Issue with jeep help - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Issue with jeep help
Paracord grab handles, door limiting, etc at JeepHut.comRough Country Deals at JeepHut.comNew! JK/U skid plate system.
Unread 01-27-2015, 10:14 AM   #1
colo970
After driving the jeep and coming back home I went to start it again shortly after shutting it off maybe like 2mins and it started doing this it's been doing this for awhile now ever so often but haven't gotten a chance to get a video also the cluster says transmission over temp
Jeep wk starting issues: http://www.youtube.com/watch?v=icp-EmfXDDg
colo970 is offline   Reply With Quote Quick reply to this message
Unread 01-27-2015, 11:38 AM   #2
Tekn0logy
2006 WK
Maybe you can describe what it is doing? Cant see the video.
YouTube says: This video is private. :\
Tekn0logy is offline   Reply With Quote Quick reply to this message
Unread 01-27-2015, 11:43 AM   #3
Aclow33
2006 WK
Originally Posted by tekn0logy View Post
maybe you can describe what it is doing? Cant see the video.
Youtube says: This video is private. :\
+1
06 WK-5.7L-Modified OME HD Lift-SRT8 Volant Intake-1.5 Spacers-2014 Rubicon Wheels-22" Magnaflow
Aclow33 is offline   Reply With Quote Quick reply to this message
Unread 01-27-2015, 04:39 PM   #4
colo970
Can you try watching the video again not sure why it's private it's hard to explain it
Unread 01-27-2015, 04:59 PM   #5
GregK340
2007 WK
Still says its private
GregK340 is offline   Reply With Quote Quick reply to this message
Unread 01-27-2015, 05:07 PM   #6
colo970
Issues with jeep: http://www.youtube.com/watch?v=EHGt1eYur-I
Unread 01-27-2015, 05:07 PM   #7
colo970
Try now should be ok
Unread 01-27-2015, 06:50 PM   #8
Defender2000
2007 XK Commander
Do the ignition key dance. Does the EVIC throw any codes?
Defender2000 is offline   Reply With Quote Quick reply to this message
Unread 01-28-2015, 07:00 AM   #9
colo970
Nope and no check engine light at all
Unread 01-28-2015, 02:15 PM   #10
colo970
Any other suggestions
Unread 01-29-2015, 03:17 AM   #11
colo970
Bump...
Unread 01-29-2015, 12:57 PM   #12
tom19511
2006 WK
Starter staying engaged?
Tom
tchristopher1@wowway.com
2006 G.C.65th Anniv. Edition
2007 Liberty Sport 3.7
tom19511 is offline   Reply With Quote Quick reply to this message
Unread 01-30-2015, 05:04 AM   #13
colo970
I'm not sure what's going on this happens every so often
Unread 01-30-2015, 07:08 AM   #14
Tekn0logy
2006 WK
Originally Posted by colo970 View Post
Colo, so this is a V6 WK hard starting hot? Is it only hard starting hot or when cold also? Does it ever stall? When was the last time you changed the air filter or spark plugs? What is your battery voltage at rest, while cranking and when running? I would check all of those items first.
Unread 01-30-2015, 07:22 AM   #15
skibum555
2005 WK
check the ignition to make sure it is not sticking when you start
Jeepin ain't easy...
Proud Member of the BlAcK wK club
MEMBER #105
skibum555 is offline   Reply With Quote Quick reply to this message
