HOWTO: Replace the MTC Blower Motor Resistor - Page 4 - JeepForum.com
 1Likes
post #46 of 57 Old 10-25-2013, 11:08 AM
croth
2005 WK
I have replaced the resistor pack on my '05 at least three times. The last one lasted about three weeks. Soooo, I figured the blower motor was drawing too much power and changed that out, (it was squeaking anyway). Two days later, driving along, suddenly start seeing smoke coming out from under the dash!! Turned the fan off and it went away!! Got home, got under the dash, tried the fan...... nothing but high speed again.
Tried to pull the plug off the resistor pack, couldn't get it off! It welded itself right to the resistor pack.
I did get it off the resistor pack, completely melted the two outside connectors, wires were burnt an inch up from the connector.
The new harness has much larger wires than the original did.
Oh well, live and learn!
Craig
croth is offline
post #47 of 57 Old 11-11-2013, 05:20 AM
Sighn
mouse?
Originally Posted by LifeOnABoard View Post
This just helped me get a mouse out of blower. Oh my beejesus it stank! To drop the motor just take off the shield below the glove box and then take the 6 torx screws out of the bottom of the motor. Then pull down!
Now I get to eat dinner then go clean out the blood.
I found one in my blower too. Now to find out how it got in, and screen off the entrance!
Sighn is offline
post #48 of 57 Old 12-06-2013, 05:44 PM
98jgc
2005 WK
Just did mine, great and super easy to follow write up, I found it easier to cross hands when manipulating the bump stop things right for left , left for right. It felt more natural. Anyway one of the wire blue/grayish colored wire look was a little burned up looking, as was the connector on that single outermost pin. I plugged it in and it worked fine. I'll probably need to do the upgraded harness soon. Part was 8.00 on ebay shipped, so if I need another mehh who cares. And yes this job is 10 minutes tops - Don't be afraid it is a 1/10 in difficulty.
98jgc is offline
post #49 of 57 Old 04-05-2014, 01:10 PM
wootenjs
I have the reverse of this, plenty of air on lowest and intermediate settings, but nothing on highest setting. Could it still be resistor?
wootenjs is offline
post #50 of 57 Old 07-01-2014, 06:37 PM
bknox0928
Help! :)
I found this post to be SO helpful, very easy to DIY with all the pictures. Any ideas on what else could cause the same thing? My AC would only work on full blast in my 2005 Grand Cherokee. We replaced the blower motor resistor but it didn't fix the problem, any suggestions on what to try next would be greatly appreciated!
bknox0928 is offline
post #51 of 57 Old 08-26-2014, 11:32 AM
stark_WK
2005 WK
I have had this problem for a year and I thought it was the knob that controls the AC!!! I wish I had seen this post sooner!
Swapped out old resistor, put in new one. Everything works fine... except the backlight to the information panel and shift panel don't light up.. I think I read somewhere it's actually a faulty switch in the headlight switch assembly on the steering wheel.
I had difficulty removing the connector to the blower motor resistor, and when it finally came loose, I noticed both end terminals look black (burnt, melted).
bknox, I would guess it might be a faulty contact on in the knob that controls the AC?
stark_WK is offline
post #52 of 57 Old 09-04-2014, 11:28 AM
kendog81
Blower motor
Much thanks!!! (too hot not to have the AC working properly) Time for that cold Beer!!
kendog81 is offline
post #53 of 57 Old 12-10-2014, 05:51 PM
ladyjen
Originally Posted by jager00 View Post
God write up. I was actually trying to do it the other day but didnt know which screws to take out so I just didnt mess with it lol
God wrote that up? and here I am thinking the dude was only human!
ladyjen is offline
post #54 of 57 Old 12-11-2014, 01:35 PM
BrooklynWK
2005 WK
I'm done using aftermarket blower motor resistors and blower motors. Not worth it. I replaced a blower motor because it was making noise after having it for less than a year. Some things are not worth buying aftermarket. Just spend the $$ and get mopar stuff.
BrooklynWK is offline
post #55 of 57 Old 12-14-2014, 02:45 PM
Walt
2008 WK
Agree with you. There are just certain components that are not worth the few dollars you save when they have to be replaced more frequently. I believe heater blower motors are one of those. Mine start to die after 3.5 to 5 years ( my 4th Grand Cherokee).
HEMI CLUB MEMBER #45; SILVER WK CLUB MEMBER #13
'08 WK GC Limited. 5.7L HEMI. Quadra-Trac II. Bright Silver Metallic. Class IV hitch.
Michelin LTX M/S tires. Fumoto oil drain valve. Billet Technology oil catch can.
Walt is offline
post #56 of 57 Old 12-16-2014, 07:41 PM
00RedWJ
2006 WK
I replaced my resistor and a few months later the fan stopped working intermittently but would come on with a good whack to the glove compartment box. I found rock auto had the resistor complete,with new harness for $12 (link below). Soldered in the new harness and kept a resistor pack for a spare. Been fine now for a year The old harness was pretty fried, apparently not sufficient gauge wiring.
http://www.rockauto.com/m/mobilecata...&parttype=6557
2000 Red Laredo WJ
4.0 with Selec-trac - Sold
2006 Black Laredo WK
3.7 with 95,000 Miles
00RedWJ is offline
post #57 of 57 Old 08-10-2016, 12:21 PM
donp815
2005 KL Cherokee
Jeep blower resistor
Very nice description. Have looked for this for 2 years. Paid mechanic to replace resistor twice. 2nd time, still wouldn't work. He did it without removing glovebox. I couldn't figure glovebox out until I read your writeup. I now have the box hanging and am able to reach the plug. Wiggle it up and down and blower runs, but when released, it shuts off again. I can't get the box to come clear out. Have tried all positions and no luck. Mine is 2005 Grand Cherokee Laredo and pix look just like yours. Would be nice to see a pic of the glove box door when it is off. I realize this is an old post and don't expect a reply.
THANKS AGAIN!!! FOR A VERY INFORMATIVE POST!!!
donp815 is offline
anyone know how to replace the blower resistor? yepits2wd WK Grand Cherokee & XK Commander Forum 3 08-05-2009 01:38 PM
Wired up blower motor power module - do I need to replace blower motor? sniperdude ZJ Grand Cherokee Forum 0 04-19-2009 02:33 PM
HELP! Blower Motor, Blower Motor Resistor Fix Already Attempted... No Luck! DJGWJ ZJ Grand Cherokee Forum 3 12-26-2008 12:51 PM
Blower motor resistor 93ZJbeast ZJ Grand Cherokee Forum 6 02-04-2007 06:54 AM
Blower motor resistor eddiecai ZJ Grand Cherokee Forum 0 08-31-2006 07:40 PM
