Issues with My O5 Grand - JeepForum.com
post #1 of 4 Old 07-29-2007, 04:29 PM Thread Starter
sww3
2005 WK
I have just recently started having a couple problems with my 05 Grand Cherokee.
1. The fan control knob only works on the highest setting and the fans are shut off in all other settings. This happened in another car that I had and it was a resistor in the switch, has this happened to anyone else or is it a common issue with these jeeps.
2. Very rarely my jeep shifts hard between reverse and drive, and then the square lights around the Selected Gear part of the dash light up and flash then shut off. No codes reading from the dealership, and they did the Recall replacement of the Transmission fill valve. Trans fluids are at good levels.
any help would be great. Thanks.
Stephen Waite
2005 Jeep Grand Cherokee
3.7 L
sww3 is offline
post #2 of 4 Old 07-29-2007, 05:48 PM
merlinTec
merlinTec's Avatar
Hi
did they do TSB 21-008-05 http://www.wkjeeps.com/tsb/tsb_wk_2100805.pdf
merlinTec is offline
post #3 of 4 Old 07-30-2007, 06:47 AM
merlinTec
merlinTec's Avatar
Hi
As for the heater sounds like the resistor I take it it’s manual zone control. Resistor is behind the glove box. Only 2 screws.
post #4 of 4 Old 07-30-2007, 06:49 AM
merlinTec
merlinTec's Avatar
Check it with an ohm meter there should be a circuit between all the terminals
03 grand cooling issues. Wolfhope ZJ Grand Cherokee Forum 3 09-08-2009 02:47 PM
96 Grand Cherokee A/C issues timewalker ZJ Grand Cherokee Forum 3 08-11-2009 12:15 PM
96 Grand Dash issues tnt.lee ZJ Grand Cherokee Forum 2 06-11-2008 06:30 PM
99 Grand Cherokee LTD various issues Tom Stewart ZJ Grand Cherokee Forum 1 02-16-2008 09:17 AM
99 Grand Cherokee issues need help! brad0502 ZJ Grand Cherokee Forum 5 09-25-2006 11:15 PM
