Jack points and stands - JeepForum.com
post #1 of 7 Old 10-19-2008, 12:59 PM Thread Starter
jeeper31
2008 WK
Want to rotate my tire. Where is the best place to jack up the vehicle and use the jackstands?
TIA
Dan
2000 Jeep Grand Cherokee Limited
8 cyl. (Sold)
2008 Jeep Grand Cherokee Overland (Black)
HEMI Club Member #4
jeeper31 is offline
post #2 of 7 Old 10-19-2008, 02:59 PM
tednelson83
use the cross members on the front (those bars that the suspension and engine attach to)
and on the rear use the differential to lift the jeep, and place the stands under the axle tubes.
Sacramento Alumni. ASE A6, A8, and L1 Certified. CA Smog License.
1993 Jeep Grand Cherokee Limited 5.2 4x4, IRO 3.5" lift, Spidertrax adapters, 32" BFG M/T's on 17" cragar soft 8's, Flowmaster muffler.
1987 Pontiac Fiero GT 2.8
Liberalism stems from the notion that it's entirely possible to pick up a turd by the clean end.
tednelson83 is offline
post #3 of 7 Old 10-19-2008, 08:02 PM Thread Starter
jeeper31
2008 WK
it's ok to use the rear diff?
Dan
8 cyl. (Sold)
HEMI Club Member #4
jeeper31 is offline
post #4 of 7 Old 10-19-2008, 09:50 PM
tednelson83
certainly is! i almost always use that to lift the rear. did it just this week to install my wheels. jack stands went under the axle tubes.
post #5 of 7 Old 10-20-2008, 08:21 AM
robpp
^^^^^^^^^^ is correct.
Here is from the manual:
1 - FRAME RAIL LIFT POINT (Floor Jack & Hoist)
2 - FRONT SPRING MOUNT (Lift point in front of spring mount - floor jack and hoist)
3 - AXLE LIFT POINT (Floor Jack)
4 - CONTROL ARM LIFT POINT (Floor Jack)
When properly positioned, a floor jack can be used to lift the vehicle (3 and 4). Support the vehicle in the raised position with jack stands at the front and rear ends of the frame rails (1 and 2).
CAUTION: Do not attempt to lift a vehicle with a floor jack positioned under:
Aluminum differential.
A body side sill.
A steering linkage component.
A drive shaft.
The engine or transmission oil pan.
The fuel tank.
HOIST
A vehicle can be lifted with:
A single-post, frame-contact hoist.
A twin-post, chassis hoist.
A ramp-type, drive-on hoist.
NOTE: When a frame-contact type hoist is used, verify that the lifting pads are positioned properly (1 and 2).
WARNING: The hoisting and jack lifting points provided are for a complete vehicle. When a chassis or drivetrain component is removed from a vehicle, the center of gravity is altered making some hoisting conditions unstable. Properly support or secure vehicle to hoisting device when these conditions exist.
Rob 007 Laredo 4.7 FFV 27X; DeBadg'd; Zaino'd; SRT8 Grill, Pedals, Strut; ClearBra; WeatherTech; LED Reverse; HIR Hi/Lo; SS Fog; Stealth Turns; 15% Tint; Stubbie; Rear Spoiler; Magnaflow; V1; 22Elite Console/Visors; Body Kit; Color Match Everything; TintedTails; K&N 63; Front Skid; QuickOilDrainValve; BatteryTender; SuperChips 91; Bilstein; Billet Window Switches; Greasable Addco Sways; RamMedic Hood; Fastman TB; BWoody Links; Kicker Upgrade w/Single Sub; AVIC F90BT Hacked; NeffyWrap ABCD; Putco LEDs; Viper 20s w/255/50; R1 Slot/Dimple w/Hawk Pro Ceramic; Whistler Mod w/FlashTech Halos
robpp is offline
post #6 of 7 Old 07-16-2013, 06:47 PM
grimah1w
1990 XJ Cherokee
Vince
2008 Overland WK 5.7L Hemi
1990 Cherokee Limited XJ 4.0L Renix -- 3.5" RE and OME, '95XJ Booster+M/C upgrade
grimah1w is offline
post #7 of 7 Old 07-16-2013, 07:06 PM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Jack the rear under the diff.
Put stands under tubes out wide.
Jack the crossmember under each side at a time at the unirail.
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is online now
Jack and jack stands 4x4jeepcrew ZJ Grand Cherokee Forum 4 10-10-2009 10:43 AM
jack points BLACKzj52 ZJ Grand Cherokee Forum 24 12-14-2007 09:06 AM
Came off the jack stands... MuddyLuxury ZJ Grand Cherokee Forum 14 07-26-2007 10:06 AM
rent jack+jack stands? Arkansas_WJ ZJ Grand Cherokee Forum 28 07-12-2006 11:08 PM
WJ Jack points? jo8243 ZJ Grand Cherokee Forum 4 11-19-2004 08:53 PM
