Key Fob Questions - JeepForum.com
post #1 of 19 Old 06-08-2013, 05:53 AM Thread Starter
Jake00
Key Fob Questions
Hey guys, this might be my first post in the WK section. My wife drives our 09 Overland and her key fob buttons stopped working so she switched with me. I changed the battery and the buttons still won't work. I thought I saw a post about getting replacement fobs on here cheap but can't seem to find it. The chip in the fob still lets the car start so I believe I can still program a new one. Where is a good source to get replacement fobs and how much should it run me?
Jake00 is offline
post #2 of 19 Old 06-08-2013, 06:44 AM
gamma500
2015 WK
Jake,
I did a Forum Search with "key Fob" and there are quite a few postings which will point you towards a new source...there is an inexpensive one on eBay you can put your chip in. I didn't post any links from the Search since there are a ton you probably want to peruse...
gamma500 is offline
post #3 of 19 Old 06-08-2013, 07:47 AM
fordt
2008 WK
I bought an 08 CRD Overland recently with only one remote, bought a couple off EBay from vendor "yourkeylessremote", sells them for $44 each with free shipping. Definitely cheaper than the dealer, and supposedly if you have two working remotes, you can program a third yourself (but that won't help ya)...the dealer charge is high-$100 or so to program. If you know anyone at any dealership, the job can be done with a scanner. That's what I did, he had me park outside the fence but still in range of the wireless scanner-snuck out on his lunch hour to do it!
2008 Grand Cherokee CRD Overland 2WD, GDE Eco tune with DPF delete, MBRP DPF back exhaust system
fordt is offline
post #4 of 19 Old 06-08-2013, 08:48 AM
colinzj
2006 WK
Nah, it'll work. All it needs to do is identify itself to the vehicle when it's in the ignition, which it's still doing if he can still start the vehicle with it.
2006 WK Laredo 4x4 4.7L
1993 ZJ Laredo 4x4 4.0L Dead, sold, and rolling again
colinzj is offline
post #5 of 19 Old 06-08-2013, 11:47 AM
Shafer57
2006 WK
You need two keys that start the vehicle in order to enroll a third doing on-board programming (See owners manual). If you only have one working key that does this, call your local locksmith first and skip the dealer. Most locksmiths can do all of this for you much cheaper than a dealer. Including hooking the truck up to a computer and manually enrolling keys into the memory.
Hopefully this helps, any questions just ask, i'm a locksmith and do this daily
Also confirm that the cradle that holds the batteries in place is secured to the circuit board properly.
Dodge Dakota R/T 360ci Small-block _sold_
Jeep GC 5.7L Hemi- Magnaflow Cat-Back, BT Catch Can, 20" Gloss black SRT Reps
275/45R20 Nexen Roadian, Blacked out, 180 Stat _SOLD_
2008 335i Twin-Turbo
Shafer57 is offline
post #6 of 19 Old 06-09-2013, 02:07 PM Thread Starter
Jake00
I just read your post about everything you need to know and I'm convinced its the battery contacts that are the problem. I also have learned this is the fobik key and its pretty tough to get a soldering iron in there, unless its ok to split the case instead of taking the battery cover off? Is there a good chance I'll mess up the transponder chip?
Thanks to everyone else that chimed in.
Jake00 is offline
post #7 of 19 Old 06-09-2013, 04:52 PM
Shafer57
2006 WK
Splitting the case open on a FOBIK can be tricky. Some locksmiths, or even car security/audio places will actually repair those annoying small solder connections. On the older style like the key in my thread, you can actually electric tape the battery, and cradle down to the circuit board and re-assemble the whole thing and testing again. Which might not be possible on the FOBIK
Here's a video on splitting the case.
Shafer57 is offline
post #8 of 19 Old 06-09-2013, 06:42 PM Thread Starter
Jake00
Thanks for the link. I just ordered a new FOBIK for $45. Once that's programmed and working I may try to split the case and repair it to have a third remote laying around for a spare.
Jake00 is offline
post #9 of 19 Old 06-09-2013, 06:56 PM
Shafer57
2006 WK
Sweet, don't forget to run to a locksmith or somewhere to have the key insert (in the FOBIK Fob) cut from your current one.
Shafer57 is offline
post #10 of 19 Old 06-10-2013, 07:14 AM Thread Starter
Jake00
Thanks!
Jake00 is offline
post #11 of 19 Old 06-11-2013, 06:25 PM
jediknight
2008 WK
Is it possible to program 3 key fob or skim module allows only for two ?
2008 WK CRD Blue, QD II, Startech SD6 mod.
jediknight is online now
post #12 of 19 Old 06-11-2013, 07:17 PM
Shafer57
2006 WK
I'd have to double check, but the memory in the immo. should be able to hold up to 8 keys. If that is your question.
Shafer57 is offline
post #13 of 19 Old 06-12-2013, 08:07 PM
jediknight
2008 WK
I have a third key from a another jeep (same plateform type) here that I'd like to program. Do we have to delete all the keys from the immo through starmobile before registering this key or we should be able to add it without deleting the others ? This third key is already programed from an other accidented jeep and i'd like to reuse it.
post #14 of 19 Old 06-13-2013, 12:48 PM
colinzj
2006 WK
Keys are not reusable.
colinzj is offline
post #15 of 19 Old 06-13-2013, 02:07 PM
jediknight
2008 WK
So they have to be brand new in order to program them ?
