How to remove engine shroud - JeepForum.com
post #1 of 7 Old 10-04-2013, 04:44 AM Thread Starter
hdsport
2008 WK
Just looking at my '08 JGC 4.7L engine yesterday and was going to pull a couple of plugs to check them and was wondering what is the method to remove the plastic shroud cover from the engine.
Didn't want to break anything, so I thought I'd seek some professional help.......
Thanks.
2001 Winnebago Adventurer 32v Motor Home
2008 Jeep GC Limited Toad, 4.7 L V-8, QTII
US Army Vet, 8th Army, 11th Evac SMBL Hospital, Pusan, South Korea
In God We Trust
hdsport is offline
post #2 of 7 Old 10-04-2013, 04:45 AM
scootter82
2009 WK
On my hemi, I just had to remove the oil cap then pull off the shroud
OME HD, JBA UCA, Rear Adj TB, Catch Can, K&N CAI, Gibson CB, MM TB, Flaspaq, Full LED swap
scootter82 is offline
post #3 of 7 Old 10-04-2013, 05:34 AM
caulk04
2008 WK
I didn't think the 4.7 had a shroud...I know the previous ones didn't. Maybe the 08+ does.
Otherwise, I'd imagine you're talking about the airhat/intake resonator. Should be a couple bolts on either side of it going into brackets on the intake manifold and obviously the hose clamps at the inlet and outlet.
08 Limited Hemi - wheels, tires, springs...ya know, stuff
caulk04 is offline
post #4 of 7 Old 10-04-2013, 07:04 AM
jjarvis0007
2005 WK
If you're talking about the 4.7 V8 cover its two 10mm bolts on each side and them some 5/16's on the throttle body and intake tube. Pull back and up once those are loosened and you'll be good to go.
jjarvis0007 is offline
post #5 of 7 Old 10-04-2013, 10:26 AM
modernblueWK
Nope, on the 2008 4.7 you pull the outer shroud toward you (toward the grille). Itjust pops into a few ball socket fasteners. The airbox is attached to the throttle body with a hose clamp.
The shroud you see is two pieces.
SOLD 2008 WK 4.7 V8
2013 Hemi Durango Crew
2007 Silverado Crewcab LT3
modernblueWK is offline
post #6 of 7 Old 10-04-2013, 12:39 PM Thread Starter
hdsport
2008 WK
Thank You, That's just the kind of information that I needed.
I just lifted up the front and gently pulled the catches from the rear and it came right off.
The air box was attached as you stated.
I checked one Top plug and it had a nice tan color and was gapped at .044.
Looks like a little wear, but nothing that says I should change them.
Thank You again for your help....this is what makes this Forum great.
In God We Trust
hdsport is offline
post #7 of 7 Old 10-04-2013, 06:48 PM
modernblueWK
If/when you do change them, make sure you use the proper factory spec bosch plugs. I got mine from justforjeeps.com.
SOLD 2008 WK 4.7 V8
