Installed a Billet Technology Catch Can on the CRD - JeepForum.com
post #1 of 77 Old 05-06-2012, 07:37 PM Thread Starter
suzieque
2008 WK
Well, I installed a Billet Technology Catch Can designed for the WK Hemi on to a WK CRD. The bracket the catch can came with had to to be flipped to fit to the strut bar of the CRD. I like the look of it. I need to show a photo of how it is connected to the airbox on the CRD.
I bought a Billet Technology catch can from a member on another site. I really wanted the BT brand and I wanted a clear container so I could check it quickly without removing.
Here is the top view of the catch can from the WK Hemi, notice the hoses are quite short. I bougtht is used from another member, $150 shipped.
Here is the side view, I love the clear container, you can see oil in it right away:
Here is the braided hose kit I bought to dress up the hoses, $30 from a local auto supply store, also comes in blue or silver fittings, I got red to match the catch can. There is is enough braiding to do some other hoses, including the raditor hose.
Here is the side view with the braided hose kit installed. I cut the stock PCV hose in half and spliced in the catch can hose on one end then on the other end I plugged hose that goes to the air intact tube. Notice the long exit hose, wonder why it's so long?
I connected the hose to the airbox in front of the air filter.
Here is the system installed first without the engine cover:
Here is the system installed first with the engine cover:
2008 WK "S" Limited bright metallic silver exterior, light graystone interior, 5 speed W5J400 transmission, June 18/2008 build, C213RE rear differential with 3.73 axle ratio, C200FE front differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, GT2056V turbo, 3.0L CRD (OM642.980)
suzieque is offline
post #2 of 77 Old 05-06-2012, 09:04 PM
p3busman
Please let us know how often you have to clean the oil out.
p3busman is offline
post #3 of 77 Old 05-06-2012, 11:01 PM Thread Starter
suzieque
2008 WK
what I've noticed so far is that driving around the city doesn't generate alot of oil. On the highway though the CRD is under boost all the time and that is when I see quite a bit of oil. I wrote down the mileage at install and I will measure it at 1800 miles, or when the container is 1/3 full, whichever comes first.
suzieque is offline
post #4 of 77 Old 05-07-2012, 02:59 PM
nostaw22
Just trying to make sure I'm following what you've done... You're using this catch can thing like a ProVent/Racor filter to capture oil, but instead of routing back into the intake just before the turbo (e.g. the stock CCV routing) you're feeding the CCV gases into the air box?
JW
1998 XJ - built for offroading
2007 WK CRD - DashHawk, for towing the XJ
nostaw22 is offline
post #5 of 77 Old 05-07-2012, 03:59 PM
Sizzlenut
Please let us know how often you have to replace your air filter.
Sizzlenut is offline
post #6 of 77 Old 05-07-2012, 04:06 PM Thread Starter
suzieque
2008 WK
JW
Yes, that is correct, and the reason is that my experience is that all catch cans still let through a bit of oil mist in the CRD. I'm using the air filter to stop that completely. Some guys would just vent it under the Jeep, but I don't want any drips on the driveway, plus using the airbox provides a bit of a vacuum to ensure a positive flow.
suzieque is offline
post #7 of 77 Old 05-07-2012, 04:07 PM Thread Starter
suzieque
2008 WK
I have a K&N air filter, so I will let the oil just lubricate the filter.
suzieque is offline
post #8 of 77 Old 05-07-2012, 05:11 PM
terrasmak
2007 WK
Anyone who is interested , look in the elephant hose mod thread, I posted a much better catch can for a cheaper price.
"Racing makes Heroin addiction look like a vague wish for something salty." -- Peter Egan
terrasmak is offline
post #9 of 77 Old 05-07-2012, 06:47 PM Thread Starter
suzieque
2008 WK
but it does not look as sweet as this.
suzieque is offline
post #10 of 77 Old 05-07-2012, 07:02 PM
terrasmak
2007 WK
But it is fully baffled and really good design. I don't drive around with my hood removed or open, so looks are not important, function is,
post #11 of 77 Old 05-07-2012, 07:50 PM
Dr. Internet
Actually, Terrasmak's installation looks more like an OEM part, so it would probably fool most Chrysler "Diesel" (sic) mechanics, except for the hardware store hose clamps. Need to find some more expensive clamps that only work once, to fit into the general schema under the hood.
Susieque's adds a lot more bling under there, but would stand out during an inspection, IMHO.
Either is better than the POS intake system Chrysler's engineers (?) sold us.
What ever happened to the class action lawsuit against Chrysler for this obviously flawed design?
Steve
2012 Black GC Overland Summit 4x4 2006 Red LJ Rubi
USN Club Hull TJ-13 TX Jeep Club #29
Dr. Internet is offline
post #12 of 77 Old 05-07-2012, 09:08 PM Thread Starter
suzieque
2008 WK
It's true, I suppose nearly any mod, whether a lift or cold air intake or wheels or catch can could be done cheaper, I was going for looks and function.
I'll be first to admit this is my fourth version of a catch can or bypass, I like this setup the best (so far). By the way I remove my catch can when my Jeep goes in for service (I make sure it can come out in 15 minutes or less when designing), so blending in to a stock look is not as important.
suzieque is offline
post #13 of 77 Old 05-07-2012, 11:02 PM
oilverland
2008 WK
Can't find it. Can you provide URL?
Thx
2008 Overland Diesel QDII, Bilsteins, Stillen rotors and pads, 156,000 miles as of Nov '16.
oilverland is offline
post #14 of 77 Old 05-08-2012, 01:11 AM
terrasmak
2007 WK
http://saikoufabrication.blogspot.co...&max-results=3 is the one i'm going with for my car and my Jeep. His site sucks so you have to look around on it. It is chambered , has mesh , really cool setup.
post #15 of 77 Old 07-01-2012, 01:59 PM Thread Starter
suzieque
2008 WK
Here is my catch can at about 1600 miles, 50% highway miles, 50% city miles.
I dumped this into a measuring cup, it's a bit less than1/4 cup of oil. So, do the math, if you've not had a catch can installed, and your vehicle has 45000 miles on it, your intake may have injested 7 cups of oil!
Here is my hose from the catch can going to the airbox...
I found an oil stain in the airbox that I cleaned out, the liquid you see is water after I washed it, I will let it air dry and then reinstall the filter, so some vapor gets through the catch can and to the output hose. I removed the K&N filter and installed a STP air filter I bought from Pep Boys for $11.
suzieque is offline
Billet Tech Oil Catch Can Install Pix: Hemi Marcus86GLHS WK Grand Cherokee & XK Commander Forum 2 11-01-2011 04:24 PM
catch can question: billet vs. generic mailforjon WK Grand Cherokee & XK Commander Forum 15 04-24-2011 07:48 PM
CRD - to catch can or not to catch can dilema - what to do manitoman WK Grand Cherokee & XK Commander Forum 4 07-22-2009 12:20 PM
ESP Technology,..this is a good site.... coyote runner WK Grand Cherokee & XK Commander Forum 17 11-05-2007 05:33 PM
ORT (Off-Road Technology) version of WK coming? Colo.kid WK Grand Cherokee & XK Commander Forum 2 06-28-2007 07:25 AM
