I’m removing the rough country spacer lift that was on the Jeep when I bought it and installing a OME HD lift on my WK CRD in a week or so. I’m also going to add JBA a-arms.
I notice they offer a “caster kit” which is new bushings and flat washers. Is it really needed? Has anyone used the kit or flat fender washers for the same effect, and did it work for you?
Can you provide a link? I can't find the caster kit you are referring to. I just installed their wk UCA's for lifted jeeps. Didn't order any other kit. Had zero issues with getting it aligned.
I don't see a caster kit being offered with the JBA arms.. I know I just ordered the lifted version and called it a day. if you have a 2008+ they offer sensor link brackets, but im not seeing a caster/camber/whatever kit
I'm having problems with the rough country lift. May I ask what made you decide to remove and go with a different lift? This might help me decide where to go with my lift issue I'm currently having...
for JUST an OME HD kit, just get the lifted version of their UCAs and call it a day.. theres a lot of people that are fine with JUST the UCAs. hell I have them with my OME MD and rustys spacer upfront and theyre just fine without the caster kit.
Guitarmann, the Jeep has 145k on it and I have no idea how long it was on there. The only issue I actually have is a thump when hitting bumps on the drivers front. Think it’s because the jounce bumper is not where it should be. It’s sitting on the strut and splitting open. A big clue the springs/shocks are ready for replacement is that with a 2” space lift I’m at a hair over 19” hub to fender all around. And the springs/ shocks are clearly old. It bounces too much going into turns and has excessive body roll. While new springs/shocks without spacers may not fix all of that, it won’t hurt.
I believe in doing things the right way. I’d prefer a superlift with coilovers and adjustable rear arms/track bar, but for now the budget says no. So I have new isolators and jounce bumpers and a few new bolts and nuts to go along with the OME HD and JBA arms. Would like to do it once and that’s why I’m wondering if I should try the bushing kit.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
