Kick in da Pants for an '09 3.7L 2WD! - JeepForum.com
post #1 of 3 Old 10-09-2012, 10:56 AM Thread Starter
infinitempg
2009 XJ Cherokee
Been diggin' around and getting mixed messages so thought I'd just cut to the chase and pull all the strings together. Got a low mileage clean 2009 Jeep Grand Cherokee Laredo 3.7L 2WD and really like it except for the somewhat flat performance, lax acceleration at times, quirky idle (sometimes RPM drops like a rock when idle for a while) and less then stellar gas mileage. Been burning up the web and found a lot of confusing stuff....
Heard that mod chips like the Jet 90901 or Hypertech 52501, will increase performance, good changes to tranny shift points, response and gas mileage. Then I find first hand users saying that it didn't do squat or very little, or horror stories of creating engine knocks, transmission shifting issues, and other issues that don't go away when it's removed.
Then stumbled across the cold air intake kits that increase horsepower and gas mileage. Then I dig deeper and find that mileage and performance improvements are minimal, the filters clog quick or don't filter well and debris gets sucked in screwing stuff up, or requires cutting and altering things under the hood to truly get cold air intake.
So the question is, is there really anything that can be done to help improve performance and gas mileage with the stock 3.7L 2WD without risking major mechanical issues???
Any and all opinions, suggestions and advice gladly welcome
infinitempg is offline
post #2 of 3 Old 10-09-2012, 11:08 AM
oducks12
2005 WK
I have the Hypertech programmer and havent had a single problem. I'd say it is definitely the best bang for the buck. You can also put headers on it, a full exhaust system, re-gear for better acceleration...it all depends on how much $$ you want to put in it.
2005 WK Laredo - SOLD
2015 WK2 Limited
oducks12 is offline
post #3 of 3 Old 10-09-2012, 11:41 AM Thread Starter
infinitempg
2009 XJ Cherokee
Do you have the 52501? How difficult was it to install and setup? How much improvement did you see to tranny shifting, response and mileage? Hate to pry but.... well, no I don't
Not running down the headers/exhaust street, last time I did that was on a 350 small block and the only you could call "electronics" in that beast was an 8-track
2wd , 3.7l , improve , performance
