Intake and new muffler = worse gas mileage? - JeepForum.com
post #1 of 9 Old 02-01-2010, 04:59 PM Thread Starter
TheDude584
2005 WK
I put an intake and a thrush turbo muffler on my 05 wk 3.7L. my gas mileage has gone from about 16.5 ish to a constant 13.8. I was expecting opposite results.. any ideas? (I understand its a jeep and not a prius, im just wondering)
*** Thrush Turbo is too loud btw. I dont recomend it.***
2005 Grand Cherokee Laredo V6. 2.25" RR lift and 267/75r17 Goodyear Wrangler Authority tires and 2" wheel spacers, K&N Homemade Intake, Aux lights, red calipers = my baby.
TheDude584 is offline
post #2 of 9 Old 02-01-2010, 05:24 PM
GCL06
2006 WK
Might just be a heavier foot? I've been having too much fun with the new power on ice haha. Not sure what kind of air restriction the turbo might have but that could also factor into things. The filter on your CAI might not be breathing very well (I like my Spectre).
Not to jack the thread but if it's possible I'd love to hear a sound clip of the turbo
Nick - 17 and learning
Moderately modified 06 3.7L V6 WK
GCL06 is offline
post #3 of 9 Old 02-01-2010, 07:14 PM
Lt_JWS
2006 XK Commander
Have you factored in the new tires and the size difference? Leave anything unhooked? Has it been colder then usual? Did you install the muffler yourself and was it new?
2006 XK 4.7V8 | Quadra-Drive II | Daystar 2" Lift |K&N Filter | Port and Polished Throttle Body| Magnaflow# 12256 | IAT Mod | Leather, heated seats,Command View| Factory Tow hooks | Full factory skids | Rear D-Ring Shackle
Lt_JWS is offline
post #4 of 9 Old 02-01-2010, 08:10 PM
smcginnis87
4X4WK
smcginnis87's Avatar
2007 WK
if you don't have enough back pressure you can run the possibility of getting worse MPG.... only really in turbo cars the bigger and more air out the better.... but yet it could be that you have a lift ect.
2015 WK2
--4x4WK--
smcginnis87 is offline
post #5 of 9 Old 02-01-2010, 08:12 PM
JMorash
2005 WK
was it a weld in muffler, or was it a kit.
2005 WK 5.7L Hemi
HEMI Club Member #28
3.5 Rock crawler lift.265/65R17 Toyo AT SuperChips Flashpaq MDS delete
JMorash is offline
post #6 of 9 Old 02-01-2010, 08:19 PM
GCL06
2006 WK
My Thrush Welded was a weld in; I'd assume the Thrush Turbo to be the same.
GCL06 is offline
post #7 of 9 Old 02-01-2010, 10:07 PM
Devilsmed98
I say heavier foot.
~Black WK Club Member #9~
2011 WKII Overland
2007 WK Limited[/COLOR]
1995 YJ Rio Grande
Devilsmed98 is offline
post #8 of 9 Old 02-02-2010, 06:07 AM
falcon10
All the above possibly or winter fuel?
With winter fuel my mpg drops 2-2.5 mpg
falcon10 is offline
post #9 of 9 Old 02-02-2010, 08:05 AM
tjkj2002
2002 KJ Liberty
Correct,the 3.7 likes back pressure.
Plus the AEM/K&N CAI are not CAI kits,there HAI kits(Hot Air Intake).
tjkj2002 is offline
Will tightening the pinion nut too tight cause bad (worse than before) gas mileage? 12xracer ZJ Grand Cherokee Forum 2 03-24-2009 12:14 PM
need help.. having problems after new muffler and intake.. miq228 WK Grand Cherokee & XK Commander Forum 5 07-28-2007 09:06 PM
WJ Getting worse gas mileage JoeyJoJo ZJ Grand Cherokee Forum 11 09-03-2006 07:41 PM
Gas mileage went from bad to worse? hinchcliffe ZJ Grand Cherokee Forum 12 01-20-2006 01:31 AM
Just changed spark plugs....now gas mileage WORSE! Help. natef26 ZJ Grand Cherokee Forum 13 01-16-2006 07:08 AM
