how Seafoam 2008 grand cherokee hemi - JeepForum.com
post #1 of 19 Old 08-23-2014, 02:59 PM Thread Starter
narutogoku
I been reading but not finding exactly where to put it. I should put 1/3 can in oil, gas and brake booster? Where is the brake booster at? Is it the tube that says brake booster that is behind the steering wheel?
Thanks for you time.
My vehicle: 2008 grand cherokee limited 5.7 4x4 113340 miles.
narutogoku is offline
post #2 of 19 Old 08-23-2014, 03:26 PM Thread Starter
narutogoku
Here are some pics. The line its pointing at is the one put the seafoam in?
post #3 of 19 Old 08-23-2014, 03:51 PM
Schvin
That's the vacuum line connecting/supplying your booster. It's says to put it in the 'brake booster' ? Or 'brake master cylinder' ?
Schvin is offline
post #4 of 19 Old 08-23-2014, 04:13 PM Thread Starter
narutogoku
It says to put it in a vacuum line, I read that the brake booster is the most popular?
post #5 of 19 Old 08-23-2014, 06:18 PM
Jeep Brian
Brake fluid is the ONLY thing you put in your master cylinder. Period!
Mine: 07 GC Limited Hemi stock for now.
Hers: 14 Dodge Durango Citadel Hemi
68 Firebird 350 4 spd #'s matching
Jeep Brian is offline
post #6 of 19 Old 08-23-2014, 06:35 PM Thread Starter
narutogoku
i found this video of a 2005 https://www.youtube.com/watch?v=q4CuUoQlvyM
mine should be similar right? The jeep needs to be on when pouring in vacuum right?
Thanks for the reply's.
post #7 of 19 Old 08-23-2014, 09:35 PM
caulk04
2008 WK
Yes, the engine must be running.
On mine there is a small capped off port just behind the TB that I hook a short hose to and run it in through there. The idea is to make sure you feed all cylinders.
08 Limited Hemi - wheels, tires, springs...ya know, stuff
caulk04 is offline
post #8 of 19 Old 08-23-2014, 10:04 PM
davidtownsend
2006 WK
If you want it in all cylinders shouldn't you pit it through the intake?
1994 Jeep Grand Cherokee 5.2L Limited
2006 Jeep Grand Cherokee Overland 5.7L Hemi
davidtownsend is offline
post #9 of 19 Old 08-23-2014, 10:10 PM
robpp
the vacuum is ported into the intake so ^^^^^^^^^^^ you are correct. the brake booster is common and usually a rather large hose. thats why they recommend it.
Rob 007 Laredo 4.7 FFV 27X; DeBadg'd; Zaino'd; SRT8 Grill, Pedals, Strut; ClearBra; WeatherTech; LED Reverse; HIR Hi/Lo; SS Fog; Stealth Turns; 15% Tint; Stubbie; Rear Spoiler; Magnaflow; V1; 22Elite Console/Visors; Body Kit; Color Match Everything; TintedTails; K&N 63; Front Skid; QuickOilDrainValve; BatteryTender; SuperChips 91; Bilstein; Billet Window Switches; Greasable Addco Sways; RamMedic Hood; Fastman TB; BWoody Links; Kicker Upgrade w/Single Sub; AVIC F90BT Hacked; NeffyWrap ABCD; Putco LEDs; Viper 20s w/255/50; R1 Slot/Dimple w/Hawk Pro Ceramic; Whistler Mod w/FlashTech Halos
robpp is offline
post #10 of 19 Old 08-23-2014, 10:19 PM
Jwhughes3
No real reason to not just put it in the gas tank -it mixes and cleans in the mixture just fine in my experience.
JW
Jwhughes3 is offline
post #11 of 19 Old 08-23-2014, 10:23 PM
caulk04
2008 WK
Running it through the fuel alone will really only clean the fuel system. Running it through the intake will much more aggressively clean the intake ports, valves and combustion chambers to rid them of carbon buildup.
I've had good success getting cats to perform better with a couple good seafoam treatments as well.
caulk04 is offline
post #12 of 19 Old 08-23-2014, 10:34 PM
Schvin
I was just clarifying. Never used sea foam
Schvin is offline
post #13 of 19 Old 08-24-2014, 08:36 AM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Make sure you change the oil/filter within about 50 miles of putting it in the oil.
Usually day after Seafoam is what I do. You don't wanna run all the churned up dirty oil for too long.
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is online now
post #14 of 19 Old 08-24-2014, 04:41 PM
LouC
2007 WK
What problem are you trying to solve?
If you want to clean the injectors and intake valves put a bottle of Techron in the tank.
2007 WK Limited Hemi QDII
1998 ZJ Laredo 4.0 Selectrac
LouC is online now
post #15 of 19 Old 08-25-2014, 12:25 PM Thread Starter
narutogoku
I did it yesterday, everything went fine. I put it in the vacuum, oil, and gas. I also got the intake cleaner and used that to. It did clean the intake but it is still dirty. Thanks for all you help.
