Jeep 2in ome Hd lift and coil spacers? - JeepForum.com
post #1 of 2 Old 05-25-2013, 05:29 PM Thread Starter
Toigan
I was jsut curious as to if i put a Jepp Wk on a 2in Ome lift. Could i put coil spacers on it as well to achieve a total of about 4in lift?? In theory it would be 2in suspension 2in body.. for a total a 4in lift. So that it could clear 33's?
Toigan is offline
post #2 of 2 Old 05-25-2013, 07:07 PM
WieSeL
Ome is about 3 in the front and some people put 1/4 to 1/2 inch spacers on top of that which gives you an extra 1/2 to 1 inch at the wheel. With 4 inch you will need aftermarket uca's and track bar. Defenitely do not do a 2 inch spacer on top of the ome. And then you run the risk of wearing out tie rods and cv's. Check out Omelet's build thread.
WieSeL is offline
jeep wk , lift , ome , suspension
