Jvenrick's Mean Green Build Thread - Page 7 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Jvenrick's Mean Green Build Thread
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Unread 03-02-2014, 10:54 AM   #91
m07wk
2007 WK
What size is your solid diff cover?
THE DOC
2007 WK 3.7L, N Dure tail light guards, short antena
Red WK club
m07wk is offline   Reply With Quote Quick reply to this message
Unread 03-02-2014, 10:56 PM   #92
Jvenrick
Jvenrick's Avatar
2007 WK
It's the solid Chrysler 8.25.
2007 Grand Cherokee Rocky Mountain Edition: 4.7L V8- QTII- Green
The build: http://www.jeepforum.com/forum/f67/j...hread-1373720/
Jvenrick is offline   Reply With Quote Quick reply to this message
Unread 04-13-2014, 04:46 PM   #93
Jvenrick
Jvenrick's Avatar
2007 WK
Was able to get my new key cut, and moved the electronics over to the new shell. love this key!! I always thought the original key design was horrible.
Unread 04-13-2014, 05:51 PM   #94
suzq044
2005 WK
That was my first "mod" for my jeep. Lol
1964 Jeep Wagoneer Panel Delivery - work in slow progress
2005 Grand Cherokee Laredo QTII 4x4 - stock for now
suzq044 is offline   Reply With Quote Quick reply to this message
Unread 04-15-2014, 11:13 PM   #95
Jvenrick
Jvenrick's Avatar
2007 WK
Ha. Yeah should have done it months ago.
Unread 05-07-2014, 08:13 PM   #96
Jvenrick
Jvenrick's Avatar
2007 WK
Took the day off and did some maintenance work on the wk. was able to drain and fill the trans and replace the filters, new spark plugs, repaired the trans cooler lines, and replaced the lower ball joints. What a huge difference!! I also picked up all the accessories for my cb install. Hope to get that wrapped up this weekend, think I have figured out a good mounting point for everything!!
Unread 05-07-2014, 08:58 PM   #97
ColoradoGrand05
2007 WK
I really love that color and what you've done. How has the Rola held up in the weather here?
2007 WK, 4.7L
Colorado Jeep club #288
ColoradoGrand05 is offline   Reply With Quote Quick reply to this message
Unread 05-10-2014, 12:03 AM   #98
Jvenrick
Jvenrick's Avatar
2007 WK
Thanks a lot dude!!
The Rola is doing well, I have been meaning to weld it up, but have not gotten around to it. I have used silicone to more or less waterproof it though and that has been working just fine.
Unread 06-07-2014, 08:30 PM   #99
Jvenrick
Jvenrick's Avatar
2007 WK
ok guys I need your help. so I did a mock-up install of the CB, and the SWR's are very bad. Im at 3:1 on both channel 1 and 40. This reading is in an open empty lot, so there is no interference. Can anyone help me figure this out? here are a couple pictures of what im thinking. again this is just a mock-up, ill hide it all and make it look clean once I know I am able to successfully tune it. thanks!!
here are some pics of the mount. I have tried it on the top rail and it is now on the bottom rail, just because that way it fits in my garage. I have no problem moving it to the top again if its worth it. the antenna is on a HD spring and a quick release mount. I know this mount is not the best by any means, so im thinking of purchasing the SA antenna mount with hopes that it will give a better ground... if that's my issue?
I got the cobra 75wxst so here is where im mounting the mic plug
I mounted the transceiver box to the back of the cubby in the dash that's on the driver side next to your left knee
and I fed the power wires directly to the positive terminal on the battery and grounded it on one of the engine bay grounds.
Unread 06-07-2014, 10:28 PM   #100
BoraBora
2015 JK Wrangler
It's your mount. The mount needs to be in solid contact with the frame to form a ground. The old school Aspen Creek mounts ground by being screwed in, so for that taillight guard mount you can run a wire through the mount and ground it.
'15 JK 2.5" lift on 35's
'06 WK 3.5" lift on 33's (Sold)
BoraBora is offline   Reply With Quote Quick reply to this message
Unread 06-08-2014, 01:00 AM   #101
Jvenrick
Jvenrick's Avatar
2007 WK
Great, thanks. I'm assuming the SA mount is the same design as the aspen creek one?
Unread 06-08-2014, 08:28 AM   #102
BoraBora
2015 JK Wrangler
Yep same design.
Unread 06-15-2014, 04:16 PM   #103
Jvenrick
Jvenrick's Avatar
2007 WK
well guys, with the help of the steel armadillo antenna mount I was able to mount and successfully tune my CB. Currently at 1.7 on both channel 1 and 40, and that was just in my drive way with tree interference. Im going out to the family farm in a couple weeks so I will re-tune it out there with no inference. I also purchased and installed the steel armadillo secure counsel. I love it. very well made, and perfect for my concealed carry 380.
Unread 08-28-2014, 11:23 PM   #104
Jvenrick
Jvenrick's Avatar
2007 WK
Hey guys been awhile since I have updated this. Been having a real fun summer exploring all over Colorado. Here are just a couple pics of the fun I have been having.
Unread 08-29-2014, 07:26 AM   #105
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Great Sand Dunes National Park and Medano Pass - been there. Beautiful.
Looks like you're getting out and enjoying your state, Evan, nice!
~Mike~
Build Thread WK
Other Build Thread XJ
September 2013/January 2015 COTM
JeepN4KC is offline   Reply With Quote Quick reply to this message
