Keeslinger31's build thread - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Keeslinger31's build thread
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 08-27-2013, 07:43 PM   #1
Keeslinger31
2005 WK
Starting with this
05 Black/Grey limited Hemi nav 2 inch lift 255/70/17 general grabbers at2's
Then I clayed polished and waxed it and a few personal touches
As of now
05 Hemi ome hd/spacers 265/70 Geolandar
winch HLM aspen creek grille defaced wheels
Black WK #126
Keeslinger31 is offline   Reply With Quote Quick reply to this message
Unread 08-27-2013, 08:01 PM   #2
Clirry
2014 WK
Just beautiful start!
Clirry is offline   Reply With Quote Quick reply to this message
Unread 08-27-2013, 08:34 PM   #3
Anon155
2005 WK
Welcome to the forum neighbor! Good to see another lifted WK in KC, there's only a few of us out there. Looks like your off to a great start. I like the idea of painting the wheels charcoal. I've heard its not easy getting that coating off the wheels though. I'd probably just plasti dip them or try to sand them down with a decent grit and paint over it.
05 Jeep Grand Cherokee: ORT 4X4; Khaki #55
Too many mod's to list...
Anon155 is offline   Reply With Quote Quick reply to this message
Unread 08-27-2013, 09:09 PM   #4
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
^^^ x2
Just some food for thought - the 4xG front skid is gonna set you back some bills - bills that would be better spent on the belly skid.
I would definitely be up for a KC WK day of wheelin sometime.
BTW - I like the attention to preventative maintenance right outta the gate.
Smart move.
~Mike~
Build Thread WK
Other Build Thread XJ
September 2013/January 2015 COTM
JeepN4KC is offline   Reply With Quote Quick reply to this message
Unread 08-27-2013, 09:43 PM   #5
Keeslinger31
2005 WK
Thanks guys! Where is there to wheel around here? Id be interested to see what this thing can do.
I was happy to see these when I looked under it
It's nice to see some wks in kc that aren't grocery getters !
Black WK #126
Unread 08-27-2013, 09:59 PM   #6
816jared
2005 WK
I'd be down for that as well. My rig is still a pretty big work in progress, but would definitely be fun to meet everybody.
816jared is offline   Reply With Quote Quick reply to this message
Unread 08-27-2013, 10:04 PM   #7
Keeslinger31
2005 WK
thats 4
Black WK #126
Unread 08-27-2013, 10:05 PM   #8
JeepN4KC
JeepN4KC's Avatar
@ Keeslinger: See there.........put a 4xG belly skid in that mix and you've got solid protection underneath. Add to that a stronger aftermarket rear diff cover/guard and you're good to go.
There are few that are great places to wheel:
SMORR - just outside Springfield
Tuttle Creek - just north of Manhattan
Kansas Rocks - south of town in Mapleton, KS
There's a couple others if you are interested look into KCJeepClub.org or the Northlanders Jeep group on FB
~Mike~
Build Thread WK
Unread 08-27-2013, 10:10 PM   #9
Anon155
2005 WK
Yeah, I would say your ball joints are pretty much shot . I would consider getting a set of moog adjustable ball joints instead of replacing the whole upper control arms. Save the cash for other mods. Unless you plan to wheel the crap out of your rig. Other than some minor surface rust, they still look to be in decent shape to me.
The 4xguard belly skid goes in the middle of your front skid and transfer case skid. It covers up your transmission pan and catalytic converters but not your muffler unfortunately. I'd call them before ordering, make sure they have the new wings made. I was the first HEMI to get their newest design (#5). They mocked it up on a CRD and 4.7L. The driver side catalytic converter rubs on the left wing. Marlin said he'd be making up a new set that would be 1/4" wider allowing the clearance we needed. But....I still haven't gotten the new wings for mine yet. I had to space them out using 3-4 washers to make it work.
You also mentioned getting a new muffler. Push that thing as far back and up as you can. That will save it from any major hits it would take. Plus the Borla or Magnaflow mufflers are a lot smaller than that big *** thing thats on there now.
Unread 08-27-2013, 10:31 PM   #10
Keeslinger31
2005 WK
Ya they are pretty bad, I'll look into some adjustable ones. Probably help with the alignment too.
