Jeep WK Tire Pressure Light Constantly Blinking - JeepForum.com
post #1 of 27 Old 09-26-2012, 05:30 PM Thread Starter
vucat13
Two months ago I purchased a 2007 WK with about 50k miles.
On the way home from the dealer, the orange tire pressure warning light on dash started blinking. Often it will blinking for a minute or two, shut off, and come on again later. It does not matter what speed or terrain.
Shortly after purchase I replaced the tires (Goodyear). They needed to be replaced, but that did not solve the problem either.
I took it back to the dealer twice. Believe the second time they said they reset the sensors and aligned the pressure in each tire.
That did not fix it either. One of the service guys gave me a long-winded answer (sounded like BS) that this light comes on in a lot of cars and it should be a problem more in the mornings due to the temperature change. I pointed out to this guy that it comes on at all times of the day and at all temperatures.
Does anyone have any advice for my next move?
The light is really annoying and I want to get it fixed somehow.
THANKS
vucat13 is offline
post #2 of 27 Old 09-26-2012, 05:45 PM
cherrybomb05
2010 JK Wrangler
Check your spare and possibly get the sensor in it replaced. I believe they have one too
07 WK
10 JKUR
11 JKR
cherrybomb05 is offline
post #3 of 27 Old 09-26-2012, 06:12 PM
JRLT
2010 WK
My spare doesn't have a sensor.
What probably happened is the right wheels with the correct sensors got swapped out at the dealership and they just threw on a set of wheels but doesn't have the correct sensors in them.
2010 3.7L, 4XGuard Matrix, Fastman TB, TB Ground Mod, Injen CAI, 255/60/18 Nitto Terra Grapplers, Bilstein Shocks & Struts, Cruiser Alloy Wheels - Switchblade, Stillen Brakes, Cargo Light Strip Mod, Electric Ashtray Mod, Jet-powered, Monkey Navigated...
JRLT is offline
post #4 of 27 Old 09-27-2012, 08:20 AM
yzjwk
2005 WK
THANKS
A jeep dealer , or any shop for that matter should have been able to figure out whats wrong pretty easily as any fault or low pressure will flag a code .. but i would Definitely check your spare pressure and make sure the values are close to what is written on the tire placard located on the drivers door or pillar ( should be 33 or 35psi i think) when i bought my wk i had a tpms fault which was caused by an over-inflated tire. here's the info from the owners manual if you don't have
TIRE PRESSURE MONITOR SYSTEM
Tire Pressure Monitoring — Base System
The Tire Pressure Monitor System (TPM) system uses
wireless technology with wheel rim mounted electronic
sensors to monitor tire pressure levels. Sensors, mounted
to each wheel as part of the valve stem, transmit tire
pressure readings to the Receiver Module.
NOTE: It is particularly important, for you to check the
tire pressure in all of your tires regularly and to maintain
the proper pressure.
The “Tire Pressure Monitoring Indicator Lamp”
will illuminate in the instrument cluster, and an
audible chime will be activated when one or more
tire pressures is low. The “Tire Pressure Monitoring
Indicator Lamp” will flash on and off for ten seconds
when a system fault is detected. The flash cycle will
repeat every ten minutes or until the fault condition is
removed and reset.
The Tire Pressure Monitoring System consists of the
following components:
• Receiver Module
• 5 Wheel Sensors (including Full Size Spare Tire)
• Amber Colored Tire Pressure Monitoring Indicator
Lamp
The system will consist of tire pressure monitoring
sensors attached to each wheel through the valve stem
mounting hole, a central receiver module and an amber
STARTING AND OPERATING 269
5
colored Indicator Lamp. A sensor is located in the spare
wheel if the vehicle is equipped with a matching full size
spare wheel and tire assembly.
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
yzjwk is offline
post #5 of 27 Old 09-27-2012, 12:31 PM
JeepCares
FCA Customer Care
JeepCares's Avatar
Just an FYI - you can download an Owner Manual (at no charge) at http://www.jeep.com/en/owners/manuals/.
JeepCares is online now
post #6 of 27 Old 09-27-2012, 02:08 PM
blizzboy283
2005 WK
Mine used to blink all of the time too and it was bc of my iPhone charger. It was messing with the frequency.
