Info on Cupped Tires? (CAUTION, Toyota Tech Involved) - JeepForum.com
post #1 of 4 Old 09-22-2012, 11:02 AM Thread Starter
LilyBayXJ
Hey guys, I'm in need of a schooling on IFS rigs, having owned nothing but solid axle Jeeps. Just a warning in advance, it involves my '07 Tacoma, so if you've got nothing to say but, "Toyota sucks," ect., please take it elsewhere. I figured you guys would likely be the most knowledgeable on the topic, so any help would be greatly appreciated
I've been a long-time member of the Jeeping community, having owned many Jeeps over the years. I've become fairly knowledgeable with mechanics, I've always done my own repairs. However, I've never owned a vehicle with IFS before, and know basically nothing about it's design.
I recently purchased a 2007 Access Cab 4x4 with 191,000 miles on it, for the steal price of $5,000. It's in mechanically good shape NOW, but it's had some recent work done, including new brakes all around and new CV Shafts up front.
The truck came with a set of 245/75/16 Cooper Discoverer S/T's on it, Load Range E. The tires have less than 10K miles on them. However, the tires that were previously on the front got cupped pretty bad from the worn CV's, and are worn down to about half-tread. (That's some serious tread wear!) The tires that were originally on the rear look in brand new condition.
Now, the PO replaced the front CV shafts and rotated the tires front/rear so the good tires are up front and the cupped tires in the rear. The cupped tires are bad enough to shake the whole truck between speeds of 20-80 MPH. Also, the shaking is felt in the steering wheel when the brakes are applied, which would lead me to believe warped rotors, but the rotors are new?
So, what would you guys do? Take it in for an alignment and have them re-balance the tires? Run it and wait for the cupped tires to wear down, or replace the two cupped tires? Replace all four?
FYI, for those unfamiliar, we're talking IFS up front, Solid Axle rear.
What're your thoughts? Thanks!
-Walt
2006 LJ - 4.0L, NSG370, 31's
2001 XJ - 4.0L, AW4, 3.5" lift, 31's
1997 TJ - 2.5L, AX5, 2.5" lift, 32's - Sold
1983 CJ-5 - Stock - Sold
LilyBayXJ is offline
post #2 of 4 Old 09-22-2012, 12:02 PM
sk1er18
2007 XK Commander
CV axles don't cause cupped tires. Check the shocks/struts and get an alignment.
For the cupped tires on the rear, make sure they're reverse direction from what you had on the front. See if they'll rebalance and if they do they should eventually smooth out.
-Matt
sk1er18 is offline
post #3 of 4 Old 09-22-2012, 12:04 PM
sk1er18
2007 XK Commander
If the PO hammered the rotors to get them off while changing the CVs he probably warped them.
-Matt
sk1er18 is offline
post #4 of 4 Old 09-22-2012, 12:21 PM Thread Starter
LilyBayXJ
Awesome, thanks a bunch for the advice. I'll have it aligned and re-balance the tires, and probably replace the shocks and struts then.
Looking for some good info on Tires for me WK White_Shark WK Grand Cherokee & XK Commander Forum 21 08-25-2012 11:28 PM
Cupped GY Forteras; looking for inexpensive replacement tires EugenetheMagic WK Grand Cherokee & XK Commander Forum 11 01-16-2012 01:37 PM
upgrading tires need info...... bluengoldjimmy ZJ Grand Cherokee Forum 12 03-05-2009 11:30 PM
WJ BB + Wheels & Tires Info Needed 86Spider ZJ Grand Cherokee Forum 20 01-19-2009 03:42 PM
caution-------------washing the engine ---------caution badnews ZJ Grand Cherokee Forum 16 09-23-2003 11:34 PM
