How much you paying for CRD oil filters? - Page 2 - JeepForum.com
post #16 of 21 Old 11-26-2013, 07:06 PM
gemiller
2008 WK
amsoil for around 10
2008 WK Red Rock Crystal Pearl CRD || Lifted and stuff.
gemiller is offline
post #17 of 21 Old 11-26-2013, 09:16 PM
Tuco
Tuco's Avatar
2007 WK
RM European 20% off this weekend. Makes Mann original equipment filter $8 each. They also have oil for about $35 per 5 liter
07 WK CRD Limited
Tuco is offline
post #18 of 21 Old 11-27-2013, 12:58 AM
va7cid
2008 WK
Go across the border to any of the local NAPA for filter at about $11 and Walmart Shell T6 at $22 for jug of 4L total of about $77 USD for a DIY oil change for your CRD with 2L of oil to spare instead of paying $200+ at your Stealership. Just hate them, don't ever waste your money on any extended warranty that will not cover anything at all.
va7cid is offline
post #19 of 21 Old 11-27-2013, 12:26 PM
gemiller
2008 WK
Definitely don't listen to va7cid, putting that oil in will cause the dpf failure to happen extremely expedited. Liquimoly, amsoil, Castrol and a handful of others make the appropriate 229.51 oil. Unless your dpf deleted, in which case you can use some other ones. I pay right around 100 give or take 10 or 20 bucks either way (I don't remember, ive got the fancy amsoil account) for amsoil plus filter.
gemiller is offline
post #20 of 21 Old 11-27-2013, 03:16 PM
ryann04
2008 WK
OP may have a DPF delete to expand his choices on oil.
If not then OP is stuck buying merc spec oil only.
2008 - Jeep Grand Cherokee - 3.0L CRD - Quadra Drive II - GDE Hot-Tune - OME HD Lift Kit - OEM Full Steel Skids
Blue WK Club Member #42 // DIESEL FTW !!!! -Ryan
ryann04 is offline
post #21 of 21 Old 11-28-2013, 06:07 AM
gemiller
2008 WK
Which would be exactly what I said in my post....
gemiller is offline
