JKS Quicker Disconnects - JeepForum.com
post #1 of 80 Old 10-05-2010, 10:30 PM Thread Starter
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Ok so I posted a quick pic in the picture thread which received a lot of attention so I am making a thread for them. I got these from Rusty's Offroad. I was originally looking to get the extended sway bar links that they use in their 4.5" kit. Once I found out that they are now using JKS Quicker Disconnects and have not had any problems with them, I had to have them. They cost me $140. I do believe they were for a JK and I think the PN is 2034. I am not sure what they did or added, if anything, to make them work for the WK. Here is how the install went...
I started by lifting the front end off the ground, removing the tires, and letting the suspension hang free. I figured this would be the easiest way to tackle both sides without them fighting each other. Then I disconnected the bottom link bolt on the LCA.
Then the top link bolt removing the link all together.
Then I installed the Tapered Mounting Post onto the LCA using some Loctite and slid on the Offset Polyurethane Spacer.
Followed by the top Tapered Mounting Post onto the sway bar.
Then I extended the link out to the desired length, slid it onto the lower pin, and secured it into position using the Click Pin.
Followed by the top.
After it was secured into position I used a crescent wrench to tighten the nut on the link which I was not able to get very tight before. I had also applied some Loctite to the threads as well.
And there you have it. Quicker Disconnects!
After finishing I took it out for a test drive to make sure everything was tight and aligned well. I did not get any weird noises, creaks, or clunks. They are relatively easy to slide on and off, which I knew they would be. I know these will work for a 2-3" lift and am pretty sure they would work on a stock Wk as well, since they collapse down to a stock length link. I am not sure how long the links are that come with the SL or BDS 4" lifts but if Rusty's is using them on theirs, then I am sure they would be fine. I hope this is informative and gives the necessary info you were all looking for.
Omelet is offline
post #2 of 80 Old 10-05-2010, 11:51 PM
lagonwagon
2007 WK
Omelet,
You rock man! Great find! This is next on my list.
2007 WK Limited (white), QDII, Hemi, OME HD lift, JBA UCA's, Treadwright Guard Dogs 32.25's, Fuel wheels, K&N CAI, BT catch can, 4xGuard rails & belly skid, Saguaro 4x front shackle mounts, tow hitch shackle mount (SOLD)
lagonwagon is offline
post #3 of 80 Old 10-06-2010, 07:07 AM
BonesWK
2006 WK
man, thanks for posting this... seems like a pretty cut and dry install.
Ryan
2006 Black WK Limited 4.7 4x4 QD II SOLD
Current - 2008.5 Mazdaspeed 3
If you want to achieve greatness, stop asking for permission
BonesWK is offline
post #4 of 80 Old 10-06-2010, 08:36 AM
TOAOST21
2007 WK
thanks man, awesome write up on the install. these are definitely next on my list of add ons to the WK
TOAOST21 is offline
post #5 of 80 Old 12-14-2010, 04:58 AM
ahmed255
Very good installation write up .. thanks for sharing
I assume you do this to extend the wheel travel for off-road ,, Any pics for the wheel travel difference in both cases stock length and disconnected?
2007 XH Commander (International model), Green Metallic, Limited, 5.7L HEMI, Quadra-Drive II
Spidertax 1.5" wheel spacer, Flowmaster 50 SUV muffler, Sylvaniya Ultra bulbs for high beam and fog lights, K&N replacement filter
ahmed255 is offline
post #6 of 80 Old 12-14-2010, 09:51 AM
stanton3
2007 WK
Does anyone make disconnects for the rear?
2007 WK 4x4 | OME HD 3" Lift | OME Shocks front + rear | 265/70/17 BFG All Terrains | 1.25" Wheel Spacers on stock wheels | Saguaro4xcomponents 5/8" Front recovery shackles | Aries Taillight Guards | PIAA 510 fogs in stock location | Midland 1001z Cb | Mopar Rear recovery hook | Rola Roof Rack |2 Hella 500ffs mounted behind grill | Firestick 3' Antenna | Saguaro Antenna Mount | Front Bumper Cut/Fender Trim | OEM Front suspension skid | 4xguard Front skid | Rusty's .5" Front Spacer | Lots more to come
Want to buy: 4xguard Rear Guard
stanton3 is offline
post #7 of 80 Old 12-14-2010, 10:32 AM Thread Starter
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
ahmed255 - Good to see you back around here! Its been a while. Ya these things are intended to maximize your articulation. Just pull one out and let the IFS work! I don't have any flex shot right now, but I can post some up this weekend.
stanton3 - I am not sure about the rear. I am actually planning on putting some back there soon. It would be easy. I need to compare the rear top bolt threads to the front lower arm threads to see if they are the same. If so it is as easy as the front just mount them upside down. If it is differant then I will probably just reuse the top bolt in the rear and just have the Tapered Mounting Post bolted to the swaybar like it is in the front.
