Jk wheels on my 05 WK - JeepForum.com
post #1 of 10 Old 10-19-2013, 02:14 PM Thread Starter
ohhpe
Alright I have been searching forever about what fits on my 2005 wk limited hemi jeep. All I see is how running bigger tires w the two inch lift will require spacers.
My local mechanic said you can run 265 70 17 with no spacers. Everyone on here seems to say you cannot.
Also Will a set of jk wheels solve the problem as I read the back spacing is better for clearing the upper ballpoint stud???
95 yj 6" lift, 34" truxs mts
2005 WK Limited 5.7L Hemi. 2" day star lift awaiting tires and wheels for installation.
ohhpe is offline
post #2 of 10 Old 10-20-2013, 02:20 PM
BoraBora
2015 JK Wrangler
No. JK wheels will need at least .25'' spacers in the front to clear the brake calipers. Only on very early 2005 and 06's did the JK wheels fit fine without spacers. You can always grind the brake caliper down and cut the bolt to clear the tires fine. I'd just get a set of aftermarket wheels or run wheel spacers. I've had wheel spacers for 2K miles now...not a problem.
'15 JK 2.5" lift on 35's
'06 WK 3.5" lift on 33's (Sold)
BoraBora is offline
post #3 of 10 Old 11-15-2013, 05:27 PM Thread Starter
ohhpe
Any other options? Sounds like the jk wheels don't fix the problem
ohhpe is offline
post #4 of 10 Old 11-15-2013, 06:10 PM
Cherokee30D
2007 WK
Just got some JK rims with 265/70/17 tyres for my WK last week. Needed 6mm (1/4 ") spacers, otherwise all good.
Cheers, Craig
Cherokee30D is offline
post #5 of 10 Old 11-17-2013, 12:47 PM Thread Starter
ohhpe
That close huh?? So they help but don't solve the problem
ohhpe is offline
post #6 of 10 Old 11-17-2013, 12:49 PM Thread Starter
ohhpe
I just noticed you have an 07. Wil my 05 be different. Is the .25 inch spacer needed to clear the brake caliper or the bolt
ohhpe is offline
post #7 of 10 Old 11-17-2013, 01:52 PM
ttusqrl
2005 WK
To clear the caliper
2005 WK 5.7 ORT | Mod SL (OME struts & 990s) | JBA UCAs & Discos | Saguaro Front Bumper | Warn Zeon 10s | 285/70/17 BFG TA KO | AIRAID CAI | Gibson 3" Exhaust | DiabloSport Intune | JL Stealthbox
ttusqrl is offline
post #8 of 10 Old 11-17-2013, 08:39 PM
msfulcher77
2008 XK Commander
Does this issue also apply to XK's?
2008 XK Hemi w/QT2
Superchips Flashpaq 3875 running Mileage Tune (for now)
msfulcher77 is offline
post #9 of 10 Old 11-20-2013, 11:48 AM
R4TCHET
2005 WK
05 does need 1/4" spacers to clear the caliper
Sent from my Jailbroken iPhone using JeepForum
| (dark)KHAKI WK CLUB MEMBER 17 | 2005 4.7L QTII | JBA UCAs | Modified OME MD 3.5" lift | Rusty's Adj. track bar | 4XG Matrix | 285/70r17 Duratracs | 17" KMC Enduro Wheels | Rola Roof Rack | 21" Bean LED Light bar on Roof Rack | 2 12" Punch P3 Subs | Expanded Sheet Grille | SA Sliders |
R4TCHET is offline
post #10 of 10 Old 11-20-2013, 12:01 PM
ryann04
2008 WK
I have also seen people shave down the calliper a bit with a file to clear the JK rims and not use a spacer.
If you do this, be careful and only shave off what you need.
2008 - Jeep Grand Cherokee - 3.0L CRD - Quadra Drive II - GDE Hot-Tune - OME HD Lift Kit - OEM Full Steel Skids
Blue WK Club Member #42 // DIESEL FTW !!!! -Ryan
ryann04 is offline
