How do I know if I need a transmission flush or coolant flush? - JeepForum.com
post #1 of 18 Old 06-27-2013, 08:19 PM Thread Starter
snowdude1026
2008 WK
I have a 2008 WK, 3.7L laredo, at 80,000 miles, lifted (if it matters).
I always replace the oil with synthetic every 3k miles.
However, I cant for the life of me remember when I did a transmission or coolant flush, or any other type of needed flush. I know it was in 2010 before I left for South Korea, or could have been when I got back. Either way, I dont remember the miles.
Could it hurt if I just went ahead and did all the needed flushes? Or is there a way to check and see if any are needed.
Thanks
snowdude1026 is offline
post #2 of 18 Old 06-27-2013, 08:22 PM
ryann04
2008 WK
Thanks
No it wouldn't hurt if you went ahead and did all the needed flushes.
2008 - Jeep Grand Cherokee - 3.0L CRD - Quadra Drive II - GDE Hot-Tune - OME HD Lift Kit - OEM Full Steel Skids
Blue WK Club Member #42 // DIESEL FTW !!!! -Ryan
ryann04 is offline
post #3 of 18 Old 06-27-2013, 08:37 PM
GhostRider08
2008 WK
DO NOT DO A TRANSMISSION FLUSH! This is not recommended! You can however have the transmission fluid drained and replaced, as well as the transmission filter.
GhostRider08 is offline
post #4 of 18 Old 06-27-2013, 08:59 PM Thread Starter
snowdude1026
2008 WK
Isnt that...a flush?
post #5 of 18 Old 06-27-2013, 09:02 PM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
No - it is a drain and refill with new filters.
A flush is a completely different process and as mentioned above: not recommended by the manufacturer.
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #6 of 18 Old 06-27-2013, 10:33 PM
WieSeL
A full flush isn't going to hurt anything and the dealer does it all the time. When it's not recommended is with high miles and original fluid
WieSeL is offline
post #7 of 18 Old 06-27-2013, 10:47 PM
suzieque
2008 WK
I am going to flush the hoat coolant from mopar. The cost container says "5 years" no mention of mileage on the mopar container.
2008 WK "S" Limited bright metallic silver exterior, light graystone interior, 5 speed W5J400 transmission, June 18/2008 build, C213RE rear differential with 3.73 axle ratio, C200FE front differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, GT2056V turbo, 3.0L CRD (OM642.980)
suzieque is offline
post #8 of 18 Old 06-27-2013, 10:55 PM
WieSeL
Id say 100k is probably about standard
WieSeL is offline
post #9 of 18 Old 06-28-2013, 05:04 AM
Budasac
2005 WK
According to Chrysler the transmission should NEVER be flushed unless the fluid was somehow contaminated regardless of what the dealer says. Drain and fill and replace the filters. Sadly dealerships don't know **** about the vehicles they sell. I don't trust them to touch my Jeep. (I get free lifetime oil changes and don't even take it to them for that.)
Coolant flush should be fine.
Budasac is online now
post #10 of 18 Old 06-28-2013, 07:08 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
Thanks
Chrysler Group vehicle fluid systems do NOT require regular flushing. These systems
include: engine oil, transmission oil, axle lube, brake fluid, power steering fluid, and
refrigerant. The only exception to this requirement are published in the vehicle
maintenance schedules, e.g. engine coolant.
Exceptions to this recommendation include only those instances where a failure has
occurred and/or the system has become compromised, contaminated or overheated
beyond the normal operating range.
Chrysler Group does NOT recommend aftermarket chemicals to flush the engine,
transmission, brake or steering systems. Chemicals contained in these products can
damage the system elastomeric components, and contaminate the component fluid,
leading to loss of system/component durability and service life. When necessary, only the
original approved system fluid should be used to flush these components using teamPSE®
approved equipment.
If the engine coolant contains a considerable amount of sediment, clean and flush with
Mopar Cooling System Flush, p/n 04856977, or equivalent. Follow with a thorough rinsing
to remove all deposits and chemicals. Refill with a minimum of a 50% mixture of the
specified coolant and distilled water.
JeepCares is online now
post #11 of 18 Old 06-28-2013, 10:24 AM
colinzj
2006 WK
They usually know about the vehicles they sell. They're just more motivated by the several-thousand-dollar flush machine BG provides them for free if they sell BG transmission flushes.
2006 WK Laredo 4x4 4.7L
1993 ZJ Laredo 4x4 4.0L — Dead, sold, and rolling again
colinzj is offline
post #12 of 18 Old 06-28-2013, 11:09 AM
WieSeL
You actually have to lease those machines and usually factory fluid is used and not a BG product. Flushes don't hurt transmissions if done regularly and not after 150k on original fluid
WieSeL is offline
post #13 of 18 Old 06-28-2013, 01:16 PM
ehron
Regardless, I wouldn't flush my transmission. I'd read about it a bit, and decide for yourself. Some say it's fine, others say it will destroy your transmission. One things for sure; it's a money maker for those interested in providing maintenance services. I'm always wary of services being offered that are lucrative for the entity providing the service (like throttle body cleaning, and other expensive processes that don't seem to require an effort commensurate with the cost).
Cost vs benefit analysis in my view results me in dropping the pan, changing the filters, and refilling with fluid. If you want to get all the fluid out of the torque converter pop off a trans cooler line and start the engine while adding enough fluid to make up for the fluid that's being pumped out by the transmission. There are numerous videos on youtube demonstrating that process.
ehron is offline
post #14 of 18 Old 06-28-2013, 04:09 PM
WieSeL
Some cars will actually have driveability issues with a coked throttle body so it's not always hype. And I don't think it's possible to add enough fluid through the dipstick tube to compensate for the fluid that will be pumped out of a cooler line. It will dump 5 quarts in a matter of about 1 minute. That seems much more detrimental than a simple flush. But like you said to each his own and there are different theories on the topic. Never heard anyone having issues with standard maintenance flushes in the years I've worked in a shop but every one.seems to think these flushes are voodoo or something. The horror stories you hear are from flushing a high mileage Trans with old fluid, and every one equates that to not doing maintenance on their transmissions. I've replaced more transmissions because of lack of maintenance and never due to a recent flush
WieSeL is offline
post #15 of 18 Old 06-28-2013, 05:08 PM
ehron
A coworker of mine was just telling me his wife was told by the Ford service rep that her 2012 Ford Explorer needed a throttle body cleaning as part of the standard 25k mile service for the low, low price of $325. $325 to unscrew the throttle body, spray some cleaner in it, and wipe it out. I wonder how much that dealer charges for a transmission flush...
I'll agree that the horror stories I've heard of flushes generally came from someone getting the sale price transmission flush at Jiffy Lube. I'm sure a competent technician will take the proper steps to ensure it's done correctly. As Jeepcares pointed out it's not recommended for WKs so perhaps it's a moot point.
ehron is offline
