Jeep wk trouble startingand rough idle - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Jeep wk trouble startingand rough idle
Savvy/Currie Aluminum Control ArmsIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAlloy usa heavy duty ball joint kits
Unread 12-22-2014, 06:07 PM   #1
JustJeep247
Junior Member
JustJeep247's Avatar
2010 WK
Okay so I'm not very experienced with work under the hood, but recently my 3.7 will try to crank and make a few clunk noises and I turn the key to the off position for fear of damaging the engine. It seems to do this very randomly and just started about4 days ago. Also after it does it when I try to crank it again it always starts perfectly fine.i have also noticed quite a bit more heat coming from the engine. The gauge is still about half way but it is noticeably warmer. Lastly it has been having a really rough idle. It feels like there's slack in a belt or something. I just wanted to see if anyone has experienced anything like this before taking her to the dealership.
Thanks!
-Emerson
JustJeep247 is offline   Reply With Quote Quick reply to this message
Unread 12-26-2014, 02:37 PM   #2
Craigyfm
2006 WK
Sounds like a misfire. Change the plugs and clean off the connectors. Buy decent plugs, better to try this first before being dry raped at the stealers!!!
Craigyfm is offline   Reply With Quote Quick reply to this message
Unread 01-18-2015, 11:27 PM   #3
jrusse
Is it throwing any codes? Usually a misfire will a throw a code really fast.
jrusse is offline   Reply With Quote Quick reply to this message
Unread 01-22-2015, 07:45 AM   #4
jbarrett
It's not a misfire - it would throw the code immediately. Sounds like you need a good tune up. Change the oil, change the plugs, change the air filter? Not sure how many miles you have or when that was last done. The WKs are also notorious for acting "weird" when the battery is not in absolute tip-top shape.
jbarrett is offline   Reply With Quote Quick reply to this message
Unread 01-22-2015, 07:51 AM   #5
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
I've experienced something like that but not before I took it to the dealership. (Do everything you can to DIY or find a reputable shop other than a dealer).
Just the other day in fact. My 4.7 had shudder when driving and somewha at idle. Started up fine though. Did it for a bit before throwing a CEL.
Turned out to be a misfire in cylinder 8.
~Mike~
My Build Thread WK
My Other Build Thread XJ
'01 XJ with some stuff
Sept 2013 Cherokee of the Month
'07 WK with some other stuff
~RED WK CLUB #7~
'11 KK with mostly stock stuff
'06WK our first Jeep with stock stuff - totalled and gone
JeepN4KC is online now   Reply With Quote Quick reply to this message
