Interior Light Problem - JeepForum.com
post #1 of 6 Old 10-06-2013, 08:40 PM Thread Starter
BlackedOutWK
2007 WK
I have an ongoing issue that I cannot figure out. My interior lights won't turn on when opening the doors, yet if I manually click them on (map and rear handle lights) they work fine. I ordered all new LED's because before this happened 2 bulbs were acting up. So i switched out all the bulbs with brand new ones, still no luck. I even tried the old stock bulbs, same deal. Another weird thing that happens, is when I turn on my headlights, the dash and radio lights dim down to almost nothing. Anyone ever have any of these issues or know what could be going on?
I also checked the fuses. I wasn't sure which one it was, so I checked all the 10a fuses and they were fine, but if someone has a pic of the exact location the interior light fuse is, I would appreciate it.
Rob | 2007 WK Laredo | Modified OME HD | 255/75 BFG MT's | Black Powder Coated Moabs | Lot's of other goodies...
BlackedOutWK is offline
post #2 of 6 Old 10-06-2013, 08:51 PM
RUGLAYR
Did you check the dimmer for the gauge lights. If it's turned all the way down the interior lights won't work and the gauges will be very dim.
RUGLAYR is offline
post #3 of 6 Old 10-06-2013, 08:52 PM
RUGLAYR
And the dimmer for those is on the same part as the headlight switch
RUGLAYR is offline
post #4 of 6 Old 10-06-2013, 09:34 PM Thread Starter
BlackedOutWK
2007 WK
i don't think i have a dimmer, but ill have to check. the dash lights arent dim unless i turn the headlights on.
post #5 of 6 Old 10-07-2013, 07:50 AM Thread Starter
BlackedOutWK
2007 WK
that was it! thanks a ton ruglayr...never realized that dimmer was there. i had it at a shop getting body work done and they must have turned that switch off. glad it was something simple but now i feel like an idiot.
post #6 of 6 Old 10-07-2013, 03:52 PM
james_2k
2003 WJ
james_2k is offline