Omelet is offline
post #8 of 80 Old 12-14-2010, 08:14 PM
hughes278
awsome, i can't wait to see the pics
hughes278 is offline
post #9 of 80 Old 12-14-2010, 09:24 PM
AJeepZJ
2006 WK
Thanks for the post Omelet - Always so resourceful ... I'm wondering how beneficial this would be for the rear sway bars though?
All Gear, No Skill.
AJeepZJ is offline
post #10 of 80 Old 12-14-2010, 10:35 PM
tjkj2002
2002 KJ Liberty
Novel idea but the noises will come along with many broken pins.Some have used them on the IFS on a KJ and alway's resulted in very loud noises and broken parts and almost everyone later removed them and installed OE style links.The swaybars on a IFS are pretty stout and stress those disconnects to much.Sure they limit front flex but this also keeps the CV's more in there safe operating ranges also.
Just remove the rear swaybar,you'll never now your driving without it anyways as it's a Jeep and not a Corvette.
tjkj2002 is offline
post #11 of 80 Old 12-14-2010, 11:40 PM
ahmed255
you can use the same brand of these disconnects JKS (part # 2001) ..
Look at this thread in jeepcommander.com someone did it there:
JKS Rear Sway Bar Quick Disconnects - Jeep Commander Forums: Jeep Commander Forum
it is actually more beneficial for the rear more than the front due to the solid axle.
ahmed255 is offline
post #12 of 80 Old 12-15-2010, 04:58 PM
AJeepZJ
2006 WK
Well what I mean is... I don't really see the purpose of a swaybar for the rear in the first place which would defeat the purpose of these disconnects... I know they are decent for on-road and what not. But I guess this would be a really nice alternative to taking a wrench to it every time you go out or leaving it disconnected all the time. I am starting to see the usefulness of it.
All Gear, No Skill.
AJeepZJ is offline
post #13 of 80 Old 12-15-2010, 06:25 PM
Robert J. yates
We have this discussion all of the time in the TJ forum.... a properly functioning rear swaybar will not limit flex while adding to off camber stability. Its simply not sufficiently sized so as to reduce flex such as that with the front. MA is to leave the rear alone.
As for the front... I have the JKS disco's on my daughter's XJ and they do tend to get beat up a bit by the swaybar moving around. I guess I am also curious as to the effect of a disco'd front bar on CV's as well as the steering rack.
Originally Posted by samgm2 View Post
And yes, I am an exceptional scientist and engineer.
Robert J. yates is offline
post #14 of 80 Old 02-22-2011, 03:24 PM
criket
2005 WK
Bump.
So I'm thinking of going with these from Rusty's. I've read the other thread where you disconnect both sides but i think i'm going with just one side (personal preference).
Omelet, could you give me a sort of pros and cons on this product please?
I have a 2" lift.
Thanks!!!
2005 | WK | Khaki | 3.7 | QT1 | OME HD Front Struts | Rusty's 2" lift in Rear w/ Monroe load levelers (F150 version) | 265/70 Nitto Terra Grapplers | 17" Moabs | 1.5" wheel spacers | Pinch weld mod Rear fender trim mod | 4xG Matrix w/ reciever hitch | 4xG Belly guard | SOLID Diff cover | Cobra CB radio | 4xG antenna mount | Rola roof
criket is offline
post #15 of 80 Old 02-22-2011, 03:39 PM
Acidcold
2005 WK
Just ordered a set from JBA and they will be longer for my SL! I have had my knuckles bleed almost every time i went wheeling due to removing the sway links!
Acidcold is offline
quicker disconnects holder Ricochet88 ZJ Grand Cherokee Forum 23 03-11-2009 11:59 AM
jks quicker disconnects MEinSoCal ZJ Grand Cherokee Forum 4 07-07-2008 04:25 PM
Jks Quicker Disconnects semperfismhs ZJ Grand Cherokee Forum 5 05-27-2008 04:52 PM
?'s on JKS quicker disconnects deathbylaxitive ZJ Grand Cherokee Forum 8 02-17-2007 09:01 PM
I need advice right this minute! Quicker Disconnects veddderman123 ZJ Grand Cherokee Forum 26 02-15-2007 03:08 PM
