leaking diesel fuel injector solved - JeepForum.com
post #1 of 2 Old 02-15-2014, 11:36 AM Thread Starter
brewcider
If you have an injector leaking from the return line, slide the clips up on the return line that holds them to the injector and you can remove line then. The clips are the plastic donut things that can spin around. It may take a lot of effort to slide the clips up. Look for an O-ring on the injector, they're very tiny and you almost can't see them. The Jeep parts diagram doesn't really show the rings on the injector, however the Sprinter parts diagram shows them. I got mine form europarts since I was also buying a fuel filter and didn't want to pay dealer prices. http://europarts-sd.com/item.asp?cID=114&PID=2197
Anyway I took the line off of my injector and there was no ring to be found... I'm not sure where it went. The other injectors had the ring. That would explain the leak I guess.
The part number is 68014080AA for the Mopar part, or A0000780580 for the Mercedes part.
sold - 2005 Liberty Limited CRD, 22G Package, Atlantic Blue, fully loaded.
2007 Grand Cherokee Limited Diesel 4x4
brewcider is offline
post #2 of 2 Old 02-15-2014, 01:11 PM
suzieque
2008 WK
Good work in diagnosing and repairing. And thanks for the photos.
2008 WK "S" Limited bright metallic silver exterior, light graystone interior, 5 speed W5J400 transmission, June 18/2008 build, C213RE rear differential with 3.73 axle ratio, C200FE front differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, GT2056V turbo, 3.0L CRD (OM642.980)
suzieque is offline
