LED Wiring - JeepForum.com
post #1 of 13 Old 01-01-2017, 07:40 PM Thread Starter
commanding2016
LED Wiring
Long story short...
Mounting LED pods on 4 sides of a roof rack. Bought a switch plate from Steel Dillo and have 5 switches coming from eBay. I need 5 harnesses for this setup to control the lighting how I want, but every harness I find comes with a switch and plugs. Is there a company that sells what I need, but without a switch and plugs included? Just need fuse and relay. Also need wire as it's obviously longer than 10 feet runs which is what most of these harnesses online are. Prefer US based as I want to complete this project next weekend.
Thanks so much!
commanding2016 is offline
post #2 of 13 Old 01-01-2017, 07:50 PM
Budasac
2005 WK
You need to just buy the relays and wire it up yourself. You're not going to find a pre-fab harness for what you want to do.
Budasac is online now
post #3 of 13 Old 01-01-2017, 08:00 PM Thread Starter
commanding2016
Is there a good site to buy what I need? Never wired anything outside of car audio stuff a decade ago.
post #4 of 13 Old 01-01-2017, 08:09 PM
JeffQuinn
Your local auto parts store should have relays and rolls of wire in stock.
Jeff Quinn
Gunblast.com
JeffQuinn is offline
post #5 of 13 Old 01-01-2017, 08:20 PM Thread Starter
commanding2016
Can you tell I never go in one of those? HA! Is that the cheapest route though? I'm doing everything possible to save money on this truck as it's at 160k and you never know. Thanks
post #6 of 13 Old 01-01-2017, 09:33 PM
Budasac
2005 WK
I wrote up a thread about five years ago to help people wire their lights and accessories up. Check it out. Maybe it'll give you some ideas.
http://www.jeepforum.com/forum/f67/e...elays-1207445/
post #7 of 13 Old 01-02-2017, 07:36 AM
acabtp
2005 WK
http://www.digikey.com
'05 WK Limited 5.7 Hemi
acabtp is offline
post #8 of 13 Old 01-02-2017, 05:39 PM Thread Starter
commanding2016
Thanks for this. My plan is to run 5 relays (only going to utilize 4 for this project until the steel bumper / winch project begins) and I'm even more confused now with the fuse block, ha. Is this a must for this many relays? Or can I just run fuses in line like they are when you buy the relay harnesses?
Assuming the fuse block is just to keep things neater, correct?
Thanks for the post! The diagrams and photos make it much more clear for me.
post #9 of 13 Old 01-02-2017, 05:40 PM Thread Starter
commanding2016
Originally Posted by acabtp View Post
Thanks for the link
post #10 of 13 Old 01-02-2017, 07:01 PM
Budasac
2005 WK
Correct,. The fuse block is just to keep it more organized. You can run them all inline. I was trying to avoid having a fistful of wires attached to the battery and a bunch of fuses floating around. I also don't like having splices in the wires if it can be avoided and the inline fuses typically come with 6" leads.
post #11 of 13 Old 01-02-2017, 07:45 PM Thread Starter
commanding2016
Great, thanks. I'll look under the hood and get a better idea of the space I have and make a decision at that time. May be tough to mount 5 damn relays next to each other, lol. Might have no other choice but to add a block to ensure I don't have that fistful, spiderweb / nest of wires.
post #12 of 13 Old 01-02-2017, 07:53 PM
JeffQuinn
If you are running low-amperage LED lights, you do not have to use relays. Run a large-gauge wire to the fuse block, and run directly from the fuse block to each switch, then from each switch to each light. Less clutter, and saves you money. Just make sure that your switches are of proper amperage.
Jeff Quinn
Gunblast.com
post #13 of 13 Old 01-03-2017, 04:11 PM
05AKWK
Junkyard is your friend on this one. This is the stock relay box with an extra relay bank added.
05AKWK is offline
