JBA vs. Rocky Road UCA's??? - JeepForum.com
post #1 of 27 Old 04-10-2013, 10:36 AM Thread Starter
XK1982
2006 XK Commander
Anyone have a preference as to which is better or gives the most clearance? I have the older design of the JBA's, paid $450 for them and they have my knuckle bashing my strut bc of lack of clearance. Not sure if JBA's are worth the costs since rocky roads are $339.
2006 XK Commander, 4.7L V8, Quadra-Trac II, 6.25" Modified Superlift, Jeepin by Al's front UCA's, Rusty's Adjustable rear LCA's; 35x12.5R17 TOYO Open Country MT's; Method NV305 17x8.5 wheels
XK1982 is offline
post #2 of 27 Old 04-10-2013, 11:01 AM
dsjr2006
2006 WK
I have the Rocky Roads and have a hard time imagining any other options being better designed or made. No coilover contact at full extension for me either.
'06 Limited Hemi QDII - Icon Coilovers - OME Lift w/Bilsteins - 32" 265/65R18 Goodyear Duratracs on JK Sahara 18s - Smittybilt XRC10 Comp X20 Winch
05-08 WK Service Manual PDF:
dsjr2006 is offline
post #3 of 27 Old 04-10-2013, 11:05 AM
Jeepforthewin
2010 JK Wrangler
there is a thread on here about the new design from JBA. cant remember who its by but they tested out the new ones a few times for JBA and it appeares the issue was fixed.
2010 JKU - Stock for now
2005 WK - 6" lift, 35" BFG's, a lot more (SOLD)
Jeepforthewin is offline
post #4 of 27 Old 04-10-2013, 11:06 AM
Jeepforthewin
2010 JK Wrangler
sorry for posting twice but i found the link to the thread http://www.jeepforum.com/forum/f67/j...-12-a-1438984/
post #5 of 27 Old 04-10-2013, 12:48 PM Thread Starter
XK1982
2006 XK Commander
thanks buddy! This information is exactly what I needed!!! Just called JBA and they said they'll work with me on getting the newly redesigned ones since I already blew $450 on the older ones. Thanks again for everyones help! I'll let you know how it goes!
XK1982 is offline
post #6 of 27 Old 04-10-2013, 01:18 PM
trax95008
2006 XK Commander
So what's the down side to the rocky roads considering they are over $100 cheaper? I think I'm about ready for some UCA's
trax95008 is offline
post #7 of 27 Old 04-10-2013, 01:44 PM
06JeepXKHEMI
06JeepXKHEMI's Avatar
The RRO use KK bushings which are smaller and seem to be not as stout as the JBAs.. Although havent heard of any complaints from people using the RRO, I will be going the JBA route though..
05 LJRubi Currie 4" Springs, Savvy Fox shocks, MC trackbars, MC CA's single adj lower double uppers, 37x13.50 Cooper STT Pros on 17x9 ATX Ravine, MC Overlines front, Genright rear, Revolution 5.38s, Carolina Driveline driveshafts, MCAI
06JeepXKHEMI is offline
post #8 of 27 Old 04-10-2013, 02:45 PM
Theogriff15
2006 WK
I read somewhere that the RRO's are better for lifted heights of 4"+, as opposed to the NEW version of the JBA ucas which are more suitable for 2-3" of lift. I am not positive of this fact but I recall seeing it somewhere.
2006 - 3.7L, Superlift, 265 Guard Dogs, 30" LED Bar, Bilsteins, Spidertraxx, Solid, Hypertech, Rola, Rear Led, Led Tails, S4xC Skids
Theogriff15 is offline
post #9 of 27 Old 04-11-2013, 07:29 AM
jeremyc653
2005 WK
That is true but that's only on the new design JBA is still carring the other uca for wk with more then 3 inch lift
Build Thread: http://www.jeepforum.com/forum/f67/jeremyc653-build-thread-1423295/#post14245927
jeremyc653 is offline
post #10 of 27 Old 04-11-2013, 08:47 AM
christiang26
2009 WK
I have been using the rocky road uca for 5 months on a moded superlift with no issues.
christiang26 is offline
post #11 of 27 Old 04-11-2013, 08:59 AM
tjkj2002
2002 KJ Liberty
RRO bought a set of JBA's,copied them using cheaper material.Why there cheaper.
Ever notice RRO almost always comes out with exactly the same products a few weeks/months after someone else does and they look almost identical.
tjkj2002 is offline
post #12 of 27 Old 04-11-2013, 10:56 AM
Budasac
2005 WK
The fact that they don't do any R&D also allows them to charge less. This was one of the reasons JBA re-designed their UCA the first time and upgraded the bushings so they weren't the same after RRO copied the original design.
For me the deciding factor was Customer Service. RRO doesn't have any from what I understand, where as Marlin is known to work with his customers. If you buy a product from JBA, and are unhappy, they will give you a refund without questions.
Not inly was this my experience, but when I pressed the case further (poor fit on the UCA) I was contacted by Marlin who offered to work with me and fabricate some new arms until we got the best possible fit. I think the quality and service is easily worth the extra cash.
Budasac is online now
post #13 of 27 Old 04-11-2013, 11:09 AM
Theogriff15
2006 WK
So basically if you've got more than like 4" of lift the jba ucas first gen are your option and they're not gona fit right
post #14 of 27 Old 04-11-2013, 11:27 AM
jeremyc653
2005 WK
They will if u have more lift if not as big a lift u get the second gen
post #15 of 27 Old 04-11-2013, 11:51 AM
Budasac
2005 WK
A 4" Superlift utilizes the stock UCAs due to the new Lower control arms which essentially maintain stock suspension geometry. If you want to use the JBA arms you would have to add a little more lift to about 6", which would then be about the same as a budget lift (as far as suspension is concerned).
