Idle Dips at the lights - JeepForum.com
post #1 of 4 Old 04-12-2013, 07:46 AM Thread Starter
matt777
2005 WK
My '05 GC runs great at 240km. However, when you come to a stop in gear the idle drops to 400 rpm and then recovers. The warmer the ambient gets the more it does it. It didn't seem to have this problem when I bought it early in the winter when the temps were cold but now that they are above freezing it does it more. When it was very cold it would occasionally stall when you stopped when the engine was cold. There are no codes and the dealer can't help. They said it might be transmission bump stop?? but I think that is something different. Any ideas?
It has new plugs, IAC and I cleaned the throttle body already .I might just start replacing sensors
matt777 is offline
post #2 of 4 Old 04-12-2013, 11:09 AM
caulk04
2008 WK
4.7? I had that trouble with my Dakota years ago. Tried a new tps first, nothing. The iac did it. Seems hit or miss for which one fixes it, though usually one will.
08 Limited Hemi - wheels, tires, springs...ya know, stuff
caulk04 is offline
post #3 of 4 Old 04-12-2013, 07:43 PM Thread Starter
matt777
2005 WK
Yeah I'll either change the TPS, inlet air temp or MAP sensor next.
matt777 is offline
post #4 of 4 Old 02-15-2014, 11:18 AM Thread Starter
matt777
2005 WK
The problem seems to be that it was almost 1 quart low.
matt777 is offline
