KYB vs Bilstein shocks - JeepForum.com
post #1 of 44 Old 02-23-2012, 10:33 AM Thread Starter
IndyBlueWK
2005 WK
Ive heard really good things about KYB's and the Bilsteins, the KYB's are much cheaper but I hear they make a good shock. Does anyone know the length of both of them for a stock Wk with the Hemi?
KYB part number KYB 344496 GR-2 Shock
Bilstein Shock 24-186803
IndyBlueWK is offline
post #2 of 44 Old 02-23-2012, 11:55 AM
Kolak
Vendor
Kolak's Avatar
The KYB is a low pressure twin tube shock with velocity sensitive valving - much the same as your stock shocks in terms of technology.
The Bilstein is a high pressure monotube design with a digressive self-adjusting valving setup.
Bilsteins will outperform the KYB by quite a wide margin. You'll get more rapid responsiveness, far better fade resistance and improved ride control and handling.
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
or
Kolak is offline
post #3 of 44 Old 02-23-2012, 12:17 PM Thread Starter
IndyBlueWK
2005 WK
How does this compare to the monroe part number 911278 or ORV Suspension 18465.05 shock?
post #4 of 44 Old 02-23-2012, 01:11 PM
Kolak
Vendor
Kolak's Avatar
Both of those are twin tube low pressure shocks, like the KYB or your stock shocks.
or
Kolak is offline
post #5 of 44 Old 02-23-2012, 01:39 PM Thread Starter
IndyBlueWK
2005 WK
Does the length of the shock have anything to do with the fact that I am adding a 2" Lift to the jeep? From what I have found at the moment the Bilstein shock 24-186803 has the third shortest length of (24.33 in) all the shocks I've looked at.. My jeep won’t see a lot of time off road so I really all I need is something longer than the OE shock right?
All of these were looked up for a stock fitment..
Brand -----------------(Fully extended length) #part number
Gabriel ultra------------------ (24.11 in) #G64012
Monroe Truck/SUV shock--- (24.25 in) #911278
Bilstein------------------------- (24.33 in) #24-186803
KYB shock--------------------- (24.41 in) #344496
Monroe load leveler shock- (24.87 in) #58646
Monroe Standard------------ (24.88 in) #32407
post #6 of 44 Old 02-23-2012, 02:20 PM
Kolak
Vendor
Kolak's Avatar
The Bilsteins work fine with a 2" BB.
Measurements of struts vary from manufacturer to manufacturer depending on what points they choose to take the measurements.
or
Kolak is offline
post #7 of 44 Old 02-23-2012, 02:29 PM Thread Starter
IndyBlueWK
2005 WK
The old man Emu N190 is 25.9 inches fully extended and 15.5 fully compressed.....
post #8 of 44 Old 02-23-2012, 05:03 PM
Kolak
Vendor
Kolak's Avatar
Yes - that's the shock that's used with their lift kits. They're expensive - more than the Bilsteins. They are a low pressure shock, but they are very heavy duty. So more travel with the OME shocks, better handling with the Bilsteins. More expensive for the OME shocks, less for the Bilsteins. Tough call.
or
Kolak is offline
post #9 of 44 Old 02-23-2012, 05:22 PM
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
This is why I skipped the shenanigans and went with FOX!
Omelet is offline
post #10 of 44 Old 02-23-2012, 09:15 PM
Piepenbrok420
You have to consider that a monotube set of shocks/struts (like bilsteins) are going to have atleast 100 psi each of upward force on your vehicle over a standard dual-tube.
Built Not Bought. 2013 JK trailrig. Instagram: @chrispiepenbrok
Piepenbrok420 is offline
post #11 of 44 Old 02-23-2012, 11:51 PM
TurboDiesel
2008 WK
I love those fox shocks
The twin tube looks sick, that's what I want
Mainly for looks LOL the performance is nice too I guess
Is the twin tube that much better than single?
What's it help with?
2008 CRD // GDE Eco // DPF delete // 3" intercooler // OME HD // 265 dirtytracs etc.
TurboDiesel is offline
post #12 of 44 Old 02-24-2012, 05:31 AM Thread Starter
IndyBlueWK
2005 WK
Do they make fox shocks for an almost stock height WK or one with a 2" lift?
post #13 of 44 Old 02-24-2012, 06:50 AM
yetti182
2007 WK
I'm gonna have to work an ot shift this week so I can order bilsteins.
07 Black Jeep WK Rky Mtn Edt. 3.7L
2" RC Lift/1.5" RC Spacers
265/70/17 Nitto Terra Grapplers
yetti182 is offline
post #14 of 44 Old 02-24-2012, 07:03 AM Thread Starter
IndyBlueWK
2005 WK
Its not the price that bothers be I just want to make sure that there the best thing to get for my application.
post #15 of 44 Old 02-24-2012, 11:02 AM
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
It depends on your use. The other tube is a remote reservoir. This allows the shock to hold more oil than a non res shock. These are really only needed when you will be excessively exercising your suspension. When the shock is worked hard it heats up and will start to feel soft. The res gives the shock greater oil capacity and a place for the fluid to expand. I am not a shock expert and there is a lot of technology that goes into these thing that I can't explain It would be better for you to go to Fox and read about it, but that is the basic info. When I had my OME shock I felt a difference between the way they acted at the beginning of a trail and then later on once they were hot. That's just one reason I went with these.
I have the 11" travel version, but they make a lot of different sizes. The 10" is probably what you would want for a 2" lift.
Omelet is offline
Ome Shocks Or Bilstein f-250ford WK Grand Cherokee & XK Commander Forum 8 08-09-2010 09:08 PM
Bilstein Shocks micallef WK Grand Cherokee & XK Commander Forum 7 11-19-2008 08:30 PM
Bilstein shocks zaq123 ZJ Grand Cherokee Forum 11 04-06-2005 04:53 PM
Bilstein Shocks maxpsi ZJ Grand Cherokee Forum 6 07-01-2004 04:12 PM
Bilstein shocks NuTone ZJ Grand Cherokee Forum 3 06-05-2004 09:16 AM