05 WK LTD 5.7L Hemi QD II Midnight Blue Pearl, Blue WK Club member #30
Intune, AFE Stage 2 CAI, BT Catch Can, Gibson Cat-back, OME HD, 255/75/17 BFG KM1s, 1.25" Spidertrax, LED Interior, Reverse & Tail Lights, 3/4" Grille, Chrome Fuel Door & handles, SRT8 Pedals, Taylor Shorties, XK knob, 4xGuard Front 4 & Rear Diff.
blizzboy283 is offline
post #7 of 27 Old 09-27-2012, 02:43 PM
black_06_WK
Yep. Mine does this too when my GPS is plugged into the outlet.
black_06_WK is offline
post #8 of 27 Old 09-27-2012, 06:06 PM
GregK340
2017 WK
If the light is flashing, it means there's a problem with the system. It's not reading one or more of the sensors. Could be a problem with one of the sending units in the tires, could be a problem with one of the receiving units mounted near the wheel wells. or in the wiring coming off the receiving units, sometimes while doing tires or brakes these wires get broken. On an 07, the sensors don't need to be "reset". A flashing light means a system problem not a tire pressure problem, although now you have to check tire pressure yourself because the system isn't working.
GregK340 is offline
post #9 of 27 Old 09-27-2012, 07:24 PM
tjkj2002
2002 KJ Liberty
Man can't have that now can we
tjkj2002 is offline
post #10 of 27 Old 09-27-2012, 08:29 PM
Burtman88
1987 YJ Wrangler
If you have to replace the sensor then i would recommend parts bin. com i put my jeep stats in and ended up paying 30 with shipping for the sensor. The first one i broke i took it to many places and was told over 100 dollars each time. I freaked out because when i had it installed they warned me that it was a gm part and it probably wont work. I gave it a day and it ended up detecting the sensor which is great for only 30 dollars.
87 YJ 2.5 inch lift 1 inch shackle BF AT 33-1250-r15
00 WJ
09 WK Hemi, 2.5 inch Rc lift, Super chips,Gibson 3 inch catback, rough country spacers, Voolant Cai,lockpik, Falken Wild peak At 265/70R-18
Burtman88 is offline
post #11 of 27 Old 09-28-2012, 04:37 PM
w1pf
Who, me?
w1pf's Avatar
2007 WK
i'm starting to feel the 2007s are getting to the end of the sensor life.
From mile 1 I've had an intermittent (once every few months) loss-of-sensor, but my EVIC lets me see all the pressures so I can easily tell that I don't have a flat and exactly which sensor is out..
But recently I've started losing multiple sensors.. driving back from a mini-vacation in Maine this weekend, at one point three sensors were AWOL.. I'm wondering if the internal batteries are giving out.
...tom
2014 WK2 Overland 5.9L
2007 WK Limited 5.7L
And some past Durangos
Red WK #19, Hemi #68.. I think..
Durango Owners Club DOTY 2011
"Must have been that yesterday was the day that I was born"
w1pf is offline
post #12 of 27 Old 09-28-2012, 05:29 PM
oducks12
2005 WK
Mine was constantly blinking...broke the valve stem off on a rock and that was the cause
2005 WK Laredo - SOLD
2015 WK2 Limited
oducks12 is offline
post #13 of 27 Old 09-29-2012, 05:20 PM
nick81
I had this problem on my 2005 WK a couple of years ago.
Problem for me was solved by replacing 2 of the sensors.
To Diagnose, I simply chose one tire and deflated it to 15 lbs.
then i started the car, if the light came on solid, I knew that sensor was good because it reported a low tire. Finally to confirm, I would re-inflate to the proper Psi and watch the light go back to blinking indicating the sensor was in proper working order. Then I would move onto the next tire.
Using the process of elimination, I determined my 2 rear tires needed new sensors. Got them online for $45 each and had the tire shop down the street replace them for like $5 each.
I would try to diagnose yourself and then go back to the dealer. I have learned more on here than most dealers, so I trust them about as far as I can throw them.
nick81 is offline
post #14 of 27 Old 10-01-2012, 04:48 AM Thread Starter
vucat13
thanks for the help - what exactly is the sensor part called?
vucat13 is offline
post #15 of 27 Old 10-01-2012, 04:51 AM
tjkj2002
2002 KJ Liberty
TPMS sensor
tjkj2002 is offline
'07 WK Tire Pressure Light Constantly Flashing vucat13 WK Grand Cherokee & XK Commander Forum 1 09-27-2012 07:40 AM
Tire Pressure Monitor warning light tomdible WK Grand Cherokee & XK Commander Forum 1 04-08-2011 06:49 AM
Does your Limited display Tire Pressure? I think my 05 is idiot light only Jeeprage WK Grand Cherokee & XK Commander Forum 8 03-03-2010 03:14 PM
tail light fuse blows constantly Juice_Man ZJ Grand Cherokee Forum 17 09-01-2009 10:16 AM
Tire Pressure Warning Light AGAIN! IMFLASH WK Grand Cherokee & XK Commander Forum 26 03-16-2007 08:43 AM
