Improving Gas Mileage - JeepForum.com
post #1 of 10 Old 07-10-2013, 08:08 AM Thread Starter
HemiJeep7
2010 WK
Is there anyway to improve gas mileage on the WK Grand Cherokee? I'm only getting about 10 MPG and I have to refuel about every other day.
HemiJeep7 is offline
post #2 of 10 Old 07-10-2013, 08:26 AM
SSF556
2008 WK
Get a diesel....
Silver WK Club Member #1
2008 CRD QT2
SSF556 is offline
post #3 of 10 Old 07-10-2013, 08:43 AM
Jeepforthewin
2010 JK Wrangler
Go easy on the skinny pedal is the easiest way to improve it! How long has it been since you changed the spark plugs? I went from getting 11.5 to barely 12 MPG's to 13.5 after i replaced my sparkplugs!
2010 JKU - Stock for now
2005 WK - 6" lift, 35" BFG's, a lot more (SOLD)
Jeepforthewin is offline
post #4 of 10 Old 07-10-2013, 09:47 AM
90grandoneer
90grandoneer's Avatar
2006 WK
First, do a search and you'll find many threads on this subject. There are many ways but, as said, driving habits are the biggest factor. Tire pressure is also a biggie. I run 40 PSI in the fronts, and 38 PSI in the rears. Other than that the best way is to increase the Volumetric Efficiency (VE) of the engine. This is done by improving the flow of air through the engine.....mainly intake, head port/valve size, cam timing, and exhaust. With our Hemi's, IMO, the biggest weak spot is, by far, the exhaust system, specifically the small "log" style manifolds. Also, the transmission shift schedule can adversely affect fuel economy. With my mods. (see signature) I get about the same as others in town (~13-14 mpg), but on the highway my range is 20-24 mpg, with a normal of around 22 mpg. Remember these things (4WD Hemi models) weigh ~4800 lbs. without you and any stuff you're carrying. I figure mine, with me, the wife, a full tank of fuel, and camping equipment runs a little over 5500 lbs. In town, the normal weight is the biggest problem......moving the mass from a stop everytime.
Currently I am doing a little test with mine. I went to the drags this past weekend and changed the WOT upshifts from 6000 RPM to 6200 RPM. I was in a hurry and didn't insure my custom shift schedules were still installed and they reverted to the canned ones in the tuner. I've noticed that my MDS works a whole lot less now, and after filling up my FE is down almost 2 mpg, so far. I'll do a couple mileage tests to verify if this continues, and I'll have to return it to the stock tune when I take it in to the stealer for the transfer case actuator recall. That should be real fun then.
06 GCO, Dk Khaki, QDII, Flshing Hi 3rd Bk Lt, MDS "ON" Lt, Airtab Vortex Gens, Debadged, Fumoto Drain Valve, BT Catch Can, Chopped EGR Tube, SRT8 CAI, K&N Filter, Sonnax Trans Line Press Booster, SC Tuner W/Adv Trans Tune App, DS Tuner, Cust tubular hdrs w/3 in Magnaflow/Xlerator AP Exh Sys, Bilsteins, SRT Springs/Sways, Cust Eng Cvr, SRT8 frt/rear bumpers, FRI Sidewinder Cam/6.1 valvetrain, SLP 25% UD Pulley, BBK true 90mm T-Body, SOS Ign Coils w/.060 spark plug gaps, SRT Reps with 265/45&295/40X20's.
90grandoneer is offline
post #5 of 10 Old 07-10-2013, 10:47 AM
bhawks28
2014 JK Wrangler
this topic comes up, what...once a week?
First off, you have a Jeep. Don't expect good gas mileage.
https://www.google.com/search?q=site...gas+mileage&oq
I clicked up to page 5 on the Google results and there were STILL threads about this topic.
2014 JKU Rubicon
bhawks28 is offline
post #6 of 10 Old 07-10-2013, 04:08 PM
90grandoneer
2006 WK
To give you an idea on the lousy stock 5.7 exhaust system, here's a link to the thread I did on the differences between the stock 5.7 WK and LX "log style" exhaust manifolds. You can see that the LX ones are quite a bit better than the WK ones.
http://www.jeepforum.com/forum/f67/b...-7-wk-1174042/
post #7 of 10 Old 07-10-2013, 04:27 PM
BoraBora
2015 JK Wrangler
Search bar. However the main way to improve gas mileage is to go easy on the gas pedal and try and avoid stop and go traffic. Going 55 mph also is the sweet spot for the best gas mileage. We drive Jeeps...poor gas mileage is a given. At least it's not an FJ or Hummer
'15 JK 2.5" lift on 35's
'06 WK 3.5" lift on 33's (Sold)
BoraBora is offline
post #8 of 10 Old 07-10-2013, 07:24 PM
johngreen1234
2010 WK
On the freeway or rural highways, I get around 19 mpg. Burn a tank of gas on stop and go errands, I end up around 15-16 mpg. I can imagine that true city driving (which I try to avoid at all costs) would really cruch the mileage.
johngreen1234 is offline
post #9 of 10 Old 07-10-2013, 07:26 PM
sebastien
2006 WK
make sure your tire pressure is good..
http://www.blacksheep4x4s.org/
sebastien is offline
post #10 of 10 Old 07-10-2013, 08:10 PM
Butterjeep
2015 WK
Make sure you have fresh spark plugs.
2014 Mustang GT Track Pack
2015 WK2 Limited 4x4
Butterjeep is offline
