KYB vs Bilstein shocks - Page 3 - JeepForum.com
post #31 of 44 Old 02-29-2012, 05:46 AM Thread Starter
IndyBlueWK
2005 WK
Correct!
IndyBlueWK is offline
post #32 of 44 Old 03-02-2012, 12:02 AM
Piepenbrok420
Originally Posted by Tamerin
Kinda confused, new to Jeeps so don't mind me when I ask this question:
Why is it that some people say Struts? And some call them Shocks? Doesn't the jeep have both, right?
Yea the design of the shock on the front is called a strut, it comprises of a spring and a shock together. (used on IFS vehicles now-a-days).
The rear is a solid axle using a coil spring so it uses a traditional shock absorber.
Built Not Bought. 2013 JK trailrig. Instagram: @chrispiepenbrok
Piepenbrok420 is offline
post #33 of 44 Old 03-02-2012, 09:53 AM Thread Starter
IndyBlueWK
2005 WK
the engineers at work call em dampers.... ugh.. always corrercting me
post #34 of 44 Old 03-05-2012, 10:40 PM
juanjaimeiii
Originally Posted by Kolak View Post
The KYB is a low pressure twin tube shock with velocity sensitive valving - much the same as your stock shocks in terms of technology.
The Bilstein is a high pressure monotube design with a digressive self-adjusting valving setup.
Bilsteins will outperform the KYB by quite a wide margin. You'll get more rapid responsiveness, far better fade resistance and improved ride control and handling.
Do you sell the Bilsteins? If not where here in the Phoenix area can I get some?
juanjaimeiii is offline
post #35 of 44 Old 03-05-2012, 10:42 PM
JRLT
2010 WK
He's the man, send Kolak a PM with your info & e-mail address.
2010 3.7L, 4XGuard Matrix, Fastman TB, TB Ground Mod, Injen CAI, 255/60/18 Nitto Terra Grapplers, Bilstein Shocks & Struts, Cruiser Alloy Wheels - Switchblade, Stillen Brakes, Cargo Light Strip Mod, Electric Ashtray Mod, Jet-powered, Monkey Navigated...
JRLT is offline
post #36 of 44 Old 06-18-2013, 08:20 AM Thread Starter
IndyBlueWK
2005 WK
So far ive got 35,000+ miles on my 5100's and love them!
post #37 of 44 Old 06-18-2013, 09:50 AM
tjkj2002
2002 KJ Liberty
The WK uses a fron "Coilover" design,a shock with a coil surronding it.
Easy way to tell between a "Strut" and "Coilover" on a IFS(and/or IRS) vehicle is if you have a upper control arm you have a coilover,no upper control arm you have a strut.Struts take place of a upper control arm to place the top of the knuckle.
tjkj2002 is offline
post #38 of 44 Old 06-18-2013, 11:25 AM
bigpav7
So when you guys upgrade the shocks/struts, are you replacing just the rear or both front and back? Anyone know the part #s for 2010 commander want to put on bilsteins.
bigpav7 is offline
post #39 of 44 Old 06-18-2013, 11:50 AM
JRLT
2010 WK
Rears can be done in your driveway with the tire jack in 30 min or less. I took mine in to the local mechanic to do the fronts since I dont have the tools.
JRLT is offline
post #40 of 44 Old 06-19-2013, 08:00 AM
Zlartibartfast
2007 WK
I put Bilsteins on all 4 at once (not myself - no space to do that work) and the Jeep came alive! You can't go wrong - and Kolak is the best source to buy them from
Zlartibartfast is offline
post #41 of 44 Old 01-09-2016, 10:28 AM
LifeOnABoard
2008 WK
My wife's 08 is at 100k miles and I'd like to do a suspension/brake refresh + GDE ECO tune. Just looking for more pep and a smoother ride. I plan to keep the stock springs and was wondering if the 4600 Bilsteins would be a better choice vs. the KYB GR-2's. She doesn't off road but does drive it very sporty like it's a Cayenne. I don't want to get under the car for another 100k miles.....
what do you guys think?
LifeOnABoard is offline
post #42 of 44 Old 01-09-2016, 10:51 AM
LouC
2007 WK
I don't know about KYBs but I have had the Bilstein 4600 HDs on our '98 ZJ for about 120,000 miles and they are still good. I installed them in May of 2002! I think for a WK, if you want to keep the stock rake then go with the 4600. The 5100 on the lowest setting (3/4" lift) will eliminate that rake and it will appear level. It depends on what you want. The ride of both is about the same.
OME is a different design shock, probably a bit better off road as its not as stiff and due to the twin tube design has a bit more travel than the Bilstein monotube design. They do cost more, close to 25/30 bucks more in the sizes we checked.
2017 JK Unlimited Sport 6 spd
2007 WK Limited Hemi QDII
1998 ZJ Laredo 4.0 Selectrac
LouC is offline
post #43 of 44 Old 01-09-2016, 11:12 PM
Kolak
Vendor
Kolak's Avatar
The Bilsteins are a high pressure monotube design and will offer ride control, responsiveness and fade resistance vs a low pressure twin tube design such as the KYB. You'll be very impressed with either the 4600 series or the 5100 series. Both are valved the same but the 5100 series has adjustable front struts to level/lift the Jeep.
PM me if you'd like pricing or just more information
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
or
Kolak is online now
post #44 of 44 Old 01-10-2016, 05:30 PM
LifeOnABoard
2008 WK
Thanks for the feedback. I was worried that they would raise the car but it sounds like they won't. But still curious to hear from someone who has them on their original springs.
Ome Shocks Or Bilstein f-250ford WK Grand Cherokee & XK Commander Forum 8 08-09-2010 09:08 PM
Bilstein Shocks micallef WK Grand Cherokee & XK Commander Forum 7 11-19-2008 08:30 PM
Bilstein shocks zaq123 ZJ Grand Cherokee Forum 11 04-06-2005 04:53 PM
Bilstein Shocks maxpsi ZJ Grand Cherokee Forum 6 07-01-2004 04:12 PM
Bilstein shocks NuTone ZJ Grand Cherokee Forum 3 06-05-2004 09:16 AM
