How to use Miller 9336A Dipstick? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > How to use Miller 9336A Dipstick?
Poison Spyder JK LED Taillight & Wiring Harness KitsPoison Spyder JK Crusher CornersPANDEMIC-USA 50" Double row LED LIGHT BAR!! These thi
Unread 05-30-2015, 09:05 AM   #1
WKDiesel
I need some help on how to use the 9336 dipstick?
I changed my transmission oil last night and measured what came out, and roughly put the same amount in.
I have no leaks, but when ever I read the dipstick it shows nothing, I add a bit more still empty. The dip stick has fluid on it, but it seems to be on the edges. I'm not sure if it's picking up the tranny fluid thats in the tube or actually in the pad.
I've tried the zap strap method but it doesn't seem to be any fluid as well. This is starting to drive me crazy.
WKDiesel is offline   Reply With Quote Quick reply to this message
Unread 05-30-2015, 10:02 AM   #2
slayerized6
are you checking it on a cold engine/trans or a warmed up engine/trans?
2008 Grand Cherokee (WK)- 5.7l HEMI. OME HD Lift, Superchips Tune w/ ATT, aFe Intake, Flowmaster 44
slayerized6 is offline   Reply With Quote Quick reply to this message
Unread 05-30-2015, 12:44 PM   #3
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
What he said ^^^ Also, how many quarts did you add and are you checking it in Park or Neutral?
See How It Was Made
Omelet is offline   Reply With Quote Quick reply to this message
Unread 05-30-2015, 02:19 PM   #4
WKDiesel
I think it's more of an issue with the actual dip stick. The side with the number is pegged high but only in the outer edge. The back side without the number is lower but solid.
Not sure which side to use. The dip stick is going in with the number facing towards the front.
I just want to make sure I'm getting the right level.
I'm kind of wondering fluid in the dip stick tube is getting onto the actual dipstick.
Unread 05-30-2015, 04:18 PM   #5
nighowl2000
2014 JK Wrangler
get one of those 48" zip ties at home depot (in the electrical section). trim the bottom corners in a v up 10 cm. take a ruler and mark every 10mm up to 100mm. start the truck then let it warm up to operating temperature (should be around 165) slide it down the transmission tube and compare it with this graph:
Or for 160 bucks after taxes for a pan drop fluid service or 200 for a full flush, have these guys do it:
http://www.mistertransmission.com/langley
Had the mistertransmission do it in ottawa on friday with no issues so far with the wifes commander....
mine: 2014 jku sport S
her's: 2010 commander sport 3.7L 4x4
nighowl2000 is offline   Reply With Quote Quick reply to this message
Unread 05-30-2015, 07:12 PM   #6
WKDiesel
The 48" zap straps didn't work. The ones at home depot was too wide to fit down the spout. Good thing the local Mercedes dealer had a 722.6 nag1 dip stick.
The 9336 dorman dipstick didn't have enough texture iMo. Hard to tell where the oil actually sits. Wish they drilled tiny holes at all the 10s. Maybe the true Miller ones are better.
Unread 05-31-2015, 08:42 AM   #7
marka2k
marka2k's Avatar
2006 WK
How to use Miller 9336A Dipstick? - Oh the jokes that come to mind.....
Looking to purchase 2 BT Catch Cans PM if you have one or two for sale.
Silver WK Club #46
06 WK Overland
MyGiG RER
OEM Parkview Rear Camera
4xGuard Matrix
4XGuard Front Skid
4XGuard Rock Rails
HID Projector
2" Lift
04 TJ Rubicon Silver
Rokmen Fuel Tank Skid
Rokmen Front Skid
Rokmen Tummy Tuck
Novak Shifter
Ground Pounder Fab Front Bumper
Warn M8000 Winch
marka2k is offline   Reply With Quote Quick reply to this message
Unread 05-31-2015, 03:05 PM   #8
jediknight
2008 WK
... and if it's for the crd (w5j400) I'd recommand using the revised chart (available on the forum through another thread). The chart has the mention "revised" on it.
2008 WK CRD Blue, QD II, Startech SD6 mod.
jediknight is offline   Reply With Quote Quick reply to this message
Unread 05-31-2015, 05:36 PM   #9
WKDiesel
The revised chart is about 10mm more
Wonder why its 10mm more. As the Mercedes and sprinter applications of the same transmission does not require it.
