I want to help others installing lift kits - Page 2 - JeepForum.com
post #16 of 17 Old 04-19-2012, 03:46 PM
cby7715
2005 WK
Putting my OME lift on this weekend...
So if I read this thread correctly, if that lower strut bolt won't come out, I can just remove the upper control arm and lean the strut out away from the engine bay to put the new strut and spring on the fork?
05 WK 4.7 QTII: Pinch weld...1.5" Spidertrax...Mesh Grill...OME HD...265/70R17 Goodyear Wrangler Silent Armors
07 JK Sahara: 2" RC Spacer Lift...33x12.50 BFG A/T KO's...Black Mesh Grill
cby7715 is offline
post #17 of 17 Old 04-19-2012, 07:32 PM Thread Starter
vada9
2007 WK
when i did my OME i did not remove the upper control arm..its not needed. It is only need to do that if you are doing a budget boost kit. bc the entire strut put together with the pucks are to long..but with the OME the size is close to the same as stock.
vada9 is offline
bolt , lift , ome , seized control arm bolt , stuck
WJ Lift Kits aagill225 ZJ Grand Cherokee Forum 17 07-11-2013 09:33 PM
Lift Kits Trimble96ZJ ZJ Grand Cherokee Forum 7 04-20-2011 06:48 PM
installing ome lift tomorrow...just like installing shocks & springs? osd WK Grand Cherokee & XK Commander Forum 10 07-30-2010 12:38 PM
Any Lift kits to lift a 99 grand cherokee? Jeepfolk ZJ Grand Cherokee Forum 6 05-20-2007 11:54 PM
BB Lift Kits..and other ?'s speedfreak04 ZJ Grand Cherokee Forum 10 08-05-2006 11:18 PM
