Launch / Neutral drop - JeepForum.com
post #1 of 20 Old 04-07-2011, 10:30 AM Thread Starter
08Hemiwk
So i was messing around in my WK Hemi today and found that if i rev the engine in neutral she only gets to 4k which i found odd (I come from manual cars, this and my ZJ are my only autos). I dropped her into drive and just about snapped my neck, four wheel drive burnout and all. Is this something that should generally be done? My instinct is no, but I know very little about this truck so for all I know the drivetrain is strong as all hell.
My ZJ doesnt even shift if i try that, stays in neutral til i let it back under 1500rpm.
08Hemiwk is offline
post #2 of 20 Old 04-07-2011, 10:46 AM
Craft95ZJ
1986 MJ Comanche
I couldn't tell you how many drive shafts I've twisted/broken u joints due to doing this stunt. Its fun and all but don't make a habit of doing so.
Daily driver '01 TJ 3" RC lift
'86 MJ 3.4L interior rebuild in progress.
Craft95ZJ is offline
post #3 of 20 Old 04-07-2011, 11:32 AM
scotro95
2005 WK
Yea I did it the other day too, she launched hard but now my trans is acting a little funny, you can really hear it engaging, so save yourself the thousands of dollars and drive it the way it's supposed too.
scotro95 is offline
post #4 of 20 Old 04-07-2011, 12:30 PM
meep
2008 WK
it is common for ecu's to limit unloaded rpms to below redline. it actually puts more tension (pulling, not pressure) on the conrods with no load because there's no pressure on top of the pistons.
When you take a spinning engine, a 30+lb TC (with fluid) and drop it into gear, something has to give. It's hard on a driveline.
I had a weird experience the other day-- I snap-stomped the throttle to pull out from a standstill. It actually immediately snicked into 2nd until I was rolling maybe 5-7 mph and THEN dropped to 1st -- then back to 2nd as expected. torque management? My 2wd 3.7 WILL scuff my oversized REVOs at launch.
I've never really snap-stomped it. Usually press into it (easier on the driveline). I can only guess it was programming to prevent overtorque.
meep is offline
post #5 of 20 Old 04-07-2011, 12:34 PM
BonesWK
2006 WK
neutral drop
Ryan
2006 Black WK Limited 4.7 4x4 QD II SOLD
Current - 2008.5 Mazdaspeed 3
If you want to achieve greatness, stop asking for permission
BonesWK is offline
post #6 of 20 Old 04-07-2011, 12:55 PM
overboostin
2008 WK
^lol
When I'm racin I make sure to neutral drop it, then start in L, then go 2, 3 and drive. That way, its kinda like I have a manual. Adds like 15hp that way.
08 : Hemi : Overland : OME : Rancho : 33" MTR : Thule : SUV Racks : 6" Offroad Lights : D Ring Shackle : Hi Lift
Don't Tread On Me
overboostin is offline
post #7 of 20 Old 04-07-2011, 05:05 PM
90grandoneer
90grandoneer's Avatar
2006 WK
I believe the out of gear rev limit is 3000 RPM. With the DS tuner you can raise it. I have mine set at 4000 RPM. What everyone else says about being hard on the drivetrain, too.
06 GCO, Dk Khaki, QDII, Flshing Hi 3rd Bk Lt, MDS "ON" Lt, Airtab Vortex Gens, Debadged, Fumoto Drain Valve, BT Catch Can, Chopped EGR Tube, SRT8 CAI, K&N Filter, Sonnax Trans Line Press Booster, SC Tuner W/Adv Trans Tune App, DS Tuner, Cust tubular hdrs w/3 in Magnaflow/Xlerator AP Exh Sys, Bilsteins, SRT Springs/Sways, Cust Eng Cvr, SRT8 frt/rear bumpers, FRI Sidewinder Cam/6.1 valvetrain, SLP 25% UD Pulley, BBK true 90mm T-Body, SOS Ign Coils w/.060 spark plug gaps, SRT Reps with 265/45&295/40X20's.
90grandoneer is offline
post #8 of 20 Old 04-07-2011, 07:08 PM
Smokey28173
2007 WK
neutral dropping is seriously hard on the engine like meep said something has to give and if you do that too often you are gonna find out whats stronger the tranny or the engine
'07 Jeep Grand Cherokee WK. Laredo. Silver. 3.7L. Interstate 790 CCA Battery Class lll Towing | | Jeeps are Sexy Member #2. | XK/WK Owners Club Member #12. |
Smokey28173 is offline
post #9 of 20 Old 04-07-2011, 07:25 PM
kkuty
2011 WK
I vote engine.
kkuty is offline
post #10 of 20 Old 04-07-2011, 07:32 PM
Smokey28173
2007 WK
probally the transmission engines are typically built pretty rough and tough. transmissions ........ not so much
post #11 of 20 Old 04-07-2011, 09:16 PM
DAHEMI
2005 WK
this is abuse you don't want to subject your vehicle nor your wallet to! good luck!
2005 WK GC LTD 5.7L Hemi QD II 4WD Midnight Blue Pearl 33k
Blue WK Club Member #1
my poor signature is thrashed so deleted it
The Second Amendment - America's Original Homeland Security
DAHEMI is offline
post #12 of 20 Old 04-07-2011, 09:18 PM
theskier74
Originally Posted by BonesWK View Post
neutral drop
my thoughts exactly
My Jeep uses the gas your hybrid saves.
Anything your car can do, our Jeeps can do better.
200k+
theskier74 is offline
post #13 of 20 Old 04-07-2011, 09:24 PM
sal-XK
2007 XK Commander
Oh my god this conversation is not happening. Neutral drop a trans is probably one of the worst things you can do. It doesn't surprise me anyone would have trans issues after that kind of stunt and If you don't have issues you will or at least took years off the life of your trans. Your engine can take it but everything else is crying underneath your Jeep. You would be lucky to just throw a shaft or a U-joint. You're lucky your trans didn't throw parts all over the street which I have seen done.
sal-XK is offline
post #14 of 20 Old 04-07-2011, 10:12 PM
tjkj2002
2002 KJ Liberty
If you want to launch hard like that install a trans brake and save thousands of $$$'s in broken parts.Just make sure you add a monster trans cooler with it's own dedicated fan.
tjkj2002 is offline
post #15 of 20 Old 05-26-2014, 05:50 PM
Jeep4tw
I have a 99 jeep xj and I drop from N to 1/2 and manually shift up when racing every weekend for the past 3 years and nothing has happened, not a single noise or shifting problems. I usually rev up to 2800 max because it is quite hard on the transmission, just make sure to install some sort of aftermarket trans cooler because heat is not a good thing for the transmission.
Jeep4tw is offline
5.2 revving while in neutral? snakester14 ZJ Grand Cherokee Forum 6 03-12-2010 12:53 AM
Neutral Safety? 321lifeisgood ZJ Grand Cherokee Forum 0 02-28-2010 01:27 PM
First Towing/boat launch experience in the Jeep comishcraig ZJ Grand Cherokee Forum 31 11-14-2008 09:38 PM
Neutral on the 242 adgjqetuo ZJ Grand Cherokee Forum 3 09-02-2005 09:18 AM
neutral switch lazaru2 ZJ Grand Cherokee Forum 1 09-08-2004 11:01 PM
