIC F90BT Hacked; NeffyWrap ABCD; Putco LEDs; Viper 20s w/255/50; R1 Slot/Dimple w/Hawk Pro Ceramic; Whistler Mod w/FlashTech Halos
robpp is offline
post #6 of 11 Old 12-07-2008, 09:26 AM Thread Starter
kenific
Thanks guys...hoping this saves me a trip to the dealer to check anything else. Much appreciated...
kenific is offline
post #7 of 11 Old 12-07-2008, 09:45 AM Thread Starter
kenific
actually, Im back--sorry---Is this in the PDC grouping as found on the page above? Sorry, I am not that familiar with some of the acronyms that are used there. I am guessing its cavity 8 in the integrated power module?
kenific is offline
post #8 of 11 Old 12-07-2008, 11:57 AM
robpp
Looks like thats the correct one.
Disconnect the nbegative before you start pulling and checking breakers or fuses.
robpp is offline
post #9 of 11 Old 12-07-2008, 12:25 PM
johnniebravo
2008 WK
I was working on a liberty recently and it had a similar issue. We did everything possible. The last ditch effort by the guy I was helping was to source a third rear brake light from the salvage yard and test it. It fixed everything as the original unit had a short in it.
symptoms included no brake lights, non-working rear 12 volt outlet.
couple of questions:
does your 12 volt outlet (if you have one) still work?
does the 3rd brake light work properly?
Overall we knew it had something to do with the rear ground. and as the third brake light had it's own ground it worked fine.
2008 CRD GC
johnniebravo is offline
post #10 of 11 Old 12-07-2008, 01:23 PM Thread Starter
kenific
Yes, my 12 volt works---all of the brakes light work....I just solved the problem by the help of the guy speaking about the fuse---I just replaced the left park fuse ---cavity 8 on the website above...put the battery neg back on and sparked it up---and good news---all the lights work as expected. Thanks again...
kenific is offline
post #11 of 11 Old 12-07-2008, 01:38 PM
robpp
Glad to hear that worked.
On these WKs, I disconnect the negative to do practically everything. Even change a light bulb. We have this IOD system, way to sensitive. And as you've seen, everything is controlled by a module.
robpp is offline
Left rear turn signal intermittant legerdemain ZJ Grand Cherokee Forum 4 12-06-2011 11:15 PM
Rear left running light doesn't work ZJcrawler45 ZJ Grand Cherokee Forum 3 06-07-2010 02:47 PM
Left turn signal MNWJ ZJ Grand Cherokee Forum 6 01-12-2010 07:18 AM
Popping Noise From Left Front When Turning Left Only SSF556 WK Grand Cherokee & XK Commander Forum 1 08-14-2008 03:09 AM
Back left turn signal doesnt work? pulsepb ZJ Grand Cherokee Forum 7 06-09-2007 12:24 PM
