Just bought my first "Jeep", 08 WK, Hitch question? - JeepForum.com
post #1 of 7 Old 07-28-2012, 05:06 AM Thread Starter
gemiller
2008 WK
I just bought my first jeep, an 08 WK 3.0CRD with 40k miles, it doesn't have a hitch and I am going to order one today. However, I'm not sure where to look to see if I need the wiring harness that has the factory 7 way or the one that does not. It is a Laredo model if that matters.
Hope to learn a lot here on the forum!
gemiller is offline
post #2 of 7 Old 07-28-2012, 06:52 AM
SSF556
2008 WK
Before you do anything with the hitch you need to make sure the engine has been taken care of by the previous owner.....
1) you need to make sure you have the updated air intake pipe.....Check to see if the seal attached to the turbo is orang..orange = bad.
2) I personally would do an oil change using 229.51 oil...Napa sells Mobil 1 esp. Wrong oil and you risk premature failure of the DPF.
3) search the forum for swirl motor fixes...I would purchase the GDE tune which eliminates the swirl motor while giving you more hp/torque and better fuel economy. It is $750 for the tune, but considering the price of a new swirl motor worth it.
4) there is the swirl motor resistor fix as well
Back yo your hitch question...I am surprised your CRD does not have the factory hitch....try looking at the drivers side rear near the spare tire for wiring.
Welcome...the CRD is a great engine
Silver WK Club Member #1
2008 CRD QT2
SSF556 is offline
post #3 of 7 Old 07-28-2012, 07:28 AM
colinzj
2006 WK
The harness comes in a 4-way and a 7-way configuration. Which one you want is totally a matter of personal preference and what you plan to tow.
If you'll ever need a 7-way connector (anything more than a podunk U-haul trailer), get the 7-way.
If you're certain you'll only ever need the 4-way, get the 4-way.
7-way can also be used with 6-way, 4-way, and military equipment with adapters. 4-way can only be used with 4-way equipment, but you don't have to keep track of adapters.
2006 WK Laredo 4x4 4.7L
1993 ZJ Laredo 4x4 4.0L Dead, sold, and rolling again
colinzj is offline
post #4 of 7 Old 07-28-2012, 02:51 PM Thread Starter
gemiller
2008 WK
Thanks for the advise, I'll definitely look into everything. Where is the seal on the air intake pipe to look for it?
Also, I know the difference between the 4 and the 7, i'm saying though, that the one harness says it's for vehicles with the factory 7 way harness.
http://www.thehitchstore.com/electri...s-c-30_33.html
I don't know how to tell which one of the two harnesses i need since I don't know where the factory 7 way would be located.
gemiller is offline
post #5 of 7 Old 07-28-2012, 03:18 PM Thread Starter
gemiller
2008 WK
I'm thinking it doesn't have the factory 7 way because the only thing I see under driver side rear is a two prong plug and nothing else.
2008 WK Red Rock Crystal Pearl CRD || Lifted and stuff.
gemiller is offline
post #6 of 7 Old 07-28-2012, 08:32 PM
trax95008
2006 XK Commander
I think the idea is that you may have the wire harness tucked away under there ready to go for the socket. And FYI, the factory setup comes with both the 7 and 4 wire sockets
trax95008 is offline
post #7 of 7 Old 07-28-2012, 09:08 PM
Chirpz
Chirpz's Avatar
2007 WK
Look for a receptacle behind a trim panel.
My 07 CRD came with a hitch... BUT.... I bought a hitch and harness for my 2000 Grand Cherokee and installed it. It was pre-wired for a 7 plug but would adapt to a 4 plug if you bought the right harness. The connector was located underneath the driver side rear window behind the trim panel. I had to raise the tail gate and start removing various trim until I could get the panel off. It was pretty easy. As I recall, there was a knock out plastic plug through which I had to run the new harness. I just passed the new harness through the hole and plugged it into the receptacle that was already there. Not cutting or splicing was required.
I bought my hitch online from some place that specialized hitches and they had the correct harness in stock. I don't remember the place....sorry.
If you plan of towing an RV trailer, go with the 7 for sure.
Dittos to everything Scotr29 had to say. At 40K you are about due for a swirl motor failure unless the issue has been fixed. Mine went out around 58K and I replaced the swirl motor, then a year later discovered the GDE Tune. Now I have a new SM that just sits there turned off.
Chirpz
2007 WK CRD, Quadradrive II, OEM Tow Hitch, GDE EcoTune, DPF-Delete, 4xGuard Front, Rear, Belly Guards, Side Rails & Full Matrix, OEM Skids, EHM, Dash Duck.
Chirpz is offline
Factory NAV unit - Can the start up "jeep" or "dodge" name be changed? JOSHMAN00 WK Grand Cherokee & XK Commander Forum 12 01-15-2012 09:31 PM
Bought a Jeep that came with an early "Black Friday Special" stageninja ZJ Grand Cherokee Forum 15 11-26-2009 12:58 PM
Bought Overland w/18" but got with 17"s I feel stupid NewJeepOverland WK Grand Cherokee & XK Commander Forum 33 03-23-2009 11:36 AM
2004 Jeep Limited: (AZC "manual mode") question 2tone93zj ZJ Grand Cherokee Forum 3 02-23-2009 09:39 PM
Anyword on the "Hitch Gate" rear tire carrier? Rev. Al WK Grand Cherokee & XK Commander Forum 0 09-22-2008 07:19 PM
