K&N Install - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > K&N Install
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRaceline/Allied Wheels on Sale NOW !Bead Lock Wheels! Raceline, Trail Ready, & Trail-Gear
Unread 08-08-2008, 12:44 PM   #1
shakess9
K&N Install
Just recently installed the K&N FIPK Air Intake on my 06. It now makes a Shhhhhhh... noise everytime i push on the gas pedal. I know they are noisier then stock, But it only does it when my A/C is on. If the A/C is off, it doenst make the hissing noise at all. Anybody have the same problem? or the solution if their is one?
shakess9 is offline   Reply With Quote
Unread 08-08-2008, 01:42 PM   #2
rwmorrisonjr
2006 XK Commander
You're hearing the vacuum noise from the throttle body, its normal since the resonator' sno longer covering up the noise.
rwmorrisonjr is offline   Reply With Quote
