HVAC panel lights - JeepForum.com
post #1 of 10 Old 03-01-2013, 08:20 AM Thread Starter
afhanson72
HVAC panel lights
2005 WK-All of my lights stopped lighting up on my HVAC panel. I know my problem is no power to the wire because I had spliced some after market gauges into it and they no longer light up either. All my fuses are good. Anyone have an idea as to why its not getting power to it? All my other dash lights are working. Thanks!
Al
94 YJ - Plenty of mods
afhanson72 is offline
post #2 of 10 Old 03-01-2013, 09:44 AM
huntb
2008 KK Liberty
They are incandescent bulbs that more than likely burnt out... I just replaced my buddies lights a few days ago with LEDs
huntb is offline
post #3 of 10 Old 03-01-2013, 03:08 PM
w1pf
Who, me?
w1pf's Avatar
2007 WK
hvac, the two switch bars, the shifter, and the xfer case switch are all on the same circuit. It is driven by the instrument cluster, there is no separate fuse for it. If in fact that circuit is dead, you might be heading for a new cluster. Fuse 10 in the IPM *might* be something to look at.
the hvac and switch bar lights are incandescent, and they do burn out. Some info in http://www.jeepforum.com/forum/f67/h...thread-1334788 ...
2014 WK2 Overland 5.9L
2007 WK Limited 5.7L
And some past Durangos
Red WK #19, Hemi #68.. I think..
Durango Owners Club DOTY 2011
"Must have been that yesterday was the day that I was born"
w1pf is offline
post #4 of 10 Old 03-01-2013, 04:38 PM Thread Starter
afhanson72
OK, thanks. I didn't notice the shifter or transfer case switch. I will double check all that.
Al
post #5 of 10 Old 03-01-2013, 05:27 PM
JackB1
2008 WK
Just a tag on question. If one replaces the HVAC incandescent bulbs with LEDs are they as bright?
JackB1 is offline
post #6 of 10 Old 03-01-2013, 05:42 PM
Jaashua
2005 WK
I think the point of using them is they are brighter?
Jaashua is offline
post #7 of 10 Old 03-02-2013, 04:46 AM
w1pf
Who, me?
w1pf's Avatar
2007 WK
The HVAC LEDs are about as bright as the bulbs, if you use the right LEDs and align them correctly.
The switch bar LEDs can be amazingly bright, I recommend a fairly large resistance to tone them down..
w1pf is offline
post #8 of 10 Old 03-07-2013, 01:27 PM Thread Starter
afhanson72
Thanks! It was this fuse. All fixed!
Al
post #9 of 10 Old 03-08-2013, 05:45 PM
w1pf
Who, me?
w1pf's Avatar
2007 WK
Another satisfied customer!
w1pf is offline
post #10 of 10 Old 03-11-2013, 07:00 PM Thread Starter
afhanson72
Yes! Thanks again!
Al
