leaking diesel fuel injector - JeepForum.com
post #1 of 43 Old 01-01-2014, 04:41 PM Thread Starter
brewcider
I noticed a drip coming from my 07 GC CRD and at first I thought it was my air conditioner. Then I got my oil change at the dealer and they said I had a fuel leak and wanted $150 to diagnose the problem. I told them no and I finally traced down the leak and it looks like the injector on cylinder 1 is leaking. Notice it's wet in the picture. At idle it's doing about 4-5 drips a second. From what I read is I may just need to replace the bolt and copper ring. I believe it's these...
http://europarts-sd.com/fuelinjector...w2002-2009.asp
http://europarts-sd.com/fuelinjector...r2002-2008.asp
I've never removed a fuel injector before. Any help would be appreciated, thanks
sold - 2005 Liberty Limited CRD, 22G Package, Atlantic Blue, fully loaded.
2007 Grand Cherokee Limited Diesel 4x4
brewcider is offline
post #2 of 43 Old 01-01-2014, 04:56 PM
Lyc360
2005 WK
Why can't you just tighten up the connector?
Lyc360 is offline
post #3 of 43 Old 01-01-2014, 05:06 PM
willyok
2008 WK
yea see if you can get in there with a crows foot, and tighten the nut. dont over tighten it. if its not loose remove the line and check for cracks.
how many miles and have you had any work done recently?
will
willyok is offline
post #4 of 43 Old 01-01-2014, 06:17 PM Thread Starter
brewcider
tighten up the nut holding on the steel fuel line? I can try that. That sounds safer than replacing the copper washer and having to remove the injector. If the black rubber line is in the way, how can i remove it? It seems to swivel. I think it might snap on and off with a ball socket.
I have 90k miles on the Jeep. I've only had oil changes done recently and I replaced glow plug #6 which is on the other side of the engine.
post #5 of 43 Old 01-02-2014, 07:59 AM
GDE
2005 KJ Liberty
The leak seems to be from the steel fuel line to injector. Tightening the nut should fix it. If not, it can help to loosen the other end of the steel fuel line and then finger tightening both ends while wigging the the fuel line a bit to help seat both ends. Then torque the nuts.
The plastic parts are not very forgiving on the injector
GDE is offline
post #6 of 43 Old 01-04-2014, 12:42 AM Thread Starter
brewcider
Either I fixed the leak and created a new one, or it was the O-Ring clip on the fuel return line the whole time. I broke the O-ring the spins around on the fuel return line. I read on the Sprinter forum that you press down hard on it and it'll snap and release the line. However it just snapped in half. I'm trying to find a part number for it but it looks like I need to replace the entire return fuel line now! Help?
post #7 of 43 Old 01-04-2014, 01:54 AM Thread Starter
brewcider
This might be what I need.... I wish there was a part number
http://europarts-sd.com/item.asp?PID=2197
post #8 of 43 Old 01-04-2014, 06:55 AM
Drudgery1971
2007 WK
Check this out. Havent read through it yet but appears to be same/similar topic.
http://www.jeepforum.com/forum/f67/c...ailure-801269/
2007 WK Limited 3.0 CRD - Stock (Mine)
2010 XK Sport 5.7 Hemi - Stock (Wife)
Drudgery1971 is offline
post #9 of 43 Old 01-04-2014, 07:07 AM
Drudgery1971
2007 WK
This may help as well. Check product fit, etc but it's tracked down through merlintec's original post back in 09.
http://www.factorychryslerparts.com/...ssembly=707957
post #10 of 43 Old 01-04-2014, 11:58 AM Thread Starter
brewcider
Thanks I read those threads previously. They point to replacing the entire $130 fuel line, when all I need is the O Ring. I'm trying to find a parts diagram for Mercedes, I may be able to get the $4 clip seperately from Mercedes since it looks like Europarts stocks it, I just don't know the part number.
post #11 of 43 Old 01-04-2014, 09:16 PM
Drudgery1971
2007 WK
I don't think there is a part number as I believe I read its all one unit?
post #12 of 43 Old 01-05-2014, 12:28 AM Thread Starter
brewcider
I'm crossing my fingers it's 68005720AA and only $4. I found the part on the Sprinter parts page...
http://www.ourexcellentadventures.co...interParts.pdf
If it's not the right part I'm only out $4.
post #13 of 43 Old 01-12-2014, 03:42 AM Thread Starter
brewcider
I finally fixed the problem. The o ring holding the leak line onto the injector was the cause of the leak. You cannot buy a new o ring. You need to replace the entire leak line, and its $150 online, or $250 at the dealer. I didn't want to spend that so I went to autozone and bought a piece of 3/8" ID fuel tubing and 2 hose clamps. I cut a 1 inch piece of fuel tubing and slid it over the plastic piece that connects to the injector and clamped it down on the top and bottom of the fuel tubing. No leaks! $4 fix where if I let the dealer do it I would have paid probably $800 for parts and labor.
post #14 of 43 Old 01-12-2014, 09:16 AM Thread Starter
brewcider
here's a picture of the $4 fix I did. It's way cheaper than buying a whole new leak line.
post #15 of 43 Old 01-12-2014, 12:25 PM
suzieque
2008 WK
Thanks for posting your fix it may help someone else.
2008 WK "S" Limited bright metallic silver exterior, light graystone interior, 5 speed W5J400 transmission, June 18/2008 build, C213RE rear differential with 3.73 axle ratio, C200FE front differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, GT2056V turbo, 3.0L CRD (OM642.980)
suzieque is offline
crd , diesel , fuel , injector , leak
