Jeep GC Suspension Query - JeepForum.com
post #1 of 17 Old 01-23-2013, 04:40 PM Thread Starter
jayres
2008 WK
I have just purchased a 2008 Jeep GC CRD Overland, 71k, with 18" wheels etc.
Immediately I installed the only Bilsteins available for this model. While the difference before and after is truly incredible, the vehicle still has a pronounced side to side motion that is not only unnerving but uncomfortable. I am writing to ask if any one has had any luck with stopping these Jeeps from this motion?
I know one thing that I noticed at once is how high the body sits which lends to a boat-like ride with this rocking motion. Typically one installs tighter springs that also lower the vehicle, but this is usually done to get flatter cornering and my goal is just to stop the nauseating rocking.
The other alternative I investigated is to install a complete air bellows kit from Airbagit, on all 4 corners---cost is only $1,600!
I would love hear back from some members with some ideas.
jayres is offline
post #2 of 17 Old 01-23-2013, 05:18 PM
blizzboy283
2005 WK
Well you might not want to lift it but the OME HD kit completely took away body roll for me. Couple that with some srt8 or commander front and rear sway bars and the jeep will handle like a beast!
05 WK LTD 5.7L Hemi QD II Midnight Blue Pearl, Blue WK Club member #30
Intune, AFE Stage 2 CAI, BT Catch Can, Gibson Cat-back, OME HD, 255/75/17 BFG KM1s, 1.25" Spidertrax, LED Interior, Reverse & Tail Lights, 3/4" Grille, Chrome Fuel Door & handles, SRT8 Pedals, Taylor Shorties, XK knob, 4xGuard Front 4 & Rear Diff.
blizzboy283 is offline
post #3 of 17 Old 01-23-2013, 05:33 PM
TheDemon
2006 WK
It's a Jeep dude, not a fx35 It's a heavy true SUV built on a truck like suspension, unlike all the hatchbacks they're trying to pass off nowadays as SUVs that are built on car suspensions with zero ground clearance. You could lower it, but that would somewhat defeat the purpose of owning a Jeep, these things are not built for high speed maneuvers.
2006 WK Overland 5.7: SOLD!
TheDemon is offline
post #4 of 17 Old 01-23-2013, 05:53 PM
jjt250
2007 WK
I would upgrade to SRT sway bars front and rear.
2007 Grand Cherokee Limited | QDII | 3.0L Diesel | S4xC Shackles Mounts | Goodyear Duratracs
Bilstein HD Front/Rear | Rusty's 1/2" Strut Spacer | Hemi XK Front/Rear Coils | HID Projectors
jjt250 is offline
post #5 of 17 Old 01-23-2013, 05:57 PM Thread Starter
jayres
2008 WK
Great idea----where would you recommend to buy them??
jayres is offline
post #6 of 17 Old 01-23-2013, 06:35 PM
jjt250
2007 WK
I do not have these personally but there are a lot of guys that run them. You can get them directly from you dealer or online from a places like justforjeeps.com I think. I'd recommend you check out Jeep Garage (different forum). There are a lot more "street jeeps" over there and a lot of guys running SRT sway bars who can give you advice. Also, there's addco sway bars that are supposed to be an upgrade from the SRTs and I'm pretty sure you can get those from Kolak, who is a vendor on here.
jjt250 is offline
post #7 of 17 Old 01-23-2013, 10:23 PM
trax95008
2006 XK Commander
You said you just bought it, and mention it being high. Is is possible that it is lifted, AND maybe also have the swaybars removed all together? I put addco bars on my WJ and it made a big difference with body roll
trax95008 is offline
post #8 of 17 Old 01-24-2013, 05:51 AM
paroxysym
2007 WK
id personally go with an addco rear swaybar (order through kolak) and a srt front swaybar (order through justforjeeps.com). also while doing so replace your swaybar links- either with a new set of OEM or spend a couple more extra bucks and get yourself some bwoody swaybar links. all this will definitely make a world of difference in your bodyroll.
a wider tire and maybe a small spacer to widen your track down the road will also help
2007.5 WK Laredo 4.7
OEM+
paroxysym is offline
post #9 of 17 Old 01-24-2013, 07:21 AM
Radcrd
2007 WK
I have the SRT8 springs with Bilsteins and it is MUCH better. I even ran only the springs with stock shocks for a short period and must say the springs make a big difference. Slightly lower however by 3/4'' or so.
2007 WK CRD QDII, GDE HOT tune. 275/55/18'' on Sahara's, SRT8 suspension.
2000 Jetta TDI (hers)
2006 Liberty CRD (sold)
3 VW TDI's (sold)
Radcrd is offline
post #10 of 17 Old 01-24-2013, 07:46 AM
paroxysym
2007 WK
im so interested in doing this.. i just dont want to sacrifice ground clearance
OEM+
post #11 of 17 Old 01-24-2013, 08:26 AM
Radcrd
2007 WK
Mine only dropped 1/2'' front and 3/4'' rear, not even noticeable, was hoping for more of a drop as I do not do any offroad.
3 VW TDI's (sold)
Radcrd is offline
post #12 of 17 Old 01-24-2013, 09:27 AM
blizzboy283
2005 WK
Guess you missed my suggestion in the first post.
Kolak (a vendor here), or eBay.
post #13 of 17 Old 01-24-2013, 06:23 PM Thread Starter
jayres
2008 WK
Where did you buy your SRT8 springs? Did you put in all 4?
jayres is offline
post #14 of 17 Old 01-25-2013, 07:46 AM
Radcrd
2007 WK
Found used on Kijiji from a guy who lowered his SRT8. Yes I put all 4. Check the classifieds on the SRT8 forum you may find some.
3 VW TDI's (sold)
Radcrd is offline
post #15 of 17 Old 01-25-2013, 08:10 AM
brutusjeep
2014 WK
Just to keep it cheap, I bet your shocks and struts are wore out. If stock height is what you want I would start with that. Mine we toast my 50k.
2014 - Summit
Sold - 2006 GC Limited, 5.7L HEMI, Quad II. 4XGUARD Belly & Front (black powder coat) skid plates. Matrix front guard, PIAA Matrix mounted lights, 265/70 Nitto Trail Graplers MT, 1.5" Spider Trax spacers, Super Chips Tuner, OME MD Lift, 4XGUARD differential guard, JBA UCA'S.
brutusjeep is offline
