Injector Seal 2008 WK Diesel - blown again! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Injector Seal 2008 WK Diesel - blown again!
Ruffstuff XJ Unirail Channel Reinforcement....Even Better Heim Pricing! From RuffstuffUSA Standard Chromoly Front Axle Shaft Kits with Dana 30 4
Unread 09-03-2014, 02:25 PM   #1
Shmigsy
2008 WK
Hi everyone,
Recently got an error codes for a glow plug. 86000km/53000 miles since the first change at 100000km and 4 are still in good shape) .
However I was also greeted by a melted rubber baffle. Apparently there had been blow by for a while and it melted it. So the seal and the return line are toast. Real mess that took me hours to clean up.
I didn't want to start to mess with the injectors so I brought into the dealer. Of course as usual its all doom and gloom and only one mechanic is qualified to work on the diesel and he has never replaced an injector seal.
He seems trust worthy so I gave him the job.
Today I got a call that in order to get to the cylinder 5 injector they would have to remove the engine crossbar, and in order to do that, also the wiper fluid container and fuse box - so tack n at least 1.5-2 hrs.
Merlin - if you are still out there would you or anyone else have the units called for for removing the injector. The shroud, and rubber baffles are already out as I could not put them back on. and the elephant tube is off as they had to remove it to access the the fuel filter.
Photos show good side vs. bad
Thanks
Shmigsy is offline   Reply With Quote Quick reply to this message
Unread 09-03-2014, 04:11 PM   #2
furiousbudy
2008 WK
Did one on my jeep, get an injector puller for the mercedes OM 642 engine, a stretch bold, and the copper seal. The worst part is to clean the mess!
2008 Grand Cherokee CRD Limited 163,000KM
furiousbudy is offline   Reply With Quote Quick reply to this message
Unread 09-03-2014, 05:33 PM   #3
TangoTango
2008 WK
that is about what mine looked like, looks way worst than it is, that is just the foam injector shield melted. basically the $3 copper o-ring blew out. -- how many miles on it now?
best to replace ALL the 6 o-rings. I made the mistake of just doing the 1 side and was replacing the other side about 4 weeks later... so I've done it twice now.
I didn't have to remove the wiper cleaner container or the fuse box... or the tires ... LOL
the first day you need to soak it over night maybe 2 nights with injector cleaner. . the injectors then come out by hand... then there is a trick to getting the old o-rings out.
TangoTango is offline   Reply With Quote Quick reply to this message
Unread 09-04-2014, 02:16 AM   #4
Red_liner740
So thats where that melted black crap comes from. I went to look at an 08 CRD for my buddy and there was black melted foam all over the drivers side. I freaked out thinking the engine caught fire, but everything else was untouched.
So when the seal blows, the cylinder gasses melt the foam covers? What if the covers are not on?
Red_liner740 is offline   Reply With Quote Quick reply to this message
Unread 09-04-2014, 03:38 AM   #5
ggrassmid
subscribed...
ggrassmid is offline   Reply With Quote Quick reply to this message
Unread 09-04-2014, 05:43 AM   #6
scootr29
scootr29's Avatar
2008 WK
Originally Posted by Red_liner740
So thats where that melted black crap comes from. I went to look at an 08 CRD for my buddy and there was black melted foam all over the drivers side. I freaked out thinking the engine caught fire, but everything else was untouched. So when the seal blows, the cylinder gasses melt the foam covers? What if the covers are not on?
My covers have been off for years....
Silver WK Club Member #1
2008 CRD QT2
scootr29 is offline   Reply With Quote Quick reply to this message
Unread 09-04-2014, 05:53 AM   #7
TangoTango
2008 WK
Several people leave them off, which might be better as you can visually see the problem right away. If they are off and an o-ring goes, you're going to see the diesel leak right away. I'm not sure of thier purpose other than a sound sheld and to hide issues.
Unread 09-06-2014, 07:38 AM   #8
Shmigsy
2008 WK
Update -
I did not have the time this week to attempt to do it myself so let them go ahead.
The big issue is the return line. They cannot read the serial number from the engine (illegible) and there are two different return lines. Anybody know any other method of finding the engine serial number?
The return lines are $275+ a piece but I only need the 6 inches and plastic clamps burned by the blow by. It is sold in its entirety. The mechanic jimmy-rigged a 'very-temporary repair.
Will look for aftermarket or call the wrecking yards ...
They did end up moving the strut tower and box. The entire job cost $290 all in. I will no doubt do it myself next and leave the baffles off.
There was no indication that this was happening; no performance loss, no sound, but I occasionally thought I smelled diesel or something raunch coming in through the vents, but I assumed it up to be the diesel that drips from the elephant tube burning and being blown into the vehicle.
Its still a mess - any recommendations for cleaning this stuff off the engine? Did the best I could with degreaser...
Unread 09-06-2014, 07:42 AM   #9
Shmigsy
2008 WK
TangoTango - sounds like a good idea. I think the removal had to do with getting at the return line also. Did you replace your return line? A trick?
Unread 09-06-2014, 07:45 AM   #10
Shmigsy
2008 WK
Furiousbudy - what did you clean it with. I want it as clean as possible because of
1. To see if it starts to occur again and not be masked by the old black residue
and
B. OCD
Lol
Unread 09-06-2014, 09:00 AM   #11
TangoTango
2008 WK
It is easiest to clean the mess with the injector cleaner.
There is only (1) return line for the WK, it is the one with the "90", The other return line is for the sprinter motor and does not have the "90" that t-taps into the return line with a clip and will not fit. Too bad as it is way less $$$
The whole return line is $138 retail, the Max-suggested-retail is $275. Sometimes you can buy the return line for $99. (my last one went to Quebec) They are made in poland.
If you use a part of a hose the connector tube needs to be brass, they are really had to find in the right size, I have a few of them.
If you find an engine in a wreching yard let me know, but I have not see even (1) engine being parted out.
Unread 09-06-2014, 09:23 AM   #12
TangoTango
2008 WK
I replaced the return line also, and had no need to remove all that stuff.
The trick is in cleaning out the injector cylinders, if it's not done the injectors will not come out nicely next time.
The problem is these parts cannot be re-torqued. The o-rings a soft copper metal, and I suspect it will need to be done again in about another some what less than 70k miles so that it's done before it happens.
Unread 09-06-2014, 11:17 AM   #13
Shmigsy
2008 WK
Thanks for that! I will look for it. Ultimately if it ends up being $99 I will replace the whole line, but I am guessing you bought extra brass connectors? do you recall where you bought them?
700000 miles seems ok. The first seal on injector 2 and the entire injector and seal on number 3 went pre-maturely at 55 miles and was replaced under warranty.
I have 185000km (115000 miles) on it now and these are the only problems other than regular wear and tear (tires, brakes, glow plugs) so far (touch wood). The Front brakes where only done at 155000k rear at 130000 - pretty good for a 4500 lb truck I would say!
Unread 09-08-2014, 11:51 AM   #14
Shmigsy
2008 WK
TangoTango where did you see the return line for $138/$99?
Unread 09-08-2014, 05:47 PM   #15
TangoTango
2008 WK
the guy from quebec got the last one that was $99 ... the next best deal are the ones that are $133 at FCP
http://www.factorychryslerparts.com/...ssembly=707957
