Jeep Hemi low speed/idle stalling - JeepForum.com
post #1 of 9 Old 05-12-2013, 05:24 PM Thread Starter
mrasnk
2008 WK
Hey all,
Wanted to get any opinions and pick your brains on why my Jeep likes to, and even after several repairs, still stalls! The last 5 times it has done this it was while I was either at idle or moving approx 5 miles an hour. The rpms drop and then oil lamp light comes on. It will restart in neutral. They initially found 2 bad pins in the PCM and replaced the whole unit and it was fine for about a week and a half. The temp dropped in Ohio this weekend and the issue once again showed up.
So far to date, the following have been replaced:
-Cam sensor, crank sensor, MAP sensor, EGR valve, cleaned throttle body, new PCM, and plugs done around 10k ago.
Any ideas? Would a fouled plug/bad coil pack cause a stall in a HEMI?
Specs:
2008 Grand Cherokee Overland, HEMI 5.7, 77000 miles. Just did oil and filter with 5w 20 oil, mobile one oil.
-Snks WJ
mrasnk is offline
post #2 of 9 Old 05-12-2013, 05:40 PM
lsuber
2005 WK
Could be a lot of things, but with our XK 4.7L, a TPS change and a clean air filter (ok, so the one that was in it had sorta been there a while....) has solved it so far. Was going to look into changing the IAC next, but its running much better right now, so I'm leaving well enough alone.
2005 WK Grand Cherokee, Rocky Mountain Edition, 4.7L V8 4x4 QTII
2006 XK Commander, 4.7L V8, 4x4 QTII
lsuber is offline
post #3 of 9 Old 05-12-2013, 08:27 PM Thread Starter
mrasnk
2008 WK
Now on the hemi, i think the tps in integrated into the whole throttle assembly (not replaceable-correct me if I am wrong). Do these go bad over time?
-Snks WJ
mrasnk is offline
post #4 of 9 Old 05-12-2013, 11:19 PM
WieSeL
Yes have to but the while unit I believe. Stop throwing parts at it and have someone pull pcm data as it is failing.
WieSeL is offline
post #5 of 9 Old 05-13-2013, 05:34 PM Thread Starter
mrasnk
2008 WK
That's what I already tried. It spend 3 weeks at the dealership and they ended up replacing the PCM. I do not think going back will solve anything at this point, the service personnel is clueless.
-Snks WJ
mrasnk is offline
post #6 of 9 Old 05-13-2013, 06:15 PM
LordEnki
2006 WK
Transmission fluid level correct?
06 WK Limited
Bright Silver Metallic
4.7L, QDII, Class IV hitch
245/65R17 BFG Rugged Trail T/A
LordEnki is offline
post #7 of 9 Old 05-17-2013, 04:43 PM Thread Starter
mrasnk
2008 WK
Replace the throttle body, was covered under the power train warranty...drives like brand new now! Had a throttle position issue diagnosed by dealership filing a star report with jeep.
-Snks WJ
mrasnk is offline
post #8 of 9 Old 12-04-2013, 07:26 AM Thread Starter
mrasnk
2008 WK
Still stalling, here is a video of it in the act!
-Snks WJ
mrasnk is offline
post #9 of 9 Old 04-21-2014, 04:26 PM Thread Starter
mrasnk
2008 WK
Problem lies within the transmission. Torque converter is locking in/out incorrectly, therefore causing issues. They pulled the pan, found the valve body had collapsed valves and metal shaving throughout. Torque converter now was also found to be bad. These issues caused the engine to bogg down and stall out.
-Snks WJ
mrasnk is offline
