how to remove rubber door boot? - JeepForum.com
post #1 of 3 Old 09-10-2007, 04:25 PM Thread Starter
chad1279
2005 WK
I am trying to install a component speaker system in my '05 Grand Cherokee. Has anyone figured out the trick to removing the rubber boot that runs from the door to the frame. I want to run my wiring in there but I can't figure out how to pop the seal where the boot hits the frame. Looks like it's sealed inside and out and very hard to get to.
chad1279 is offline
post #2 of 3 Old 09-10-2007, 06:17 PM
CEPCNC
2005 WK
Have you tried taking the door paneling off first to see the guts of the door...maybe there's an access/clip to loosen the boot. Check out http://www.wkjeeps.com for any info on that.
CEPCNC is offline
post #3 of 3 Old 09-11-2007, 10:14 AM Thread Starter
chad1279
2005 WK
yep that's done... nobody has pulled these things off before?
chad1279 is offline
Rubber Door gasket SWDoodle ZJ Grand Cherokee Forum 1 11-29-2009 10:31 PM
242 t-case rubber boot? KHoff90 ZJ Grand Cherokee Forum 1 09-26-2009 11:38 AM
broken wire in d/s door boot fixed!!!! bimmerjeeper ZJ Grand Cherokee Forum 2 04-25-2009 03:53 PM
Door Rubber Seal Loose cherokee04 ZJ Grand Cherokee Forum 4 03-02-2005 10:21 PM
1998 GCherokee rattling tailgate and door switch rubber covers ziko ZJ Grand Cherokee Forum 2 02-09-2004 04:49 AM