Are they weaker than non-adjustable ones? Or the same?
Ah yes I assumed it was a transfer case skid and extended to the muffler I swear I saw one that did that too somewhere
So with the 4xg belly skid does it allow me to keep the transfer case plate?
On the website they don't show it for sale I will have to give them a call and see if they made the adjustments to the wings yet. It looks promising
I bet that crossmember is a pretty good anchor in the mud.
And good advice on the muffler location i'll definitely do that, I bet removing
that beast will compensate for the extra weight i'm about to add
There's a few others if you are interested look into KCJeepClub.org or the Northlanders Jeep group on FB
I'll check out those sites and look up those places, it's been awhile since I had anything capable of any off road activities.
I'd be willing to make a trip out somewhere better than here, it would probably be worth it for the view. Although a local trail would be more convenient.
Is the 4xg the only diff cover available?
I see empty pockets in my near future
Black WK #126
Unread 08-27-2013, 11:00 PM   #11
Anon155
2005 WK
I don't believe they would be any weaker than the stock ones, if anything they look a lot stouter IMO. I'm planning to get some when mine eventually go out. Here's a link: http://www.rockauto.com/catalog/more...128&cc=1430899
The belly skid shares the cross member bolts that the transfer case skid uses. They will butt up right next to each other just fine. It will bring everything down flush so you won't even know that the crossmember is there anymore. It should still up for sale on their website, maybe you were looking in the wrong spot. Here's a link to the sales page and better pics of it: http://4xguard.com/grand-cherokee-20...y-guard-5.html
Unread 08-27-2013, 11:04 PM   #12
JeepN4KC
JeepN4KC's Avatar
Yes the 4xG fits with the Mopar tcase and front diff skids - this is what I run. I ended up getting a Saguaro tcase skid adapter plate because I do not have the full on factory fuel skid. The steel "skin" over the fuel tank has sufficed and I have been in some pretty good places with the WK.
If you have a 12 bolt rear diff (QDII) I think 4xG is your only option for a guard - but don't quote me on that.
If you have a 10 bolt rear diff (QTII) I'd definitely go with a Solid Axle Industries Chrysler 8.25 cover.
~Mike~
Build Thread WK
Unread 08-28-2013, 12:02 AM   #13
Keeslinger31
2005 WK
It's QD2 as it was one of the things I absolutely had to have when looking at wk's and watching vids of wheeling with it, it impressed me
I saw a picture of a dented rear diff cover and don't want that to happen far from home if it leaked or hit the ring gear
Yes those do look strong
I guess its worth it since mine look like they could break at any time now.
And I couldn't justify spending 500 on control arms from jba since I could replace the ball joints several times with that money.
Weird I couldn't find the belly guard for some reason probably just skipped over it.
I was trying to follow the link from the gallery and it wouldn't work for me
So thanks for the link! I'm going to email them and ask about the wings I guess just to be sure.
I had a whole paragraph typed up asking about some other 4xg stuff but after
some reading it looks like i'm just going to get all of it as it's cheap insurance
I see some trail grapplers in my future as well had them on a silverado 2500 and they were awesome thinking 285/70/17s but I'll have to wait till I wear out these general's
My first move is going to be these ball joints as thats a safety issue if anything.
Then the belly guard and a muffler and all the little things I mentioned in the first post mostly appearance not a fan of all this chrome stuff since it's not actually real,
I will probably keep the chrome under the windows as it's actually stainless and not plastic.
After that I'll start splurging at 4xg for some protection
You guys have been really helpful
I'd say the mod bug has officially bitten me If i hadn't already been infected
Black WK #126
Unread 08-28-2013, 08:29 PM   #14
Keeslinger31
2005 WK
Installed a new chrome piece on the rear
Took a few others while I had the camera out
Love the grey
Black WK #126
Unread 08-29-2013, 09:44 AM   #15
Jeepforthewin
2010 JK Wrangler
I wonder if anyone has contacted Solid Axle about making a Diff cover for us 12 bolt folks?
2010 JKU - Stock for now
2005 WK - 6" lift, 35" BFG's, a lot more (SOLD)
Jeepforthewin is offline   Reply With Quote Quick reply to this message
