Just another build thread - Page 3 - JeepForum.com
post #31 of 297 Old 12-14-2013, 03:29 PM Thread Starter
94jeepman
2005 WK
Originally Posted by suzq044 View Post
Nice Maserati. Lol
Bahaha thanks ill let my dad know you like it lol
94jeepman is offline
post #32 of 297 Old 12-14-2013, 03:48 PM Thread Starter
94jeepman
2005 WK
More accessories
I extended it
I also did the leering mod you will need to take out the knobs
You will need new bolts I used m6x1 about 2 inches long
And put them back in using a washer
And got the rack on
post #33 of 297 Old 12-14-2013, 11:23 PM
Supermanbaja
2008 WK
Originally Posted by 94jeepman View Post
I had it for about 4 months before I broke stuff and had to get new struts and built a bumper for it.
If you can tell from the first picture the jeep is pretty much sitting on the tires
Im going to make a bumper just like that I think next summer. My work has a plasma cutter and welder. Iv been thinking of making it out of aluminum. but its going to look close to what you have.
Supermanbaja is offline
post #34 of 297 Old 12-15-2013, 09:44 AM Thread Starter
94jeepman
2005 WK
I don't have a tig welder anymore so I can't do aluminum unless I get the setup for my mig. I wanted to do aluminum tho but oh well
post #35 of 297 Old 12-17-2013, 12:17 PM Thread Starter
94jeepman
2005 WK
Originally Posted by Phrankoff View Post
damn. looking good. that bumper is ridiculously sick.
mirin' hard
The one on the jeep or the one on the ground? Haha
post #36 of 297 Old 12-17-2013, 02:24 PM Thread Starter
94jeepman
2005 WK
Got my lift gate supports.
And now everything stays open
post #37 of 297 Old 12-17-2013, 06:30 PM
Anon155
2005 WK
Do you have the part numbers for the rear glass by chance? Now that it's cold out, mine keep falling on my head
05 Jeep Grand Cherokee: ORT 4X4; Khaki #55
Too many mod's to list...
Anon155 is offline
post #38 of 297 Old 12-17-2013, 10:13 PM Thread Starter
94jeepman
2005 WK
Got them off amazon they are strong arm they said if they were for the lift gate or the glass
post #39 of 297 Old 12-18-2013, 11:25 PM Thread Starter
94jeepman
2005 WK
If you haven't found it they are strong arm 6601
post #40 of 297 Old 12-20-2013, 02:49 PM Thread Starter
94jeepman
2005 WK
I got a 1st led strip but where do I cut and solder it at?
post #41 of 297 Old 12-20-2013, 03:11 PM
Anon155
2005 WK
There should be a cut line where the gold terminals are. Usually every 3 LED's. Measure the length you want and cut on that line. You'll have to peel/cut back the urethane clear coating away from the tops of the terminals and solder your wires onto the terminals. Make sure to put some heat shrink tubing over the terminal wire ends once soldered to keep moisture away.
Anon155 is offline
post #42 of 297 Old 12-20-2013, 04:19 PM
Jeepforthewin
2010 JK Wrangler
Most of the time there is a cut line like Anon stated, but I don't see any on yours. Check the link you bought them from and check if it says you can cut them. Should look like this:
2010 JKU - Stock for now
2005 WK - 6" lift, 35" BFG's, a lot more (SOLD)
Jeepforthewin is offline
post #43 of 297 Old 12-20-2013, 04:52 PM Thread Starter
94jeepman
2005 WK
It says I can cut them at every 3 led
post #44 of 297 Old 12-20-2013, 04:59 PM
Jeepforthewin
2010 JK Wrangler
Follow Anon's steps
post #45 of 297 Old 12-20-2013, 09:36 PM
suzq044
2005 WK
Which struts for your Liftgate? Looking at replacing ours
1964 Jeep Wagoneer Panel Delivery - work in slow progress
2005 Grand Cherokee Laredo QTII 4x4 - stock for now
suzq044 is offline
