Jeep is DOA, HELP!!! - JeepForum.com
post #1 of 32 Old 06-19-2009, 05:24 PM Thread Starter
dwp1975
2006 XK Commander
I just got home about half hour ago and I parked in the driveway behind my wife's car and i turned it off. I came back out a few minutes later to move my wife's car up and get the jeep closer and it DIED!! The car won't start and I hear sputtering noises in the dash board. The info center in the speedo keeps saying "parking assistant service center". The battery seems weak since when I lock and unlock the car with the key remote it doesn't beep and the lights are dim. Also the radio has reset itself. Am I facing a serious repair or is there a chance a battery jump will help? I have a 2006 Jeep Commander BTW..
dwp1975 is offline
post #2 of 32 Old 06-19-2009, 05:55 PM
colinzj
2006 WK
If you've got a multimeter, you can check the voltage at the battery terminals. The battery warning light in the dash is useless.
On a 2006, you're pretty darn likely to be due for a new battery.
2006 WK Laredo 4x4 4.7L
1993 ZJ Laredo 4x4 4.0L Dead, sold, and rolling again
colinzj is offline
post #3 of 32 Old 06-19-2009, 06:16 PM Thread Starter
dwp1975
2006 XK Commander
I am the furthest from mechanically inclined. All the indicators come on, my radio stations have reset. Are these traits of a bad battery? Also, I am still within the 36k warranty. Would this repair fall under my factory warranty?
dwp1975 is offline
post #4 of 32 Old 06-19-2009, 06:19 PM
kudah
Jump start it and see. If the battery has failed, it is covered. Possibly just needing a jump though
Robert
kudah is offline
post #5 of 32 Old 06-19-2009, 06:24 PM Thread Starter
dwp1975
2006 XK Commander
We tried jumping it and it didn't work. Should the working vehicle run for a few minutes before I try to start the Jeep or try it right away? Sorry, for the dumb questions I just am not mechanically inclined.
dwp1975 is offline
post #6 of 32 Old 06-19-2009, 07:01 PM
kentman
kentman's Avatar
2006 XK Commander
I had the exact same thing happen on our XK a couple months ago. The battery is dead. I put a new one in, and it worked perfectly. The battery was $160. That was way more than I expected.
'06 XK Limited, 5.7L, QD II, Black, 163K
'02 WJ Overland, 4.7L HO, QD, Inferno Red, 126K
kentman is offline
post #7 of 32 Old 06-19-2009, 08:25 PM
yrkoverland
Yes if your battery is that dead you may have to leave the other vehicle run for maybe 5 or 10 minutes to try to put some charge back into your battery.
I would wait until Saturday and then take it somewhere that has free battery installation like auto zone, or advance auto parts, etc... call first to see if they offer it. I say this because you said that you aren't too mechanically sound.
I'd jump it and then drive it right to one of these places to have a new one installed.
If you think you are up to the task you can always just go buy a new battery using your wifes car for transportation and then install it yourself in the driveway to eliminate having to jump start it.
Good luck!
yrkoverland is offline
post #8 of 32 Old 06-19-2009, 08:29 PM Thread Starter
dwp1975
2006 XK Commander
Good luck!
I thought about buying my own battery. My jeep still has a remainder of the balance of the factory warranty. Can I pawn this off on Jeep? How easy is a battery change? I absolutely DO NOT want to have the truck towed. Carmax's extended warranty only covers $50 (like that helps).
dwp1975 is offline
post #9 of 32 Old 06-19-2009, 08:36 PM
weezer
battery
pep boys or autozone will check your battery for free
take it out and take it to them. good luck
weezer 98 sahara 2"bb and 31 inch goodrich ko's and a 1 inch body lift sitting in a box under my bed
weezer is offline
post #10 of 32 Old 06-19-2009, 08:41 PM Thread Starter
dwp1975
2006 XK Commander
I googled for the mopar battery it has and it says if the indicator is green which it is on mines that the battery has 75% to full charge.
dwp1975 is offline
post #11 of 32 Old 06-19-2009, 09:08 PM
SAR-Swimmer
You might try cleaning the battery terminals, and cable connections. Do you see any white powdery substance at your battery connections? If so take off the cables and useing sandpaper or a wire brush, clean the terminals until they are shiny. The cable connections can be cleaned with a small wire brush, or if you are really stuck, you can use a small knife to scrape the insides. The idea is to get the crud off the connections. Also make sure your battery connections are tight, as, if loose, you will get all sorts of weird things happening. By the way, there is a special tool for cleaning battery terminals, surprisingly called a "Battery terminal cleaner". It's got a small round brush,(think wire bottle brush) for cleaning cable ends, and an internal brush, for cleaning the battery terminals. You can get one at any auto parts store/ most hardware stores, for about $ 5-7, and it may just become your new best friend. Good luck.
SAR-Swimmer is offline
post #12 of 32 Old 06-19-2009, 09:35 PM Thread Starter
dwp1975
2006 XK Commander
It's dark out now, but I don't recall seeing any residue. The engine is pretty squeaky clean.
dwp1975 is offline
post #13 of 32 Old 06-19-2009, 09:42 PM
yrkoverland
Probably not covered under warranty as this is probably considered a wear
item like brake pads.
You could still have a bad cell in it.
If you can take it out like weezer suggested and have them load test it to be sure.
My guess is the battery
post #14 of 32 Old 06-19-2009, 09:47 PM Thread Starter
dwp1975
2006 XK Commander
That sucks, if the battery is $160 like a previous poster stated. That's not too bad but I doubt I can convince them to come to my house and change it even though I am less then 5 minutes away from the Jeep dealership.
dwp1975 is offline
post #15 of 32 Old 06-19-2009, 10:16 PM
yrkoverland
The r&i (removal and install) shouldn't be too bad if you have some tools.
There is one bolt that holds a small bracket at the bottom of the battery that keeps it in place.
And then the two terminals positive and negative and presto it's out.
If I were closer i'd help you out =)
Couple repairs planned for this weekend, will my Jeep be right by monday jeep gods ?? cherokeeghost ZJ Grand Cherokee Forum 1 11-12-2008 11:53 AM
