Installation on Rustys 2inch lift - JeepForum.com
post #1 of 5 Old 06-21-2009, 09:51 PM Thread Starter
Moparcherokee99
My Friend has a 2005 Wk. He asked me to help him install his lift that he bought. Its a rustys 2 inch. Is this a pretty easy lift to install? Is there anything that i need to lookout for? Thanks alot.
Moparcherokee99 is offline
post #2 of 5 Old 06-22-2009, 07:36 AM
BonesWK
2006 WK
the install to the back is fairly straight forward. The front is a little more tough. Make sure you have a ball joint puller, spring compressors etc.
also do a search on here, there is a lot of other info out there....
Ryan
2006 Black WK Limited 4.7 4x4 QD II SOLD
Current - 2008.5 Mazdaspeed 3
If you want to achieve greatness, stop asking for permission
BonesWK is offline
post #3 of 5 Old 06-23-2009, 08:13 AM
MOUNTAINGARAGE
MOUNTAINGARAGE's Avatar
My wife and I did a 2 inch spacer lift last night in 3 hours on our XK. No spring compressor, no ball joint puller, no lift. Spent at least 30 minutes looking for nuts that were left out of the kit.
Custom Built NP231's Complete Teralow & 2wdlow Units available.
MOUNTAINGARAGE is offline
post #4 of 5 Old 06-23-2009, 09:34 PM Thread Starter
Moparcherokee99
Thanks .the only thing im unsure of is how to remove the struts up front and put the spacer in there. How do i do that? the instructions just simply say remove it. thanks alot
post #5 of 5 Old 06-25-2009, 11:45 AM
MOUNTAINGARAGE
move the Coolant reservoir (push nut/&8mm), and fuse box(pry tabs/&10mm) from the inner fenders, remove 4 nuts from each strut tower.
jack up/ use jack stands, you will need your jack under control arm.
remove sway bar link bolt from LCA
Remove bolt from lower strut fork on LCA.
Remove top Ball joint nut
remove 10mm bolt from brake line on fender well.
remove sensor wire from back of strut.
remove nut from tie rod end
put jack under LCA ball joint nut, leave 1-2 inche space for lca to drop
push down on rotor while hitting upper spindle on UCA ball joint, nice clean direct hits with BFH
it should drop down, do the same thing with the BFH on tie rod end.
Remove the strut, bolt on the spacer, evenly few turns at a time until tight.
Now reverse
probably missed some stuff...done off of memory...good luck,
or try these:
http://www.teraflex.biz/products/wk-...-lift-kit.html
2inch poly spacers ontop of 4inch lift? JkTheItalianoWJ ZJ Grand Cherokee Forum 6 08-07-2009 09:49 AM
Rustys 2inch or 2.5 inch???????? kneegrows ZJ Grand Cherokee Forum 3 12-20-2008 04:08 PM
04 GC Special Edition 4x4 2inch Lift Questions: Best4x4 ZJ Grand Cherokee Forum 4 04-30-2008 03:05 PM
rustys lift? 1997zj ZJ Grand Cherokee Forum 5 02-22-2005 06:13 PM
shocks for 2inch BB Lift onlyone ZJ Grand Cherokee Forum 4 03-06-2004 01:35 PM
