how to replace spark plugs on a 3.7l v6 WK - Page 2 - JeepForum.com
 1Likes
post #16 of 32 Old 12-07-2009, 09:20 AM
heep1991
I just did this over the weekend. Thanks for the helpful guide. I didnt disconect the O2 sensor I just set it aside and worked around it. Thanks again
1991 YJ 2.5L - SOLD
2006 Jeep Commander 6cyl - SOLD
2007 Jeep Unlimited Rubicon 3.8L
heep1991 is offline
post #17 of 32 Old 04-26-2010, 10:49 AM
Jonathan1084
2008 WK
Just did mine yesterday, I was a little worried about last plug on passenger side but actually it wasnt that bad for me ... I used: Spark plug socket + 6 in extension + two pivot flex socket + 10 in extension + ratchet ... It was very comfortable and easy ... just make sure you dont put that whole kit together and try to shove it in i had half together for the hand tightening of the plug then connected the rest.
The middle plug on the passenger side was a pain though... there was a bracket with the oil dipstick and some other flex soft hose with a cap that i didnt know what it did... I though the middle one was tougher than the last one to be honest ... Thanks for the post though... the pics helped a bunch...
2008 WK - All stock
Laredo X-Package - 3.7L 4x4
Jonathan1084 is offline
post #18 of 32 Old 07-17-2010, 10:25 AM
theSovereign
2007 WK
Just got done with mine and had the same exact thoughts as Jonathan... thanks as well for the post and the pics!
Edit: I should probably add that I needed to use a long extension on my screwdriver in order to remove the two star screws underneath the airbox.
theSovereign is offline
post #19 of 32 Old 04-25-2011, 08:43 AM
rbptrsn
2006 WK
Great write up, thanks! I have one tip: I used a 2" and a 9" extension for the back left (when looking at the engine) spark plug. I put the spark plug socket with a 9" extension in first then attached the wrench with the 2" extension. I was much easier to manage than using a 11".
rbptrsn is offline
post #20 of 32 Old 04-25-2011, 11:48 AM
CmmdrDan
I think I did mine the same but with a swivel on it.
CmmdrDan is offline
post #21 of 32 Old 04-10-2013, 08:22 AM
RIMAX
I have a problem with the order of the spark plug wires, and the order of the coil connectors. in a jeep grand cherokee 2009 3.7l, can help assist with some diagram?
RIMAX is offline
post #22 of 32 Old 04-10-2013, 11:06 AM
RIMAX
problem solved, firing order, 1-4 3-6 2-5 seeing engine front, right 135, left 246. regardless of the order of the injectors.
RIMAX is offline
post #23 of 32 Old 07-11-2013, 04:38 AM
Gwizzar
2007 WK
Excellent instructions!!!
I have done this twice now since my wife and I both own 2008 Jeeps and this thread helped immensely! First time, took just over 2 hours, second time 1 and a half from start to clean up. I also started with the back, left plug and removed the transmission bracket slightly to the side each time... not too bad at all. By the way, the hex star screws for the air filter took a T27 on ours
Gwizzar is offline
post #24 of 32 Old 07-11-2013, 10:53 AM
JRLT
2010 WK
My "problem" was getting the coil packs unmounted. I got a 2010 and I've got three of these(I know it says 4.7L)
The mounting bracket holds an anchor with a screw in it. Found out you just gotta get a big flat head screwdriver in between the anchor and the anchor hole on the engine and pry it out.
Putting it back in is just taking the screwdriver and tapping the top of the anchor so it'll pop back in the anchor hole.
2010 3.7L, 4XGuard Matrix, Fastman TB, TB Ground Mod, Injen CAI, 255/60/18 Nitto Terra Grapplers, Bilstein Shocks & Struts, Cruiser Alloy Wheels - Switchblade, Stillen Brakes, Cargo Light Strip Mod, Electric Ashtray Mod, Jet-powered, Monkey Navigated...
JRLT is offline
post #25 of 32 Old 08-24-2015, 10:01 AM
fetterjohn
2005 WK
I changed my spark plugs out for the recommended NGK copper plugs...somewhat easy to change. The whole job took about an hour.
One thing I noticed is that the acceleration seems more sluggish. My question is, how do I know that all 6 plugs are good? If one of them was not properly installed or is a dud, will I get an SEL light?
fetterjohn is offline
post #26 of 32 Old 08-24-2015, 10:24 AM
JRLT
2010 WK
Did you double check the gap(s) before installation?
JRLT is offline
post #27 of 32 Old 08-25-2015, 08:52 AM
fetterjohn
2005 WK
I gapped them to exactly .04mm (I believe that was what it called for).
I made sure that the coils snapped in properly and plugged in.
Not sure what I could have done other than having a bad plug. If there was a bad plug, would an SEL light up? Would there be other obvious signs?
post #28 of 32 Old 08-25-2015, 09:00 AM
JRLT
2010 WK
.04 or .44?
JRLT is offline
post #29 of 32 Old 08-26-2015, 09:15 AM
fetterjohn
2005 WK
.04 or .44?
Whatever is written on the front edge of the hood...I really do forget. But I know I did exactly what it says is required for the NGK plugs.
post #30 of 32 Old 08-26-2015, 10:27 AM
mjblackhurst
2010 WK
I was getting a CEL before and after I changed my plugs that indicated I had a bad plug. (in the end it was a bad plug wire boot)
http://www.jeepforum.com/forum/f67/p...82/index2.html
So I would assume you would get a misfire code (P0301 etc.) or something similar if you installed a bad plug.
mjblackhurst is offline
spark @ coil, no spark @ plugs 94GC52 ZJ Grand Cherokee Forum 4 07-09-2009 06:17 PM
WJ spark plugs Othoni ZJ Grand Cherokee Forum 2 06-16-2006 11:21 AM
Spark Plugs? fasta76 ZJ Grand Cherokee Forum 26 06-13-2006 01:58 PM
spark plugs grandman17 ZJ Grand Cherokee Forum 10 11-25-2005 06:06 PM
Spark Plugs michiganmaveric ZJ Grand Cherokee Forum 12 11-22-2005 09:25 AM
