How to diagnose service 4WD message? - Page 3 - JeepForum.com
post #31 of 45 Old 09-28-2009, 11:53 AM
merlinTec
merlinTec's Avatar
Hi
I have a front diff stripped at the moment shout what pictures you want if any. Must be tonight I plain on rebuilding it tomorrow.
UK Chrysler Jeep Master Tec.
merlinTec is offline
post #32 of 45 Old 09-28-2009, 01:19 PM
LJS8510
LJS8510's Avatar
2015 WK
please take some,
thanks
2015 WK II 5.7 Overland, Offroad Group II,- 2008 WK Limited 3.0 CRD, - 2003 WJ Laredo 4.7, - 2001 WJ Laredo 4.0, - 1999 WJ Limited 4.7-
LJS8510 is offline
post #33 of 45 Old 09-29-2009, 02:00 PM
merlinTec
merlinTec's Avatar
Originally Posted by LJS8510 View Post
please take some,
thanks
Well didn't know what you wanted and some good pics already posted so took these two for you.
post #34 of 45 Old 09-29-2009, 03:41 PM
LJS8510
LJS8510's Avatar
2015 WK
Thanks Merlin Tec
LJS8510 is offline
post #35 of 45 Old 10-18-2009, 06:40 PM
Podedwards
Podedwards's Avatar
Hold on
There is a service bulletin on wiring from the 4WD sensor to the computer. It is grounding out. Jeep will repair it.
The continuity has to be checked on that part of the wiring harness.
"An appeaser is one who feeds a crocodile, hoping it will eat him last" Winston Churchill
Podedwards is offline
post #36 of 45 Old 07-05-2010, 08:14 PM
crawbob
Got rid of the message. Stopped on dirt road got rid of the message and put into 4wd and drove several miles. No more message. Apparently there is a sensor that needs to be used once in a while or it gives a false message. Have driven 300 miles and no more messages.
crawbob is offline
post #37 of 45 Old 07-05-2010, 08:39 PM
kentman
kentman's Avatar
2006 XK Commander
My warning went out for a month or so, but it is back again. I have the solenoids for replacement. I am just waiting for the fluid interval to do the solenoid swaps.
If it is a TSB, that means that Jeep will fix it on your dime, assuming that you are out of warranty. I would rather fix it myself.
'06 XK Limited, 5.7L, QD II, Black, 170K
'02 WJ Overland, 4.7L HO, QD, Inferno Red, 130K
kentman is offline
post #38 of 45 Old 01-26-2012, 03:31 AM
samowens44
2005 WK
Service 4wd System Quadra Drive II System
I had this light on for 5 years, took into the dealer 3 times with the same results. Reprogram FDCM, clear light and told me it was an error. I finally found out that I could keep the light out by just delaying the turning of the key to the second position by 2 sec. then turn to start, no light. Worked, no Service 4wd light. Then I started having a clunking noise in the front when slowing and making left or right hand turns. After going on the internet and finding information about the Quadra Drive II, I saw what was happening with the aid of a web cam under my front bumper with a view of my CV Drive Axle. My front axle bushing was bad. Now this was replaced and still had the clunk, but not as violent. I discovered that the clunking is really a term called "Crow Hop". This is because the Front Drive Axle ELSD was not going to slip and staying in full 4wd lock. This was further found out thru the dealer diagnostics that the Actuator Solenoid and Wiring Harness were faulty. They were replaced and now my Jeep has no clunk sound and I am getting better gas mileage.
samowens44 is offline
post #39 of 45 Old 01-26-2012, 08:09 AM
07greygoose
2007 WK
My wife's 05 Hemi did this right after we bought it back in 2008. It would flash the "service 4WD System" message for about ten seconds then go away at first. Then a few months later it would not shift into 4WD at all and the message was permanent on the display. Took in to the dealer under warranty and ended up having to have a computer flash update and replace a differential. All costs were covered thankfully but haven't had any problems since.
2007 Grand Cherokee Laredo 4X4 TrailRated / 4.7 V8
Blue WK Club #24
07greygoose is offline
post #40 of 45 Old 07-19-2012, 04:16 PM
Stevehunts
2006 XJ Cherokee
service 4 wheel drive no codes
Same here, delay tirning the key, and no "service 4 wheel drive". Yep, I've had the flash update, and that resolved an earlier problem for 1 1/2 years. Following normal factory service on the transfere case, the service 4 wheel began coming on again. It has progress until now it will always come on unless waiting 2 seconds from on to start. Spent 2 days at the dealer checking wiring, modules, etc. Their final answer was to replace the rear ELSD solenoid. $50.00 for the part, $560.00 labor? with no gaurante this would solve anything. (they said they had a high ohms reading on the coil) From the pics I've seen, the coil looks like it can be changed just by pulling the cover? Is this true? Does anyone know what the coil should ohm out at?
Stevehunts is offline
post #41 of 45 Old 07-26-2012, 03:53 PM
denneyr
2005 WK
I have the service 4wd system message. I took it to the dealer and they analyzed it and said it was the transfer case actuator motor. I obtained a rebuilt transfer case motor and installed it. The message is still there and it still won't go into 4low. Any advice from here?
denneyr is offline
post #42 of 45 Old 07-27-2012, 05:29 AM
kentman
kentman's Avatar
2006 XK Commander
$560 for labor. Ouch. That is crazy. Once the cover is off, it takes all of a couple minutes to swap out the sensor. I paid $23 for the part and did the labor myself on the next fluid swap.
I and others have found that the front ELSD solenoid is the problematic one. I bought two solenoids and figured that I would try the front first and see if that cured the problem. If not, then I was going to do the rear one. The front one cured the problem. I left the rear one alone and swapped the fluid in the rear only.
kentman is offline
post #43 of 45 Old 07-27-2012, 08:02 AM
longboy
2006 WK
How difficult is it to replace the front solenoid? Obviously doing the rear would be much easier since you can remove the diff cover easily. I also have the Service 4WD message and debating taking it to a shop vs. doing it myself.
2006 5.7l WK
longboy is offline
post #44 of 45 Old 07-27-2012, 08:19 AM
IndyBlueWK
2005 WK
mine has been on for two months... Thinking about taking it in to see what they say..
IndyBlueWK is offline
post #45 of 45 Old 07-27-2012, 05:00 PM
kentman
kentman's Avatar
2006 XK Commander
On the XK, it was not bad at all. There is an extra mount on the cover that needs to be unmounted. Other than that, it is a normal front differential fluid swap in terms of work.
kentman is offline
Service 4WD System message being displayed kunzet WK Grand Cherokee & XK Commander Forum 44 03-24-2016 04:26 PM
Service 4WD message on dash madmarchhare WK Grand Cherokee & XK Commander Forum 7 09-22-2008 02:02 PM
'Service 4wd Switch' error message in 94 ZJ DonPud4x4 ZJ Grand Cherokee Forum 1 02-07-2007 09:44 AM
Perform Service Message? WhiskeyThrottle ZJ Grand Cherokee Forum 7 09-17-2003 08:28 PM
Service 4WD Switch message Charlie93GC ZJ Grand Cherokee Forum 0 02-05-2003 08:08 PM
