Just Bought a WK, Now I've Got a Few Questions - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Just Bought a WK, Now I've Got a Few Questions
Zone Offroad Body and Suspension Lift Kits, Brackets, DiscJeep Wrangler Framless, Bowless, Trektops 92-95 YJ, 97-06 Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 11-16-2013, 11:56 AM   #1
GoldCherokee
Not new to Jeeps, but new to WK's. I just bought the wife a WK to replace her wrecked XJ, it's an 05 5.7 Limited 4x4 QDII with 100k miles on it. I purchased it from a Honda dealer, and I've got no service records on it other than the CarFax. Anyways, I've had a couple of small issues pop up in the week or so that we've owned it. I've done a few searches, but nothing really popped up immediately.
1. The right rear door will not open from the inside. The inside handle isn't broken, and the door will open just fine with the exterior handle. Is there a piece that is known to break and cause this? I didn't see child locks on the doors. I've only had a few minutes in the dark to look at it.
2. It's getting what seems to be terrible MPG. I know it's a Hemi and whatnot, but the first tank got 12.6mpg hand calculated. That was about a 50/50 mix of city and highway. Is there anything that typically fails to cause a MPG loss? I'm sure it needs a tune up, and I have no idea if the plugs/coils have ever been replaced. Other than plugs/wires, what else would cause such a loss?
3. Is there an easy way to make sure the cylinder deactivation system is properly working? The dealer I bought it from changed the oil, and the receipts that I have show 5w20 went into it. I plan to change it soon to put synthetic back in it, but it shouldn't be hindering the MDS system.
Thanks for any help in advance, I'm sure I'm going to get to know this Jeep just as well as the XJ.
-Tom
1999 Cherokee 4.0 4WD
2005 Grand Cherokee 5.7 QDII Limited
GoldCherokee is offline   Reply With Quote Quick reply to this message
Unread 11-16-2013, 12:23 PM   #2
ttusqrl
2005 WK
Have you checked the child lock on number 1?
[B][U]2005 WK 5.7[/U] [COLOR="Red"]ORT[/COLOR] | Mod SL (OME struts & 990s) | JBA UCAs & Discos | Saguaro Front Bumper | Warn Zeon 10s | 285/70/17 BFG TA KO | AIRAID CAI | Gibson 3" Exhaust | DiabloSport Intune | JL Stealthbox[/B]
ttusqrl is offline   Reply With Quote Quick reply to this message
Unread 11-16-2013, 01:14 PM   #3
Shafer57
2006 WK
12.6MPG is about what to expect. Most everyone on here w/ the Hemi gets ~14 combined. So I'd do plugs to confirm you're getting a good spark too.
Look through the search function for MDS "ON" Light write-ups. There's a few, and it basically is a small light you wire up to come on whenever MDS is active.
Dodge Dakota R/T 360ci Small-block _sold_
Jeep GC 5.7L Hemi- Magnaflow Cat-Back, BT Catch Can, 20" Gloss black SRT Reps
275/45R20 Nexen Roadian, Blacked out, 180 Stat _SOLD_
2008 335i Twin-Turbo
Shafer57 is offline   Reply With Quote Quick reply to this message
Unread 11-16-2013, 02:28 PM   #4
DanG28
The best way to improve fuel economy in every vehicle is an adjustment in driving habits. I'm not assuming you drag race from red light to red light, but try slowing your highway speeds by 5 mph, make a conscious effort to coast A LOT, bump your tire pressure up, etc. It seems like everyone wants to drive 80 mph AND get great fuel economy. You can have one or the other, and I always choose fuel economy. (I drive 50-55 mph highway)
DanG28 is offline   Reply With Quote Quick reply to this message
Unread 11-17-2013, 07:58 AM   #5
GoldCherokee
I guess I should have known better, it IS a Jeep with a V8 afterall. Although, I was only hoping for numbers closer to 15/16 mixed. I'll do plugs/wires/coilpacks and see where that puts me.
At least I have some good news, I was able to fix the interior door handle fairly easily. I didn't see the child lock lever in the dark when I looked for it, but it's right there plain as day when it's light outside. (Blue jeep/black lever). But, it was on, and now it's off and everything works just fine again.
Thanks for the help guys!
-Tom
