HOWTO: Replace the MTC Blower Motor Resistor - JeepForum.com
 1Likes
post #1 of 57 Old 12-15-2009, 10:24 AM Thread Starter
colinzj
2006 WK
Since this comes up with regularity, I tore apart my perfectly good interior to take photos.
Tools Required
1. Torx Bit & Driver — I think it's a T15 or T20. If you've bought a bit screwdriver in the past decade, you should have the one you need.
Time Required
15 minutes, tops, if you've never done it before.
Under 5 for repeat visits.
Why Are We Doing This?
You have the manual air conditioning system and only reliably get air on high.
The German resistor pack Daimler specified most likely has committed or is committing suicide.
Step 1: Remove the Damper
The guts of the HVAC system are hidden behind the glovebox, so it needs to come out. Begin by opening the glovebox.
There are a couple things holding the glovebox in. The first thing to deal with is the damper. If you look on the outboard side of the glovebox, you'll see this:
It keeps your glovebox door from slamming open. It's held on with a simple pin-and-groove system:
Grab the beefiest part of the damper arm and pull it toward the rear of the Jeep so it unlocks. Gently pull the pin out of the big hole so the damper arm is free of the glovebox.
Step 2: Lower the Glovebox
With the damper removed, we can now work on taking out the glovebox without breaking anything.
You should see this:
The orange arrows point to the bump stops that keep the glovebox inside the instrument panel. You now need to pull the bumpstops down past the trim so they clear it.
The easiest way to do this is one at a time; I find the outboard (right) one is usually the trickiest. Don't be afraid to get a little rough with it. The left bumpstop actually has a huge fingerhold you can use.
Once you clear both bumpstops, swing the glovebox out. This picture might also give you a better idea of what the stops look like and how to grab them:
Step 3: Remove the Glovebox
Now we're clear of the interior and the glovebox can come out.
DO NOT USE TOOLS TO REMOVE THE GLOVEBOX. There's at least one writeup floating around that wants you to use a flathead screwdriver to punch the glovebox off; it's totally unnecessary and you risk breaking the mounting hardware or marring the interior that way.
Open the glovebox about halfway between "normally open" and hanging down. (Roughly like in the photo above.) This will line up the openings in the glovebox mounts so you can pull basically directly backward.
Grab the glovebox as close to the mounts as you can on both sides, and give it a good yank one side at a time. Start with the inboard side—if you do the outside first, there's not always enough room to grab the inside.
Once both sides are free, you may have to wiggle things around a little to get everything to clear the opening. Take your time and set the glovebox aside once it's out.
Step 4: Remove the Blower Motor Resistor
With the glovebox out of the way, we've got clear access to our target:
Only 2 Torx screws and a connector stand between you and four speeds of heating and cooling.
Unscrew both screws and remove the resistor. Do not unscrew anything else on the HVAC box; you just want to remove the 2 screws on the resistor itself. For clarity, they are called out with green arrows in the photo above.
With the resistor free, it's a lot easier to look at the connector and get it off. It's your typical "squeeze to unlatch" deal. (Hint: It's a lot bigger than you think it is.)
If you're extremely unlucky the connector may be damaged, but in my experience this is way, way less common with the WK than with the WJ. It also seems to be related to running faulty resistors for extended periods, so don't cheap out over an $8-9 part. If your connector is melted, seek professional help unless you're confident in your splicing skills.
Steps 4-99: Reassemble
Assembly is the reverse of removal.
As with taking it out, it's easier to put the glovebox back in inboard side first.
Putting it back on the hinges just takes a good shove; you'll feel it lock in, and it'll also be obvious you did it right when it's not flopping around.
Have a beer, you just saved $40+ in labor!
2006 WK Laredo 4x4 4.7L
1993 ZJ Laredo 4x4 4.0L Dead, sold, and rolling again
Last edited by colinzj; 07-21-2010 at 11:34 PM. Reason: Improve images, extra clarity
colinzj is offline
post #2 of 57 Old 12-15-2009, 10:27 AM
Texas WJ
Texas WJ's Avatar
2005 WK
Nice. I added this to the FAQ section.
265/70-17 BFGoodrich All-Terrain T/A KO, 2" lift, JK Wrangler Moab wheels, Spidertrax Spacers, Rola Roof Rack.
