Largest size Spare? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Largest size Spare?
Artec JK Under Armor BellypanEngo winches available at www.rockridge4wd.com! Free shippG2 Disc Brake Conversion Kit for Jeep Wrangler YJ TJ LJ Ch
Unread 11-24-2013, 07:40 PM   #1
WKCRD757
2008 WK
Largest size Spare?
What is that largest size tire that can fit in the spare tire area?
I don't want to carry a wheel on my roof when I head out into the middle of nowhere and it doesn't look like there are any options for a good spare carrier/rear bumper setup... so i'm left with the spare well. Am I missing any other setups? Inside isn't an option.
Jeff
2008 Grand Cherokee Diesel - DPF Delete - GDE Eco Tune
WKCRD757 is offline   Reply With Quote
Unread 11-25-2013, 08:36 AM   #2
sebastien
2006 WK
a 265/70 will fit if you trim the bolts and hitch down with an angle grinder. A larger tire can fit if you take out the hitch and replace the welded nuts with carriage bolts and nuts on the outside of it..
http://www.blacksheep4x4s.org/
sebastien is offline   Reply With Quote
Unread 11-25-2013, 10:51 AM   #3
WKCRD757
2008 WK
Definitely have to keep the hitch mounted. Thanks Sebastien.
Unread 11-25-2013, 11:13 AM   #4
Moose25
2008 WK
I have a 285/70 mud terrains and I couldnt get mine in. I dont have a tow hitch and i even took the exhaust heat shiled off.
[CENTER][FONT="Fixedsys"][COLOR="Silver"]2008 3.7 SILVER LAREDO[/COLOR][/FONT][/CENTER]
[CENTER][FONT="Arial Narrow"][COLOR="Black"]OME HD : BFG MUD TERRAIN KM2's 285/70/17 : JK AEV PINTLERS 17" : K&N FIPK : MAGNAFLOW MUFFLER : AIRAID TBS: PW / RF MOD: HYPERTECH PROGRAMMED: THULE MOAB/SNOWBOARD/BIKE RACK[/COLOR][/FONT][/CENTER][LEFT][FONT="Showcard Gothic"][I]
[SIZE="1"][COLOR="Black"]snowboard.dirt bike.wakeboard.backpack.hike.4x4.mountain bike.
ITS A JEEP THING[/COLOR][/SIZE][/I][/FONT][/LEFT][CENTER][SIZE="2"][B][FONT="Courier New"][COLOR="Silver"]SEMPER FIDELIS[/COLOR][/FONT] [/B][/SIZE][/CENTER]
Moose25 is offline   Reply With Quote
Unread 11-25-2013, 11:28 AM   #5
Jeepforthewin
Lucky Charms!
Jeepforthewin's Avatar
2005 WK
A 265/70 is the biggest i believe you can fit and most people still have to air the spare down.
2010 JKU - Stock for now
2005 WK - 6" lift, 35" BFG's, a lot more (SOLD)
Jeepforthewin is offline   Reply With Quote
Unread 11-25-2013, 12:12 PM   #6
WKCRD757
2008 WK
I wanted to run 255 75 17 on my Jeep but the options are so limited in that size and now because of this issue, it looks like 265 70's are a better bet.
Unread 11-25-2013, 08:50 PM   #7
sebastien
2006 WK
Don't take the hitch out, homie. The 4 nuts that are on the inside of the hitch (towards engine), grind those off, replace with carriage bolt. Use a nut on outside....It is in omelets build thread somewhere
Here is the link > http://www.jeepforum.com/forum/f67/o...l#post12793004
Unread 11-25-2013, 10:00 PM   #8
blizzboy283
2005 WK
You can definitely fit that size spare in if you air down and do the hitch mod, mentioned.
05 WK LTD 5.7L Hemi QD II Midnight Blue Pearl, Blue WK Club member #30
Intune, AFE Stage 2 CAI, BT Catch Can, Gibson Cat-back, OME HD, 255/75/17 BFG KM1s, 1.25" Spidertrax, LED Interior, Reverse & Tail Lights, 3/4" Grille, Chrome Fuel Door & handles, SRT8 Pedals, Taylor Shorties, XK knob, 4xGuard Front 4 & Rear Diff.
blizzboy283 is offline   Reply With Quote
Unread 11-25-2013, 10:42 PM   #9
WKCRD757
2008 WK
awesome, thanks!
Unread 11-27-2013, 01:10 PM   #10
R4TCHET
2005 WK
Look up the knuckle bone rear tire carrier, Its made by detours USA. It's a hitch mount tire carrier that angles up just as it comes out of the hitch so it doesn't decrease your departure angle. It is what I will eventually be getting
Sent from my Jailbroken iPhone using JeepForum
| (dark)KHAKI WK CLUB MEMBER 17 | 2005 4.7L QTII | JBA UCAs | Modified OME MD 3.5" lift | Rusty's Adj. track bar | 4XG Matrix | 285/70r17 Duratracs | 17" KMC Enduro Wheels | Rola Roof Rack | 21" Bean LED Light bar on Roof Rack | 2 12" Punch P3 Subs | Expanded Sheet Grille | SA Sliders |
R4TCHET is offline   Reply With Quote
Unread 11-27-2013, 01:41 PM   #11
WKCRD757
2008 WK
I've seen those before, I need my trailer hitch though.
Unread 11-27-2013, 01:48 PM   #12
Jeepforthewin
Lucky Charms!
2005 WK
Just get a Rola Rack and put your spare up there. I have had my 265/70 up there for about 6 months now and no my MPG hasn't suffered at all.
Unread 11-27-2013, 03:05 PM   #13
WKCRD757
2008 WK
We're going to need the space available on the roof for other things so the tire size limit has to fit in the wheel well it looks like. The ideal goal will be 255 75 17s but after looking at tire availability, there really aren't any decent all terrain tires available in that size so 265 70 17 may be the ticket.
Unread 11-28-2013, 12:21 PM   #14
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Yep, after modifying the hitch a 255/75R17 will fit deflated and a 265/70R17 will fit inflated.
See How It Was Made
Omelet is offline   Reply With Quote