Texas WJ is offline
post #3 of 57 Old 12-15-2009, 10:52 AM
robtre
Its guys like you that make this forum awsome!!! Thank you
His:2005 Wrangler Rocky Mountain Edition
Hers:2005 Grand Cherokee Laredo
robtre is offline
post #4 of 57 Old 12-16-2009, 06:48 PM
glopez2k
2005 WK
This is great and friendly advice, I appreciate it.
glopez2k is offline
post #5 of 57 Old 12-16-2009, 09:40 PM
xOakley
xOakley's Avatar
2005 JK Wrangler
that easy, this is happing tomorrow haha
Sold- 98 XJ - 99 TJ - 05 WK
16 unlimited sport - Rubicon wheels/BFG tires and Rubicon rails
xOakley is offline
post #6 of 57 Old 12-17-2009, 07:24 AM
robtre
My wife and I were going back and forth Facebook vs Jeepforum she thinks I am obsessed with JF (I am) so I said go onto your facebook and find out how to fix your Jeep for free see what you come up with! That shut her down.
robtre is offline
post #7 of 57 Old 12-20-2009, 11:41 AM
sabre364
2007 WK
Great info! Thanks
sabre364 is offline
post #8 of 57 Old 07-21-2010, 06:06 PM
97tjeff
97tjeff is offline
post #9 of 57 Old 07-21-2010, 06:22 PM Thread Starter
colinzj
2006 WK
That's why the writeup only says to remove the two Torx screws on the resistor.
I'll swap that last image out with a slightly different one for the visual crew.
colinzj is offline
post #10 of 57 Old 07-21-2010, 06:49 PM
97tjeff
my bad. I looked at the picture and not the words apparently. well then, great write up all around!
97tjeff is offline
post #11 of 57 Old 07-21-2010, 11:29 PM Thread Starter
colinzj
2006 WK
New and improved! Now with 100% more green arrows and red Xs to prevent confusion!
colinzj is offline
post #12 of 57 Old 07-23-2010, 03:37 PM
jager00
2005 WK
dude ive replaced that part 2 times and need to again wtf is wrong with it
2007 JK Sahara- trying to figure this one out
2005 WK 9" lift on 37's with all the goodies- regretfully sold :(
jager00 is offline
post #13 of 57 Old 07-23-2010, 10:39 PM
97tjeff
which ones are you buying? IMO if you're going to Autozone to buy something like this, that's why. This is one thing where the best place to get it is the dealer.
97tjeff is offline
post #14 of 57 Old 07-24-2010, 08:48 AM
jager00
2005 WK
i got it from the dealor and it lasted a week or too... and then again... now it works on full blast all the time and low and med. if i slam the glove box lol
jager00 is offline
post #15 of 57 Old 01-14-2011, 05:50 AM
MBDiagMan
2005 WK
Great forum!
I'm trying to fix the blower on my daughters '05 Laredo while she's on her college graduation trip. I searched and found this thread. I only have this weekend to fix it and can only get parts from the dealer up until Noon Saturday morning.
How is the best way to test the "resistor?" Also I have a wiring diagram for the climate control part of the vehicle and do not see anything called a "resistor." I do see "Module Front Blower Power (ATC)" Is this the same thing? It sounds as if ATC refers to Automatic Temp Control, which hers doesn't have. I may have the wiring diagram for the wrong version.
Thanks for any help or suggestions you can offer, as she and her dog are freezing to death when driving it.
Also thanks very much for the pictorial and other information in this thread!
Doc
MBDiagMan is offline
anyone know how to replace the blower resistor? yepits2wd WK Grand Cherokee & XK Commander Forum 3 08-05-2009 01:38 PM
Wired up blower motor power module - do I need to replace blower motor? sniperdude ZJ Grand Cherokee Forum 0 04-19-2009 02:33 PM
HELP! Blower Motor, Blower Motor Resistor Fix Already Attempted... No Luck! DJGWJ ZJ Grand Cherokee Forum 3 12-26-2008 12:51 PM
Blower motor resistor 93ZJbeast ZJ Grand Cherokee Forum 6 02-04-2007 06:54 AM
Blower motor resistor eddiecai ZJ Grand Cherokee Forum 0 08-31-2006 07:40 PM
